My 2013 A6 3.0 is in the limp mode now; The engine can't go above 1500 RMP. I can't align the throttle body using VCDS; It doesn't allow me to do such a thing. I tried to start the car (engine-off) and press the gas for 30 seconds to do the auto-alignment. It works, but the errors don't go!
Now I'm not sure where to start.
My engine has six faults. Four of them are about the throttle body, and the other two are about misfire in CY1 - Which I guess it's related to TBA.
Also, my transmission has that weird error comes up after flushing the transmission fluid!
PS: I tried a new throttle body. and I get the same error.
Any help?
Any help?
Monday,13,July,2020,16:03:55:25666
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4508.4
VIN: WAUGGAFC3DN059406 License Plate: NEWWW
Mileage: 179664km-111638mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
5F 62 6C 72 8F 90
VIN: WAUGGAFC3DN059406 Mileage: 179664km-111638miles
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0002
Revision: --H07---
Coding: 0A2A0032052601060000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM30TFS0214G0907551D 001003
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A0D0060EC796D77E09-807E
7 Faults Found:
10327 - Fuel Level too Low
P1250 00 [037] - -
Mileage: 179664 km
Date: 2019.11.30
Time: 23:54:18
Engine speed: 1083.00 /min
Normed load value: 31.0 %
Vehicle speed: 1 km/h
Coolant temperature: 41 °C
Intake air temperature: 33 °C
Voltage terminal 30: 13.101 V
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 93.00 °C
Engine: operating status: ES
Battery voltage: 11.984375 V
Vehicle speed: actual: 0 km/h
6516 - Throttle Valve Controller
P1545 00 [096] - Malfunction
Mileage: 179664 km
Date: 2019.11.30
Time: 23:53:07
Coolant temperature: 44 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.679 V
Coolant temperature (unfiltered): 44.25 °C
Engine load: 0.000000 %
6536 - Throttle Actuator (J338)
P1579 00 [109] - Adaptation Not Started
Mileage: 179664 km
Date: 2019.11.30
Time: 23:53:29
Voltage terminal 30: 11.577 V
V_TPS_1_ENVD: 0.83984 V
V_TPS_2_ENVD: 4.23828 V
Coolant temperature (unfiltered): 43.50 °C
TIA_AM_SCHA: 34.50 °C
Battery voltage: 9.343750 V
6522 - Throttle Body (J338)
P1559 00 [165] - Fault in basic settings
Mileage: 179664 km
Date: 2019.11.30
Time: 23:58:19
Coolant temperature: 93 °C
Intake air temperature: 36 °C
Voltage terminal 30: 11.984 V
V_TPS_1_ENVD: 0.72266 V
V_TPS_2_ENVD: 4.19922 V
TIA_AM_SCHA: 36.75 °C
7113 - Cylinder 1
P0301 00 [101] - Misfire Detected
Mileage: 179664 km
Date: 2019.11.30
Time: 23:54:18
Engine speed: 1038.00 /min
Normed load value: 29.4 %
Voltage terminal 30: 12.999 V
Engine speed: actual: 1088 /min
MAF_ENVD: 413.97646 mg/stroke
Coolant temperature (unfiltered): 41.25 °C
Engine: operating status: PL
T_AST_ENVD: 25.70 s
Vehicle speed: actual: 1 km/h
6372 - Control Module Malfunction - DBW Throttle Monitoring
P1388 00 [036] - -
Mileage: 179664 km
Date: 2019.11.30
Time: 23:55:44
Engine speed: 3120.00 /min
Normed load value: 62.7 %
Vehicle speed: 29 km/h
Coolant temperature: 66 °C
Voltage terminal 30: 13.507 V
Engine speed: actual: 3072 /min
ENVD_0_MON: 9
ENVD_1_MON: 126
ENVD_2_MON: 168
ENVD_3_MON: 76
7948 - Cylinder Disabling
P130A 00 [101] - -
Mileage: 179664 km
Date: 2019.11.30
Time: 23:54:59
Engine speed: 1098.00 /min
Normed load value: 32.2 %
Vehicle speed: 3 km/h
Coolant temperature: 50 °C
Voltage terminal 30: 13.304 V
Engine speed: actual: 1216 /min
MAF_ENVD: 397.63528 mg/stroke
Coolant temperature (unfiltered): 50.25 °C
T_AST_ENVD: 51.40 s
Vehicle speed: actual: 3 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
VCID: 2D070B7CDD977A4F05B-8078
2505 - Torque Management Feedback Signal A
P2637 00 [032] - -
Mileage: 179664 km
Date: 2019.11.30
Time: 23:53:43
Voltage terminal 30: 11.298 V
Transmission output speed: 0.00 /min
Driving position: P
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Transfer speed from ESP: valid
Transfer speed from ESP: 0.00 km/h
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 44A78F0122E5F1805B00
VCID: 3635241028C13997741-8062
0787 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[SCL_MO_Motormomente_Invalid]
Reset counter: 136
Mileage: 179664 km
Date: 2019.11.26
Time: 00:17:26
VzRef: 00
Bit Info 1: 80
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E6
Uz: 85
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H32 0421
Coding: 0DA82046000000000000
VCID: 7BA3F52453E324FFCBF-802E
Serial number: 2312000185559009
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH
Component: KLIMA 2 ZONEN H11 0076
Serial number: 12091200110296
Coding: 6681201849
ASAM Dataset: EV_AirCondiBasisUDS 002040
VCID: 6597B35CC5E7820F0DB-8030
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 96
Mileage: 179664 km
Date: 2019.11.26
Time: 00:14:43
Compressor current: actual value: 0 mA
Outside air temperature: 34.0 °C
Temperature after evaporator: 33.72 °C
Engine speed: 757 /min
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [008] - Electrical Failure
Reset counter: 135
Mileage: 179664 km
Date: 2019.11.27
Time: 02:59:53
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001613528
Coding: 06002011063C9FE08100008380003908CF9CD208A6090221000004406000
VCID: 6FBBD174179B485F777-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120802 H36 0080
Serial number: 120808174755
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20548726
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 07 09 2012 00001689
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 24488946000000000001
02258 - Door Opener Transmitter
Reset counter: 94
Mileage: 179664 km
Date: 2019.11.26
Time: 00:14:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061225700966
Coding: A8C305
ASAM Dataset: EV_EPHVA18AU57X0000 003008
VCID: 77ABE9146F4B009FAF7-8022
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8002CWP9
Coding: 303234373131303030314A55304C34473053
VCID: 33331D043BB32CBF53F-8066
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y120000HUEA0+
Serial number: 3575HRB405R1HA3I6GQ-
Serial number: 3585HRB405J1HAR2D1PS
Serial number: 3515JRB40691D2ASC1RC
Serial number: 3525JRB40691D2AS1GJ9
Serial number: 3554VRB405J1GLOM59MJ
Serial number: 3564VRB400S52JMQFGNW
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LGH0022B
Coding: 000414
VCID: 38292A282255CFE766D-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 19 08 2012 33273970
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 983 E HW: 4G8 920 983 E
Component: TBenUsa H79 0515
Revision: 28460207 Serial number: 658050912596047
Coding: 0BEF09040B41D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 372B29142FCBC09F6F7-8062
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000676364
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001016
VCID: 71BFD70C012F5EAF613-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790138169
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 190612000000000002B6
0022 - Control Module Incorrectly Coded
U1014 00 [008] - -
[Steuergerät falsch codiert (MOST)]
Reset counter: 135
Mileage: 179664 km
Date: 2019.11.29
Time: 16:58:27
Voltage terminal 30: 11.6 V
Voltage terminal 15: 11.6 V
Control Module temperature: 30 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 135
Mileage: 179664 km
Date: 2019.11.29
Time: 14:56:41
Voltage terminal 30: 11.8 V
Voltage terminal 15: 0.0 V
Control Module temperature: 26 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000038583932
VCID: 77ABE9146FCB009FAF7-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA820168P1
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Component: TSG FA H03 0506
Coding: 011F17004E00628002000002
VCID: 47CB59D45FABB01F1F7-8012
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0003849993
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1800C4A925B7589-8066
[Lenkungsendanschläge nicht angelernt]
Fault Frequency: 150
Reset counter: 96
Mileage: 179664 km
Date: 2019.11.27
Time: 02:47:43
Write only channel
Revision: 00002001 Serial number: 0183853267
Coding: 0106163A00FA400581B008040205030F0000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000106949
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1799724D
Coding: 101F00
01134 - Alarm Horn (H12)
014 - Defective
Fault Status: 01101110
Reset counter: 94
Mileage: 179664 km
Date: 2019.11.26
Time: 00:14:45
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Reset counter: 95
Mileage: 179664 km
Date: 2019.11.27
Time: 02:52:06
Reset counter: 95
Mileage: 179664 km
Date: 2019.11.27
Time: 02:52:06
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
Reset counter: 96
Mileage: 179664 km
Date: 2019.11.29
Time: 17:03:29
Component: TSG BF H03 0506
VCID: 46D554D058A1A917E41-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000466548
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B030564E383747F1BF-807E
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Reset counter: 136
Mileage: 179664 km
Date: 2019.11.26
Time: 00:17:26
Voltage terminal 30: 12.0 V
Internal Fault ID: 188
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 120907-0002-130
Coding: 1221A6101002A500
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156I30C7633981
Coding: 020007020100000001
VCID: 211FE74C91CFAE2FB13-8074
Part No SW: 4G0 035 746 B HW: 4G0 035 746 B
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 194IZ0C7512711
Coding: 000200000103E0EF45128F1E00000003100001000000000000
VCID: 2615F450F8E14917C41-8072
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9402HM6V
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LIC000BB
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 135
Mileage: 179664 km
Date: 2019.11.29
Time: 14:55:12
Voltage: 11.80 V
01524 - Antenna for Telephone
Reset counter: 96
Mileage: 179664 km
Date: 2019.11.26
Time: 00:23:52
Voltage: 12.20 V
Component: TSG HL H03 0506
VCID: 49CF5FEC49BF466F093-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J28G232
Coding: 1080004
VCID: 2615F450F4E14917C41-8072
Component: TSG HR H03 0506
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Shop #: WSC 46128 001 1048576
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F170CC1AF1EAF213-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 12.2V/12.0V)-----------
