Results 1 to 2 of 2
Thread: 2010-2011 Polo EGR fault codes
    Mar 2020
    Scotland
    My son has bought a Polo 6R and it is putting up Egr errors and is going into limp mode. Garage has given him 3 months warranty on car. Ive plugged it in and recorded faults as a safeguard against any excuses that may arrise. Also the r/h indicator lamp on dash is not working when indicator or hazards are on. Car has just been Mot'd a month ago the length of time he's had it. Any help appreciated as dont want them bodging it.
    Thursday,09,July,2020,17:10:47:47700
    VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ6RZBY053683   License Plate: NJ60TWF
    Mileage: 164060km-101942mi   Repair Order:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZBY053683   Mileage: 164060km-101942miles
    Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 BC    HW: 03L 906 023 D
       Component: R4 1.6l TDI   H13 9979
       Revision: --H13---    Serial number:
       Coding: 00114014000500080000
       Shop #: WSC 124697 483 00190
       ASAM Dataset: EV_ECM16TDI02103L906023BC 003014
       ROD: EV_ECM16TDI02103L906023AH_003.rod
       VCID: 6889BF6762F87E0BFB2-803C
    7563 - EGR Sensor 1
              P046C 00 [096] - Implausible Signal
                        Mileage: 163989 km
                        Date: 2020.07.08
                        Time: 16:44:59
                        Engine speed: 1436.25 /min
                        Normed load value: 89.4 %
                        Vehicle speed: 77 km/h
                        Coolant temperature: 81 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 14.005 V
                        Unlearning counter according OBD: 37
                        EGR Solen.val.: actual value-ANG_EGRV[0]: -0.189 %
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                        High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: -20.459 %
                        High press EGR actuator: actual unconditioned volt val-V_EGRV[0]: 0.693 V
                        EGR valve: offset closed-V_EGRV_BOL[0]: 0.698 V
                        EGR valve: offset open-V_EGRV_TOL[0]: 3.999 V
                        Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]: 78
    7343 - EGR Sensor 2
              P0407 00 [032] - Signal too Low
                        Mileage: 164039 km
                        Date: 2020.07.09
                        Time: 14:29:02
                        Engine speed: 1369.25 /min
                        Normed load value: 82.7 %
                        Vehicle speed: 73 km/h
                        Coolant temperature: 54 C
                        Intake air temperature: 22 C
                        Voltage terminal 30: 14.231 V
                        EGR Solen.val.: actual value-ANG_EGRV[0]: -0.562 %
                        High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: -15.207 %
                        High press EGR actuator: actual unconditioned volt val-V_EGRV[0]: 0.684 V
                        Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]: 70
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
       Revision: --------
       Coding: 230228E3417200B5C42B14EA82D400821300
       Shop #: WSC 02069 000 00000
       VCID: 065591DF486C887B69E-8052
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
       Component: Climatic       25 0660
       Revision: 00 11 25
       VCID: 35372613654AD3E3B04-8060
       Part No SW: 6R0 937 087 H    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0230
       Revision: BF046001    Serial number: 0345 188102351
       Coding: 25B029BF08E12400922000003D2B0CD00000410F60060000200000000000
       Shop #: WSC 00791 210 104164
       VCID: 42DD4DCF2484745B056-8016
       Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0912
       Serial number: KU0-KU030.06.1011160
       Coding: 08BC30
       Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0912
       Serial number: KU0-KU001.07.1011930
       Coding: 08BC30
       Subsystem 3 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
       Subsystem 5 - Part No: 1K8 951 171 A
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag00A H09 0020
       Revision: --------    Serial number: 003GX0048EH9
       Coding: 003041
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4ACD65EF1C34AC1BCD6-801E
       Serial number: 3572SRB40000C4907AFF
       Serial number: 3582SRB40000C50CE97I
       Serial number: 3515RRB40696Q5E6J046
       Serial number: 3525RRB40676Q5E6P19H
       Part No SW: 6R0 920 961 F    HW: 6R0 920 961 F
       Component: KOMBI         H04 0304
       Coding: 440A00
       VCID: 392F2A2349D2378354C-806C
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 0230
       Coding: 002100
       VCID: 70B9D7075AA8B6CBA32-8024
       Component: IMMO          H04 0304
       VCID: 6A8DC56F7CF44C1BED6-803E
       Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
       Component: SG EXT.PLAYER H13 0111
       Revision: A1001003    Serial number: 7668267244
       VCID: 270BFC5BAFE6B173328-8072
       Part No: 6R0 423 156 B
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F3B147B8E56E933FA8-807A
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K7149183
       Coding: 0100040002
       VCID: 6B83C06B738E5513960-803E
    00874 - Treble Speaker Front Left (R20)
                        Fault Status: 01101011
                        Reset counter: 134
                        Mileage: 163839 km
                        Date: 2014.11.23
                        Time: 09:17:38
    End----(Elapsed Time: 01:29, VBatt start/end: 11.9V/11.9V. VIgn 0.0V)------
  2. Likes Lgibson liked this post
  3. #2
    Sep 2016
    Riga, Latvia
    Hi!
    If You have warranty on this car, ask to replace the EGR module under warranty. It is a well known fault of those engines. Be strong when discussing this issue with garage, ask for original spare part, do not accept aftermarket EGR module - those cheap CRAP (Chinese Replacement Auto Part) works for couple months in best case...
  4. Likes Uwe liked this post
