Results 1 to 8 of 8
Thread: I have no communication with the ECM 01
    Serbia
    Hello, this is a golf 7 2015 engine 1.6 CXXB. I have no communication with the ECM and it normally communicates with other modules.
    Can you help me with this?
    Monday,13,July,2020,13:00:43:56110
    VCDS Version: 20.4.1.0 (x64)
    VIN: WVWZZZAUZFW260271   License Plate:
    Mileage: 247294km-153661mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 69
    VIN: WVWZZZAUZFW260271   Mileage: 247294km-153661miles
    Address 01: Engine
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 60355000002282
       Coding: 01FA62A12426096C0779060741C42580462490E06082A4F300400068C002
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 7EF81624E12C5B7679-802A
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020104202100011005000000101000
       VCID: 6AD02A748DA4C7D6B5-803E
              B10CD 00 [008] - -
                        Reset counter: 229
                        Mileage: 247294 km
                        Date: 2020.07.13
                        Time: 12:38:39
                        Voltage terminal 30: 11.3 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011503800845
       Coding: 00020846C24102FB4BE44000001C07081000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 000468DC9BD82D860B-8054
       Component: WWS    150126  043 0551
       Serial number:         150130032807
       Component: RLHS  037 0059
       Serial number: S4Y15M02D10H03M20S42
       Coding: 00A8DD
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 189
                        Mileage: 247294 km
                        Date: 2020.07.13
                        Time: 12:21:32
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391503005176
       Coding: 0011051101
       VCID: 3D7AD128ACAA806E20-8068
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0FTKTF
       VCID: 4182ADD8D052E48E44-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 003 001 15
       Serial number: 35767000000F4261031H
       Subsystem 2 - Part No SW: -----------    HW: 480 003 001 15
       Serial number: 358670000005A911031G
       Subsystem 3 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3516502BB1901D923196
       Subsystem 4 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3526502A11901D9463C6
       Subsystem 5 - Part No SW: -----------    HW: 480 402 801 15
       Serial number: 3556502BB1901D92F3AP
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 31011504400876
       Coding: 0400
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 75EA0908D41A182E28-8020
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G1 920 741     HW: 5G1 920 741
       Component: KOMBI         203 5297
       Coding: 07A41A002380000800080A001400000000000000
       ASAM Dataset: EV_DashBoardJCIMQBAB 009003
       ROD: EV_DashBoardJCIMQBAB_009.rod
       VCID: 64CC444C6F8091A68F-8030
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1204
       Revision: --------    Serial number: 0003081102
       Coding: 030100340F087300EF000248080F00010001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 71E23D18A072340EF4-8024
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0038
       Serial number: 29150000215090125061
       Coding: 28FFFF
       Serial number: 4955515603
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 210115BAK05814
       Coding: 00310320D000040000001000
       VCID: 4280A2D4D554FF965D-8016
       Serial number: 00000000000005172463
       Coding: 110000
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 0102
       Shop #: WSC 64842 001 1048576
       VCID: 448CA4CCCF40F1A66F-8010
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 240115BAL13315
       Coding: 00310120DE00040000801000
       Serial number: 00000000000005180172
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT1.clb
       Part No SW: 5G0 035 867     HW: 5G0 035 867
       Component: MU-E--ER      640 5800
       Serial number: 17101400010838
       Coding: 02730000FF0000004011000100000000000000040000010000
       ASAM Dataset: EV_MUEnt4CLGE 001025
       ROD: EV_MUEnt4CLGE_VW37.rod
       VCID: 69D2557888A2CCCEBC-803C
       Part No SW: 5Q0 907 383 F    HW: 5Q0 907 383 C
       Component: Anhaenger     H14 0137
       Revision: 8B001001    Serial number: 0358084478
       Coding: 0100000202000000
       ROD: EV_TrailFunctGener2Hella_VW37.rod
       VCID: 3A70DA34BD84B75605-806E
    End-------------------------(Elapsed Time: 03:57)--------------------------
    Near Philadelphia, PA, USA
    Other symptoms? The obvious question is - is the engine able to run? If not, is the fuse for the ECM good? If the engine does run, then it would appear to be a connection problem to the engine controller. Refer to the wiring diagram and check the wiring to the diagnostic connections. It is a CAN connection - two wires twisted - CANHi and CANLo.
    Serbia
    The car works normally, starts and goes great but there is an error on the engine so I would like to see what the error is.
    I don't think it's a problem with communicating with CAN because I would get an error communicating in other modules whit ECU
    I think I have a problem with the software from my debug level interface or something like that.
    Please help me with that
    Quote Originally Posted by Wagenki View Post
    I disagree. The problem is not the software or a debug level. The problem is that your ECU is not talking/responding to requests made via the CAN bus. VCDS cannot reach it. That is not a debug level related error message.
    Serbia
    What do you suggest i do?
    Serbia
    I already had a similar problem. I couldn't communicate with AUTOHVAC on passat B5.5 and you sent me some fail and that solved the problem so I think there is a similar problem here
  7. #7
    Get the WD and trace the Powertrain CAN to the engine ECU.
    VCDS can talk to all the other modules, so I very much doubt this is a VCDS problem.
  8. #8
    Quote strange. The Gateway seems to be able to talk to it, and none of the other modules complain that they can't talk to it, yet VCDS doesn't.
    I don't think so. That Passat was a K-line car. A Golf 7 is strictly CAN.
    However, the HEX+CAN you are using is well over 10 years old and I suppose it wouldn't hurt to try a newer/different interface.
