- Joined
- Jul 14, 2020
- Messages
- 16
- Reaction score
- 7
- Location
- Jacksonville, FL, USA
- VCDS Serial number
- C?ID=407436
Hello everyone! Currently have a 2014 Jetta sportwagen in the shop that needs a new abs module. Old one is non responsive so no way to get old coding. I am familiar with how to code them and do all the basic settings just need the coding. Trying to avoid having to go to the dealer. Thanks in advance!
Monday,13,July,2020,08:51:22:04967
VCDS Version: 20.4.1.0 (x64)
VIN: 3VWPP7AJXEM614937 License Plate:
Mileage: 198970km-123634mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPP7AJXEM614937 Mileage: 198970km-123634miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 DA HW: 07K 907 309 B
Component: 2,5l R5/4V G01 5691
Revision: T4H06--- Serial number:
Coding: 0000075
VCID: 70E4260663B07406FB-8024
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 46
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:29
Speed: 254.0 km/h
Temperature: 73.0°C
Temperature: 52.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
001281 - Vehicle Speed Sensor
P0501 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Mileage: 198975 km
Date: 2014.11.11
Time: 20:55:32
RPM: 1576 /min
Load: 14.1 %
Speed: 254.0 km/h
Temperature: 81.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early
Date: 2047.15.31
Time: 31:63:63
Temperature: 81.0°C
Temperature: 57.0°C
Voltage: 9.017 V
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 81.0°C
Temperature: 57.0°C
Voltage: 9.906 V
Readiness: 0000 0100
Part No SW: 09G 927 750 LM HW: 09G 927 750 LM
Component: AQ 250 6F 2622
Revision: 00H97000 Serial number:
Coding: 0000008
VCID: 07166DDA763E53BE4A-8052
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 30811 001 1048576
VCID: 040C7AD6870878A62F-8050
10 Faults Found:
Fault Frequency: 7
Reset counter: 51
Mileage: 116886 km
Date: 2019.06.02
Time: 03:34:11
Count: 3
Count: 13
Count: 4096
Count: 16390
Count: 35072
Count: 508
Fault Status: 00101101
Reset counter: 17
Mileage: 124161 km
Date: 2019.07.08
Time: 14:16:42
Count: 16386
Count: 12
Count: 12800
Count: 8269
Count: 42752
Count: 768
Count: 65279
Count: 7936
02214 - Tire Pressure Warning
Fault Frequency: 12
Reset counter: 229
Mileage: 124161 km
Date: 2019.07.08
Time: 14:16:42
Count: 16386
Count: 12
Count: 12800
Count: 16401
Count: 42752
Count: 768
Count: 65279
Count: 7936
Fault Status: 00101100
Reset counter: 130
Mileage: 198975 km
Date: 2014.12.04
Time: 02:19:25
Count: 16387
Count: 12
Count: 24576
Count: 56
Count: 43776
Count: 249
Count: 58384
Reset counter: 130
Mileage: 393217 km
Date: 2032.08.00
Time: 16:04:19
Count: 256
Count: 35089
Count: 256
Count: 195
Count: 8269
Count: 256
Count: 12418
Count: 256
Fault Status: 01100101
Reset counter: 130
Mileage: 198975 km
Date: 2014.12.04
Time: 02:19:26
Count: 16387
Count: 24576
Count: 212
Count: 43776
Count: 59406
Reset counter: 130
Mileage: 198975 km
Date: 2014.12.04
Time: 02:19:26
Count: 16387
Count: 24576
Count: 279
Count: 43776
Count: 59406
Reset counter: 130
Mileage: 198975 km
Date: 2014.12.04
Time: 02:19:26
Count: 16387
Count: 24576
Count: 295
Count: 43776
Count: 59406
Reset counter: 130
Mileage: 196874 km
Date: 2001.00.03
Time: 00:28:10
Count: 2309
Count: 413
Count: 58624
Count: 270
Count: 3136
Count: 4353
Count: 142
Count: 13063
Reset counter: 130
Mileage: 198975 km
Date: 2014.12.04
Time: 02:20:33
Count: 16386
Count: 25088
Count: 266
Count: 51200
Count: 52224
Part No SW: 7N0 907 426 CA HW: 7N0 907 426 CA
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010002002
Shop #: WSC 00066 000 00119
VCID: 75EA1712D4D2512E28-8020
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 53
Reset counter: 170
Mileage: 198975 km
Date: 2020.06.20
Time: 05:32:41
Part No SW: 5K0 937 084 L HW: 5K0 937 084 L
Component: BCM PQ35 B 122 0173
Revision: BG122001
Coding: AF380E1A802F3EC4008800C17000004449000086435D0D20648020200040
VCID: 3B7EC12ABA76C75E1E-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07031 26 0512
Coding: 009795
Fault Frequency: 18
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:28
Voltage: 12.05 V
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R02WY71
Coding: 00004E42
Shop #: WSC 00066 790 00017
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C7CC236B778C06617-8068
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00009QFC00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME68371D41ZZZ-
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME5D104C41ZZZY
Serial number: 3511HSME3D4B2830ZZZP
Serial number: 3521HSME6E193030ZZZI
Component: F.Sens.Fahr --- ----
Serial number: 35527SME14020030ZZZT
Component: F.Sens.Beif --- ----
Serial number: 35627SME215B7D2FZZZX
13635840 - Supply voltage
Reset counter: 170
Mileage: 198975 km
Date: 2020.07.09
Time: 03:27:55
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Fault Frequency: 10
Reset counter: 170
Mileage: 198975 km
Date: 2020.06.20
Time: 05:32:26
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 170
Mileage: 198975 km
Date: 2020.07.09
Time: 03:27:11
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422NAU0007Z
Coding: 188A140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E8101EC9D45A3621-8022
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0402169 FLE 20140112
Coding: 820000
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 170
Mileage: 198975 km
Date: 2020.07.09
Time: 03:27:02
Part No SW: 5K0 920 973 F HW: 5K0 920 973 F
Component: KOMBI H04 0811
Coding: 270F01
VCID: 346CEA169F280826DF-8060
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 49
Reset counter: 170
Mileage: 198975 km
Date: 2020.06.20
Time: 05:32:24
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 24021403000470
Coding: 352002
VCID: 79F21B22F0CA354E4C-802C
Fault Status: 00110100
Fault Frequency: 47
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:27
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RPQ5607
VCID: 7EF8083E29E4127679-802A
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:30
Component: IMMO H04 0811
VCID: 6AD0346E8D6C8ED6B5-803E
Address 2E: Media Player 3
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0008019315
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5BBE61AA5236E75E3E-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008513555
Coding: 000490
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 130
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
VCID: 3972DB22704AF54E0C-806C
Fault Frequency: 29
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.29
Time: 18:28:01
Voltage: 14.25 V
DU
Temperature: 26.0°C
RPM: 1619 /min
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0007950010
Coding: 0004B4
VCID: 5CBC62B65738E06637-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000008103341
Coding: 000490
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3545555
Coding: 01000400040007
VCID: 64CC5A566748D8A68F-8030
00625 - Vehicle Speed Signal
Fault Frequency: 36
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:25
Reset counter: 130
Mileage: 198975 km
Date: 2014.11.11
Time: 05:32:25
Reset counter: 170
Mileage: 198975 km
Date: 2014.11.30
Time: 03:26:55
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665746250
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E58F87E710422F6A9-807A
End-------------------------(Elapsed Time: 02:50)--------------------------
