Results 1 to 2 of 2
Thread: 2016 SA Caddy xenon/led DRL Retofit
    Jul 2020
    Can anyone help? I have 2016 caddy. Retrofitting xenon/led to this vehicle. Checked Erwin for wiring diagram. Surprised to this set up was the same as the halogen head lights. So plugged in and did some coding but have issues as follows.
    In off position led DRL is on- this is correct acting as PRL
    In side light led DRL is on but on dimmed-?
    In dip beam xenon is on but no led side light- this is wrong
    In main beam xenon is on and shutter is working but no led side light-this is wrong
    Now the strange part. If vehicle is turned on and I hold the flash on for more than 3 seconds while the DRL is on in the off or side light position the headlights work correctly, and I have xenon dip beam with dimmed DRL acting as side light
    Wednesday,15,July,2020,23:00:24:32560
    VCDS Version: 20.4.1.0
    VIN: WV1ZZZ2KZGX088018   License Plate: 2016 CADDY
    Mileage: 66780km-41495mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
    VIN: WV1ZZZ2KZGX088018   Mileage: 66780km-41495miles
    Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 HA    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1804
       Revision: 8AH20---
       Coding: 011D001204250D090000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01104L906016HA 001003
       ROD: EV_ECM20TDI01104L906016GR_001.rod
       VCID: 6FEC5EE1B6E23CFEE2-803A
       Part No SW: 02E 300 063 J    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4934
       Revision: 06253104    Serial number: 00001511301053
       Shop #: WSC 35110 377 00143
       VCID: 1D305429C4CEFE6E00-8048
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 43545000002294
       Coding: 1079409B926AA48608750277498A25E3790000
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 3F8CCEA1A6028C7E32-806A
       Part No SW: 1K8 907 426 AR    HW: 1K8 907 426 AR
       Component: AC Manuell    H21 0909
       Revision: 00001002
       Coding: 0010004083
       VCID: 030402518A6A289E16-8056
       Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
       Component: BCM PQ35 M+   122 0183
       Revision: BD122001
       Coding: 491A583E8025E16A08080082940089EC03550008626F8360E48487040041
       VCID: 73E45291D2CA181E06-8026
       Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 14121  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 291215 03  37  0059
       Coding: 0228DD
       Subsystem 3 - Part No: 7N0 951 172
       Component: Sensor, DWA 0  005 0502
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 46
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 01:13:40
                        Voltage: 12.75 V
                        Reset counter: 46
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 01:13:40
                        Voltage: 12.75 V
       Part No SW: 1K8 919 465     HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0479
       Revision: --------    Serial number: 39291534801980
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14VW364GP00 001006
       ROD: EV_EPHVA14VW364GP00_VW36.rod
       VCID: 76E26B85C9B80D3621-8022
       Part No SW: 2K5 959 655     HW: 2K5 959 655
       Component: VW10Airbag019 008 0016
       Revision: --------    Serial number: 003QV001E90+
       Coding: 000000000000000000000000000000003139
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 79F860B9F8A6624E4C-802C
       Serial number: 3497ARB4010555MONASQ
       Serial number: 3507ARB40573NM3QD1TR
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 00:04:12
              B1007 1B [137] - Resistance Too High
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 00:04:12
       Part No SW: 5K0 953 521 FF    HW: 5K0 953 569 BB
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20151209201541
       Coding: 5880160010
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 75E06C89D4BE062E28-8020
       Part No SW: 2K5 920 976 A    HW: 2K5 920 976 A
       Component: KOMBI         H04 1009
       Coding: 480E001200
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
       VCID: 3466918D9F445F26DF-8060
       Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1674
       Revision:   H58       Serial number: 181215F1001220
       Coding: 357421
       Shop #: WSC 00000 288 1392035
       VCID: 74E6518DD7C41F261F-8020
       Component: IMMO          H04 1009
       VCID: 6ADA4FF58D00D9D6B5-803E
       Part No SW: 2K5 959 701     HW: 2K5 959 701
       Component: Tuer-SG         009 2144
       Coding: 0135728
       VCID: 71E8589968D62A0EF4-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 3978A0B97026A24E0C-806C
       Part No SW: 2K5 959 702     HW: 2K5 959 702
       Coding: 0135728
       VCID: 72EA57956DD011160D-8026
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
       Component: MU-E-D-ER     857 6495
       Serial number: 09121500012875
       Coding: 063307002800000041111101008000001F0000C60000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW32.rod
       VCID: 275C76C15E9224BE6A-8072
    0001 - Antenna 1 for Radio
              B1119 13 [009] - Open Circuit
                        Reset counter: 45
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 00:04:08
                        Voltage terminal 30: 11.6 V
    0003 - Antenna 2 for radio
              B111A 13 [009] - Open Circuit
                        Reset counter: 45
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 00:04:08
    0011 - Digital Radio Antenna
              B1103 13 [009] - Open Circuit
                        Reset counter: 45
                        Mileage: 66783 km
                        Date: 2020.07.15
                        Time: 00:04:08
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1674
       Coding: 030F1873
       VCID: 71E85899A8D62A0EF4-8024
       Subsystem 1 - Part No SW: 1K0 915 181 K    HW: 1K0 915 181 K
       Component: J367-BDM  H07 0223
       Serial number: 42345059048761253085
    End-------------------------(Elapsed Time: 02:41)--------------------------
    Tartu, Estonia
    You need to modify byte18.
    Bump this thread if You haven't gotten any extra info from me .
    The world is my oyster...
  3. Likes Uwe liked this post
