Results 1 to 10 of 12
Thread: Cant do throttle body alignment - car in the limp mode
    Mar 2019
    My 2013 A6 3.0 is in the limp mode now; The engine can't go above 1500 RMP. I can't align the throttle body using VCDS; It doesn't allow me to do such a thing. I tried to start the car (engine-off) and press the gas for 30 seconds to do the auto-alignment. It works, but the errors don't go!
    Now I'm not sure where to start.
    My engine has six faults. Four of them are about the throttle body, and the other two are about misfire in CY1 - Which I guess it's related to TBA.
    Also, my transmission has that weird error comes up after flushing the transmission fluid!
    PS: I tried a new throttle body. and I get the same error.
    Any help?
    Monday,13,July,2020,16:03:55:25666
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4508.4
    VIN: WAUGGAFC3DN059406   License Plate: NEWWW
    Mileage: 179664km-111638mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
              5F 62 6C 72 8F 90
    VIN: WAUGGAFC3DN059406   Mileage: 179664km-111638miles
    Address 01: Engine (J623-CTUA)       Labels: None
       Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0002
       Revision: --H07---
       Coding: 0A2A0032052601060000
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ECM30TFS0214G0907551D 001003
       ROD: EV_ECM30TFS0214G0907551D.rod
       VCID: 2A0D0060EC796D77E09-807E
    7 Faults Found:
    10327 - Fuel Level too Low
              P1250 00 [037] - -
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:54:18
                        Engine speed: 1083.00 /min
                        Normed load value: 31.0 %
                        Vehicle speed: 1 km/h
                        Coolant temperature: 41 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 13.101 V
                        Engine speed: actual: 0 /min
                        MAF_ENVD: 0.00000 mg/stroke
                        Coolant temperature (unfiltered): 93.00 °C
                        Engine: operating status: ES
                        Battery voltage: 11.984375 V
                        Vehicle speed: actual: 0 km/h
    6516 - Throttle Valve Controller
              P1545 00 [096] - Malfunction
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:53:07
                        Coolant temperature: 44 °C
                        Intake air temperature: 34 °C
                        Voltage terminal 30: 11.679 V
                        Coolant temperature (unfiltered): 44.25 °C
                        Engine load: 0.000000 %
    6536 - Throttle Actuator (J338)
              P1579 00 [109] - Adaptation Not Started
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:53:29
                        Voltage terminal 30: 11.577 V
                        V_TPS_1_ENVD: 0.83984 V
                        V_TPS_2_ENVD: 4.23828 V
                        Coolant temperature (unfiltered): 43.50 °C
                        TIA_AM_SCHA: 34.50 °C
                        Battery voltage: 9.343750 V
    6522 - Throttle Body (J338)
              P1559 00 [165] - Fault in basic settings
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:58:19
                        Coolant temperature: 93 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 11.984 V
                        V_TPS_1_ENVD: 0.72266 V
                        V_TPS_2_ENVD: 4.19922 V
                        TIA_AM_SCHA: 36.75 °C
    7113 - Cylinder 1
              P0301 00 [101] - Misfire Detected
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:54:18
                        Engine speed: 1038.00 /min
                        Normed load value: 29.4 %
                        Voltage terminal 30: 12.999 V
                        Engine speed: actual: 1088 /min
                        MAF_ENVD: 413.97646 mg/stroke
                        Coolant temperature (unfiltered): 41.25 °C
                        Engine: operating status: PL
                        T_AST_ENVD: 25.70 s
                        Vehicle speed: actual: 1 km/h
    6372 - Control Module Malfunction - DBW Throttle Monitoring
              P1388 00 [036] - -
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:55:44
                        Engine speed: 3120.00 /min
                        Normed load value: 62.7 %
                        Vehicle speed: 29 km/h
                        Coolant temperature: 66 °C
                        Voltage terminal 30: 13.507 V
                        Engine speed: actual: 3072 /min
                        ENVD_0_MON: 9
                        ENVD_1_MON: 126
                        ENVD_2_MON: 168
                        ENVD_3_MON: 76
    7948 - Cylinder Disabling
              P130A 00 [101] - -
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:54:59
                        Engine speed: 1098.00 /min
                        Normed load value: 32.2 %
                        Vehicle speed: 3 km/h
                        Coolant temperature: 50 °C
                        Voltage terminal 30: 13.304 V
                        Engine speed: actual: 1216 /min
                        MAF_ENVD: 397.63528 mg/stroke
                        Coolant temperature (unfiltered): 50.25 °C
                        T_AST_ENVD: 51.40 s
                        Vehicle speed: actual: 3 km/h
    Readiness: 1110 1101
       Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H16 1006
       Revision: --H16---
       Coding: 000002
       VCID: 2D070B7CDD977A4F05B-8078
    2505 - Torque Management Feedback Signal A
              P2637 00 [032] - -
                        Mileage: 179664 km
                        Date: 2019.11.30
                        Time: 23:53:43
                        Voltage terminal 30: 11.298 V
                        Transmission output speed: 0.00 /min
                        Driving position: P
                        M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                        M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                        M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                        Transfer speed from ESP: valid
                        Transfer speed from ESP: 0.00 km/h
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 44A78F0122E5F1805B00
       Shop #: WSC 02391 785 00200
       VCID: 3635241028C13997741-8062
    0787 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
              [SCL_MO_Motormomente_Invalid]
                        Reset counter: 136
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:17:26
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 00
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: E6
                        Uz: 85
       Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
       Component: BCM2 2.0      H32 0421
       Coding: 0DA82046000000000000
       VCID: 7BA3F52453E324FFCBF-802E
       Serial number: 2312000185559009
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 AH    HW: 4G0 820 043 AH
       Component: KLIMA 2 ZONEN H11 0076
       Serial number: 12091200110296
       Coding: 6681201849
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: 6597B35CC5E7820F0DB-8030
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 96
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:14:43
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 34.0 °C
                        Temperature after evaporator: 33.72 °C
                        Engine speed: 757 /min
    0379 - Supply Voltage Terminal 30 for Coolant Pump
              B11D5 01 [008] - Electrical Failure
                        Reset counter: 135
                        Mileage: 179664 km
                        Date: 2019.11.27
                        Time: 02:59:53
       Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
       Revision: 11012002    Serial number: 00000001613528
       Coding: 06002011063C9FE08100008380003908CF9CD208A6090221000004406000
       VCID: 6FBBD174179B485F777-803A
       Component: WWS57X 120802  H36 0080
       Serial number:         120808174755
       Coding: 0045F7
       Serial number: 20548726
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
       Component: E1 - LDS  H07 0044
       Serial number: 07 09 2012  00001689
       Serial number: 24488946000000000001
    02258 - Door Opener Transmitter
                        Reset counter: 94
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:14:00
       Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
       Component: PARKHILFE ACC H01 0072
       Revision: 11001001    Serial number: 61061225700966
       Coding: A8C305
       ASAM Dataset: EV_EPHVA18AU57X0000 003008
       ROD: EV_EPHVA18AU57X0000_003.rod
       VCID: 77ABE9146F4B009FAF7-8022
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H32 0032
       Revision: --------    Serial number: 003D8002CWP9
       Coding: 303234373131303030314A55304C34473053
       VCID: 33331D043BB32CBF53F-8066
       Component: BF-Gewichtss.  H11 0046
       Serial number: 6940000Y120000HUEA0+
       Serial number: 3575HRB405R1HA3I6GQ-
       Serial number: 3585HRB405J1HAR2D1PS
       Serial number: 3515JRB40691D2ASC1RC
       Serial number: 3525JRB40691D2AS1GJ9
       Serial number: 3554VRB405J1GLOM59MJ
       Serial number: 3564VRB400S52JMQFGNW
       Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
       Revision: --------    Serial number: 90372LGH0022B
       Coding: 000414
       VCID: 38292A282255CFE766D-806C
       Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
       Component: E221 - MFL  H09 0010
       Serial number: 19 08 2012  33273970
       Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
       Component: TBenUsa       H79 0515
       Revision: 28460207    Serial number: 658050912596047
       Coding: 0BEF09040B41D705020000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       VCID: 372B29142FCBC09F6F7-8062
       Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AA
       Component: J533--Gateway H11 0035
       Revision: --------    Serial number: 00000000676364
       Coding: 00CD073000
       ASAM Dataset: EV_GatewPkoUDS 001016
       VCID: 71BFD70C012F5EAF613-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790138169
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 190612000000000002B6
    0022 - Control Module Incorrectly Coded
              U1014 00 [008] - -
              [Steuergerät falsch codiert (MOST)]
                        Reset counter: 135
                        Mileage: 179664 km
                        Date: 2019.11.29
                        Time: 16:58:27
                        Voltage terminal 30: 11.6 V
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 30 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    0267 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 135
                        Mileage: 179664 km
                        Date: 2019.11.29
                        Time: 14:56:41
                        Voltage terminal 30: 11.8 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 26 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000038583932
       VCID: 77ABE9146FCB009FAF7-8022
       Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
       Component: SARA 6D       H02 0053
       Revision: --------    Serial number: EJ1BPA820168P1
       ASAM Dataset: EV_SARA2 005011
       ROD: EV_SARA2.rod
       Component: TSG FA        H03 0506
       Coding: 011F17004E00628002000002
       VCID: 47CB59D45FABB01F1F7-8012
       Component: RCEPS         H36 0010
       Revision: 00001000    Serial number: 0003849993
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1800C4A925B7589-8066
    5258753 - Steering End Stops Not Learned
              C10AC F0 [137] - Unknown Error Elaboration
              [Lenkungsendanschläge nicht angelernt]
                        Fault Frequency: 150
                        Reset counter: 96
                        Mileage: 179664 km
                        Date: 2019.11.27
                        Time: 02:47:43
                        Write only channel
       Revision: 00002001    Serial number: 0183853267
       Coding: 0106163A00FA400581B008040205030F0000000000000000000000000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000106949
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO1799724D
       Coding: 101F00
    01134 - Alarm Horn (H12)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 94
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:14:45
                        Fault Status: 11101100
                        Reset counter: 95
                        Mileage: 179664 km
                        Date: 2019.11.27
                        Time: 02:52:06
                        Reset counter: 95
                        Mileage: 179664 km
                        Date: 2019.11.27
                        Time: 02:52:06
    02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
                        Reset counter: 96
                        Mileage: 179664 km
                        Date: 2019.11.29
                        Time: 17:03:29
       Component: TSG BF        H03 0506
       VCID: 46D554D058A1A917E41-8012
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000466548
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B030564E383747F1BF-807E
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                        Reset counter: 136
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:17:26
                        Voltage terminal 30: 12.0 V
                        Internal Fault ID: 188
                        Network management state: normal
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
       Serial number: 120907-0002-130
       Coding: 1221A6101002A500
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156I30C7633981
       Coding: 020007020100000001
       VCID: 211FE74C91CFAE2FB13-8074
       Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
       Component: H-BNT-NA      H49 0549
       Revision: --------    Serial number: 194IZ0C7512711
       Coding: 000200000103E0EF45128F1E00000003100001000000000000
       VCID: 2615F450F8E14917C41-8072
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9402HM6V
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349LIC000BB
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
    02067 - Optical Databus; Unpermitted Wake-Up Request
                000 -  -  - Intermittent
                        Reset counter: 135
                        Mileage: 179664 km
                        Date: 2019.11.29
                        Time: 14:55:12
                        Voltage: 11.80 V
    01524 - Antenna for Telephone
                        Fault Status: 01101011
                        Reset counter: 96
                        Mileage: 179664 km
                        Date: 2019.11.26
                        Time: 00:23:52
                        Voltage: 12.20 V
       Component: TSG HL        H03 0506
       VCID: 49CF5FEC49BF466F093-801C
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H06---    Serial number: 525 PA8J28G232
       Coding: 1080004
       VCID: 2615F450F4E14917C41-8072
       Component: TSG HR        H03 0506
       Coding: 00060000031F030000030801424CDA010000
       Shop #: WSC 46128 001 1048576
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F170CC1AF1EAF213-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    End----------(Elapsed Time: 02:12, VBatt start/end: 12.2V/12.0V)-----------
    What was the source of the "new" throttle body?
    Have you properly verified all relevant wiring and connections?
    The fault code in the transmission looks like a "sympathy" code to me. I wouldn't worry about that until you get the engine running right.
    Mar 2019
    I bought the new throttle body from Carparts. I will Check/Measure the wiring using a multimeter and come back to you.
    Thank.
    Voltage is weak..............
  5. Likes Uwe liked this post
    Mar 2019
    Okay. Now I'm confused. The battery voltages look fine in some parts, but it's off in the actuator! How can I fix that?
    And excuse my ignorance; isn't the actuator part of the throttle body! If so, why I got two different voltage readings in my scan!
    Thanks, Jack.
    Voltage drop sir and loss of current?
    Did you know probably nothing wrong with old TV?
    Overlay the wires from ECU to TV directly yet to insure good ability to carry current?
    It's like a widespread problem in the VAG bag no for harness from ECU to load consumers being insufficient, did you check NHTSA yet for recall coverage or to report it?
    Is not this repair under useful life warranty under the 10/120?
    Ever JPPSG especially page 5?
    https://forums.ross-tech.com/showthr...l=1#post156577
    Mar 2019
    Not sure if you are asking me or telling me! too many question marks.
    Jack, If I know how to fix it, I would not come here in the first place.
    No, I haven't checked NHTSA for any recalls, and I do have access "ShopKey-Pro" with a service manual -- so, I'm not flying dark here.
    If you are implying a bad wiring connection from ECU to the TB. I will check the wires tomorrow and let you know as I mentioned to Uwe.
    Thanks for your time.
  9. #8
    I'm always asking can't you see that with the question marks?
    You do realize that if connection is bad or insufficient it can't carry current and hence when load is applied the voltage drop commences?
    Glad to hear you have something and not flying dark, did you know ERWIN or RB would be better?
    You do realize questions are not instructions and therefore are not statements, you know for liability reason's in this day in age?
  10. #9
    Mar 2019
    I do see the question marks; however, your words don't make any sense.
    Yes. A bad connection will have a downward effect on the current. I know that; however, I didn't realize that I may have this problem beforehand making this topic.
    I may buy ERWIN or RB subscription down the road for my Audi cars. Thanks for mentioning that.
    No, sir, I'm not sure what liability reasons you are talking about. I may need more clarification. I only know that we are communicating through words and well-known punctuation rules, and not following these rules will lead to a misunderstanding.
    For example, here's an improved version of your last comment in the question format. It may not be perfect, but It will be will understandable by whoever reads it.
    >> Sir, Is losing the current related to Voltage drop?
    >> Don't you know that nothing wrong with an old Tv?
    >> Most likely, the wires from the ECU to the TV are worn out.
    >> OR : Did you ensure (not insure) good connectivity between the TV and the ECU?
    >> Have you checked with NHTSA for recalls?
    >> OR: Did you check with NHTSA for recalls before posting your question?
    >> Does this repair still valid under the lifetime warranty regulation NO: 10/120?
    >> OR: Will this repair be acceptable according to the lifetime warranty regulation NO: 10/120?
    >> Have you checked page 5 in the JPPSG topic?
    One more last thing, We (DIY community) are not experts. Thus, seeking support from experts like you is our first stop. So If you are willing to help, that will be great, If not, then please don't overwhelm us with such an attitude.
    Thank you. Have a good night.
  11. #10
    I'll take your criticism under advisement, okay?
    It is not with an intent to be an attitude, sorry if you think so, did you just give legal advice, are you a lawyer?
    I prefer my questions to be cryptic and force one to work and realize "their" own summation doing their own tests, not mine, you can see the bifurcation of the two, is that right?
    I respectfully agree to disagree with some of your advice.
  12. Likes bobster liked this post
