Wednesday,15,July,2020,15:50:11:09571
VCDS Version: 20.4.1.0
VIN: 3VWD17AJ9FM285220 License Plate: 2015JETTA
Mileage: 186290km-115755mi Repair Order: 0001
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 44 56 77
VIN: 3VWD17AJ9FM285220 Mileage: 186290km-115755miles
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 997 071 C HW: 06K 907 425 C
Component: R4 1.8l TFS H13 2977
Revision: --H13---
Coding: 001A0012242400175000
Shop #: WSC 00066 000 00147
ASAM Dataset: EV_ECM18TFS02006K997071C 001002
ROD: EV_ECM18TFS02006K997071C.rod
VCID: 35619C9A9464152EE8-8060
6 Faults Found:
17178 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
Engine speed: 1195.00 /min
Normed load value: 8.2 %
Coolant temperature: 75 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.847 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
15125 - Cylinder 1
P0301 00 [039] - Misfire Detected
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
Engine speed: 1210.50 /min
Normed load value: 22.7 %
Voltage terminal 30: 14.042 V
FAC_LAM_LIM[1]: 0.000 %
Time since engine start: 72.0 s
Engine: operating status: IS
15131 - Cylinder 3
P0303 00 [039] - Misfire Detected
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
15134 - Cylinder 4
P0304 00 [039] - Misfire Detected
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
15128 - Cylinder 2
P0302 00 [039] - Misfire Detected
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [039] - -
Mileage: 186291 km
Date: 2020.07.15
Time: 20:11:29
Readiness: 1010 0101
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 A HW: 09G 927 749 A
Component: AISIN AG6 G3 109 2856
Coding: 000348
Shop #: WSC 00066 790 00016
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW32.rod
VCID: 377D96928E68E73EFA-8062
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492A00FF850D02E692190041A1100012
VCID: 0407315E873E7CA62F-8050
Reset counter: 35
Mileage: 186291 km
Date: 2020.07.11
Time: 00:00:19
Count: 2
Count: 12
Count: 20480
Count: 16390
Count: 42496
Count: 509
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 33
Mileage: 186277 km
Date: 2020.06.27
Time: 22:24:35
Count: 2
Count: 12
Count: 29184
Count: 16401
Count: 50176
Count: 62976
Count: 508
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 36
Mileage: 186277 km
Date: 2020.07.09
Time: 23:09:49
Count: 12
Count: 29184
Count: 8196
Count: 49408
Count: 507
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0349096159
Coding: 000F0F
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CG HW: 5C0 820 047 CG
Component: J301 Klimaanlage 0208
Revision: 2001001S Serial number: 00000002499546
VCID: 67DD06D25648B7BEAA-8032
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003352141277
Coding: 7B994B1808AB0B0000382080240884C50FC6702E60004050B0A010022844
VCID: 306FAD8E63063006BB-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585141114112858
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584141106144029
Coding: 820000
Subsystem 3 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 3171422334702345AD1B
Coding: 280000
Subsystem 4 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587141117081815
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586141111165352
Coding: 800000
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD040VG.
Coding: 00004B32
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72EB6786A58A42160D-8026
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1400023QC10S
Coding: 303142
Serial number: 3572MSME34273B4AZZZ.
Serial number: 3582MSME6B560C4AZZZ5
Serial number: 3516KSME2D0E7E30ZZZ%
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME421C7E30ZZZX
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME12167F31ZZZU
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME0B237F31ZZZ.
Part No SW: 5C6 920 954 B HW: 5C6 920 954 B
Component: KOMBI H04 0806
Coding: 270A01
Shop #: WSC 00066 000 00121
VCID: 2D51B4FA7C345DEE90-8078
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 37
Mileage: 186291 km
Date: 2020.07.14
Time: 22:28:03
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70EF6D8EA3867006FB-8024
Component: IMMO H04 0806
Coding: 000007
VCID: 6ADB7FE68D5A8AD6B5-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000318931002
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 306FAD8E6B063006BB-8064
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 305 3501
Revision: 00H22000
VCID: 397990AA707CF14E0C-806C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 11.9 V
PD
Temperature: 34.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 164 J HW: 1K0 035 164 J
Component: LOW NAR SDARS H05 0006
Revision: -----09S Serial number: VWZ4Z6P3864488
Coding: 01000400010006
VCID: 295940EA40DC41CE7C-807C
Reset counter: 33
Mileage: 186277 km
Date: 2020.06.27
Time: 22:24:34
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666752337
Coding: 0A10030080010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
VCID: 326BA786650A0216CD-8066
End-------------------------(Elapsed Time: 03:53)--------------------------
