VCDS RODS MISSING CRAFTER LT3
Shade
South Africa
C?ID=291138
I did an auto can on a VW Crafter 2014 model. CKT engine. The crafter has a brand new ECU bought and programmed at VW on 13/07/2020. VCDS communicates only once with ECU and fails to clear codes. If I want to scan the vehicle again, I have to switch off the vehicle and wait about 5 minutes. If I do not wait I get a no communication message.
I scanned the vehicle and attempted to clear codes and it returned a no communication message and a pop up said, the "VCDS does not have the rods to communicate with crafter LT3 send the auto scan to Ross-Tech. I attach here below a copy of the scan.
Tuesday,14,July,2020,19:33:32:22233
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4526.4
VIN: WV1ZZZ2EZE6022791   License Plate:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 B    HW: 03L 906 012 A
   Component: R4 2,0L EDC   H26 8542
   Revision: 72H26---    Serial number: XXXXXXXXXXXXXX
   Coding: 0119001020040C080000
   Shop #: WSC 01457 996 00000
   ASAM Dataset: EV_ECM20TDI01103L906012B 002012
   ROD: EV_ECM20TDI01103L906012B_002.rod
   VCID: 230623422A83219E36-8076
12 Faults Found:
4875 - Coolant Pump 2
          P261A 00 [167] - Open circuit
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Coolant temperature: 96 °C
                    Intake air temperature: 14 °C
                    Ambient air pressure: 840 mbar
                    Voltage terminal 30: 12.380 V
                    Coolant temperature at radiator outlet: actual value: -40.0 °C
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 5
                    EGR cooling function: status-Bits 0-7: 1
                    exh.gas recirc. (EGR) cooler pump: specified value: 0.00 %
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    Exh.gas temp.sen 1: 1000.0 °C
10065 - Mass Air Flow Sensor (G70)
          P0104 00 [036] - Intermittent
                    Mileage: 7304 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Intake air temperature: 12 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 12.400 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Standardized airflow ratio: filtered: 3.9988
                    EGR Solen.val.: actual value: 99.39 %
                    Throttle valve adapter: actual value: 105.21 %
                    Charge air pressure specified value: 835 hPa
                    Charge air pressure: actual value: 840.6 hPa
                    Mean injection quantity: 0.00 mg/stroke
4238 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2185 00 [036] - Signal too High
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside air temperature: 13.5 °C
                    Fuel consumption: 0.00 l/h
                    Fuel temperature: 12.7 °C
                    Engine oil temperature: 107.3 °C
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
          P0105 00 [039] - Malfunction
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Charge air pressure: actual value: 849.2 hPa
                    Intake air pressure sensor after air cleaner: raw value: 1200 hPa
                    Engine status: COENG_READY
5040 - Fuel Injector #1 (N30)
          P0263 00 [167] - Contribution/Balance Fault
                    Mileage: 7278 km
                    Vehicle speed: 255 km/h
                    Voltage terminal 30: 12.580 V
                    Allowed number of injections-Bits 0-7: 0
                    Injection release status-Bits 0-7: 0
                    Desired injection characteristic-Bits 0-7: 0
                    Rail pressure regulation: status-Bits 0-7: 0
                    Fuel high pressure: actual value: 0 hPa
                    Control Module temperature: -273.1 °C
5042 - Fuel Injector #3 (N32)
          P0269 00 [167] - Contribution/Balance Fault
                    Mileage: 7278 km
5045 - Fuel Injector #4 (N33)
          P0272 00 [167] - Contribution/Balance Fault
                    Mileage: 7278 km
5041 - Fuel Injector #2 (N31)
          P0266 00 [167] - Contribution/Balance Fault
                    Mileage: 7278 km
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [036] - -
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine speed: 40.00 /min
                    Vehicle speed: 13 km/h
                    Voltage terminal 30: 12.280 V
                    Immobilizer snapshot A-Sia Error Snap A: 14 14 09
                    Immobilizer snapshot B-Sia Error Snap B: 5C 00 00
8621 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [167] - Circuit Malfunction
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Exh.gas temp.sen 3: 1200.0 °C
                    Exh.gas temp.sen 4: 1200.0 °C
                    Shut-off timer: last engine shut-off time: 41467 s
4631 - ECM Power Relay Load Circuit
          P068B 00 [039] - Opens Too Late
                    Time: 00:00:00
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
5260 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [039] - Circuit Malfunction
                    Mileage: 7278 km
                    Date: 2047.15.31
                    Time: 31:63:63
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 C    HW: 906 900 590 2
   Component: IMMO          1231  1322
   Revision: 00231000    Serial number: VWXDZ0M1055491
   VCID: 271E375296BBCDBE6A-8072
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 - - - MIL ON
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55E24D9A34578F2E08-8000
Address 95: LT3 ESP
   Part No HW: 0009013202
   Serial number: 000901320210851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069025501    HW: 9069010301
   ASAM Dataset: 32 792
   ROD: CRFT_KOMBI_32_792.rod
   VCID: 05425DDA8477FFAE38-8050
Address 99: LT3 Ign. Switch
   Part No HW: 9069005902
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        1231  1322
   Revision: 00231000    Serial number: 12345678901234
00171 - Key 1 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9069000401
   ASAM Dataset: 33 775
   ROD: CRFT_FTUHR_33_775.rod
Address B4: LT3 Central Elec.
   Part No SW: 9069024301    HW: 9069014500
   ASAM Dataset: 33 852
   ROD: CRFT_EZE_33_851.rod (*)
   VCID: 024846C69559C8961D-8056
9041 - Right turn signal: Open circuit
            Test Complete - Stored
90A1 - Engine Coolant Level (ECL) Sensor (G32): Short to Plus
            Test Complete - Active/Stored
903E - Left turn signal: Open circuit
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 06405AD6B971F4B631-8052
End----------(Elapsed Time: 01:07, VBatt start/end: 12.3V/12.3V)-----------
There are no missing RODs in this scan.
It sounds like this vehicle has issues with communications, but I have no idea what might cause the behavior you describe.
