Results 1 to 9 of 9
Thread: Audi RS4 B7 tracktool : try to remove airbag and tpms
    Jul 2020
    France
    Hello all,
    we are modifying an Audi RS4 B7 for track use only. The car is completely empty, airbags are all removed , also crash detector in the doors.
    We try to remove the airbag ecu and also want to not have the airbag light on the dash.
    We tried to modifiy motor ecu coding to remove airbag but the process is rejected for this change.
    And we also tried to remove the tpms ecu, but when it is disconnected, the tire pressure light is on on the dash. And when tpms ecu is connected, there is an error message from tpms because there are no pressure valves in the wheels.
    Is it possible to remove correctly both ecu and to not have error message or lights on the dash ?
    Many thanks to everyone that can help.
    Airbag: Doubtful. These cars were never sold without airbags, so why would there be a an option to remove them completely?
    TPMS: Probably.
    Please post an Auto-Scan for context.
    Jul 2020
    France
    Thanks Uwe for your help.
    To remove Airbag I used the long coding help tool that gives the opportunity to uncheck the airbags and modify the motor ecu coding...
    Here is the full auto-scan from yesterday
    Dimanche,12,Juillet,2020,18:14:56:41588
    VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
    Version VCDS: FRM 20.4.1.3
    Version données: 20200331 DS317.0
    www.rosstech.fr
    VIN: WUAZZZ8E27N907835   Plaque d'immat.:
    Kilométrage: 168190km   Ordre réparation::
    Type chassis: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scanner: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
              67 69 75 76 77
    VIN: WUAZZZ8E27N907835   Kilométrage: 168190km
    Adresse 01: Moteur        Labels:. 079-910-560-BNS1.lbl
       No. pièce Log: 8E1 910 560     Mat: 8E1 907 560
       Pièce: 4.2L V8/4V FSI     ª0080
       Révision: --H15---    No. de série: XXXXXXXXXXXXXX
       Codage: 010C0003180F0160
       No. Atelier: WSC 00000 780 00200
       VCID: 63CEBE43A2F7CC9E75-8036
    2 Codes défaut trouvés:
    049412 - Régulateur de vitesse
                   U0104 - 008 - Aucune communication
                 Capture:
                        Etat du défaut: 01101000
                        Priorité du défaut: 0
                        Fréquence du défaut: 1
                        Compteur de RAZ: 255
                        Kilométrage: 168198 km
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: 24.0°C
                        Température: 32.0°C
                        Press. Absolue: 1000.0 mbar
                        Tension: 12.573 V
    049446 - Transmetteur d'angle de braquage
                   U0126 - 008 - Aucune communication
                 Capture:
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: 24.0°C
                        Température: 32.0°C
                        Tension: 12.573 V
    Tests passés: 0110 1100
    Adresse 03: Freins ABS        Labels: 8E0-910-517.clb
       No. pièce Log: 8E0 910 517 G    Mat: 8E0 614 517 BD
       Pièce: ESP8 quattro    H06 0150
       Révision: 00000000    No. de série: 00000000000000
       Codage: 0004533
       No. Atelier: WSC 06335 000 00000
       VCID: 2B5E16638AA744DE8D-807E
    4 Codes défaut trouvés:
    01826 - Transmetteur d´angle de braquage (G85):alim. en courant borne 30
                 Capture:
                        Etat du défaut: 00100000
                        Priorité du défaut: 3
                        Fréquence du défaut: 10
                        Compteur de RAZ: 40
                        Heure: 0
                 Capture:
                        Valeur hex: 0x0000
                        Valeur hex: 0x4202
                        Valeur hex: 0x0024
                        Valeur hex: 0x01A1
                        Valeur hex: 0x0001
    00493 - Unité de capteurs ESP (G419)
                008 - Signal Implausible - Intermittent
                 Capture:
                        Etat du défaut: 00101000
                        Priorité du défaut: 2
                        Fréquence du défaut: 2
                        Compteur de RAZ: 39
                        Heure: 0
                 Capture:
                        Valeur hex: 0x0200
                        Valeur hex: 0x4202
                        Valeur hex: 0x001B
                        Valeur hex: 0x34AB
                        Valeur hex: 0x0001
    01321 - Calculateur d´airbag (J234)
                004 - Aucun(e) signal / communication - Intermittent
                 Capture:
                        Etat du défaut: 00100100
                        Priorité du défaut: 1
                        Compteur de RAZ: 40
                        Heure: 0
                 Capture:
                        Valeur hex: 0x0000
                        Valeur hex: 0x4200
                        Valeur hex: 0x0013
                        Valeur hex: 0x1698
                        Valeur hex: 0x0001
    00778 - Transmetteur d´angle de braquage (G85)
                 Capture:
                        Etat du défaut: 01100100
                        Compteur de RAZ: 40
                        Heure: 0
                 Capture:
                        Valeur hex: 0x0000
                        Valeur hex: 0x4202
                        Valeur hex: 0x001E
                        Valeur hex: 0x4398
                        Valeur hex: 0x0001
    Adresse 08: Climatronic        Labels: 8E0-820-043.lbl
       No. pièce: 8E0 820 043 BM
       Pièce:   A4 Klimaautomat   3233
       Codage: 00001
       VCID: 6DDAD87B27338AEED3-513C
    8 Codes défaut trouvés:
    00716 - Servomoteur de volet d´air recyclé (V113)
                41-10 - Bloque ou n´est pas sous tension - Intermittent
    01273 - Soufflante d´air frais (V2)
                53-10 - Alimentation en tension trop faible - Intermittent
    01172 - Détecteur de température sur le siège du conducteur (G59)
                30-00 - Rupture/c.c. au pôle +
    01171 - Détecteur de température -siège du passager AV (G60)
    00819 - Transmetteur de haute pression (G65)
                07-10 - Signal trop bas - Intermittent
    00532 - Tension d´alimentation
    00466 - Calculateur pour électronique de colonne de direction (J527)
                49-00 - Absence de communication
    01206 - Signal de période de coupure de l´allumage
                27-00 - Signal Implausible
    Adresse 11: Moteur II        Labels:. 079-910-560-BNS2.lbl
    5 Codes défaut trouvés:
    008344 - Banc2 correction lambda derrière cata > limite de régu. en pauvreté
                   P2098 - 002 -  - Intermittent
                 Capture:
                        Etat du défaut: 00110010
                        Kilométrage: 166415 km
                        Heure: 0
                 Capture:
                        Tr/min: 2691 /min
                        Charge: 17.2 %
                        Vitesse: 103.0 km/h
                        Température: 89.0°C
                        Température: 33.0°C
                        Tension: 13.716 V
    005634 - Alim. en tension borne 30 Tension trop faible
                   P1602 - 002 -  - Intermittent
                 Capture:
                        Etat du défaut: 00100010
                        Kilométrage: 0 km
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: -40.0°C
                        Press. Absolue: 0.0 mbar
                        Tension: 0.000 V
    049489 - Calculateur d'airbag
                   U0151 - 008 - Aucune communication - Intermittent
                 Capture:
                        Kilométrage: 0 km
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: 62.0°C
                        Température: 53.0°C
                        Tension: 12.319 V
                 Capture:
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: 22.0°C
                        Température: 25.0°C
                        Tension: 12.446 V
                 Capture:
                        Heure: 0
                 Capture:
                        Tr/min: 0 /min
                        Charge: 0.0 %
                        Vitesse: 0.0 km/h
                        Température: 22.0°C
                        Température: 26.0°C
                        Tension: 12.446 V
    Adresse 15: Airbags        Labels: 8E0-959-655-94.lbl
       No. pièce Log: 8E0 959 655 G    Mat: 8E0 959 655 G
       Pièce:    Airbag 9.41  H13 4230
       Révision: 91H13423    No. de série: 0036M0G80B6T
       Codage: 0430612
       VCID: 3B7E26237AC7D45E1D-806E
       Sous-système 1 - No. de série: 633  RB4        4
       Sous-système 2 - No. de série: 634  RB4        5
       Sous-système 3 - No. de série: 6352ARB4025454E0G
       Sous-système 4 - No. de série: 636  RB4        7
       Sous-système 5 - No. de série: 63729RB4025ACCAD4
       Sous-système 6 - No. de série: 63829RB4025AB8C9+
    11 Codes défaut trouvés:
    01222 - Détecteur de collision d´airbag latéral côté passager avant (G180)
                011 - Coupure - Témoin allumé
                 Capture:
                        Etat du défaut: 11101011
                        Heure: 0
    01221 - Détecteur de collision d´airbag latéral côté conducteur (G179)
                 Capture:
                        Heure: 0
    01217 - Détonateur d´airbag latéral côté conducteur (N199)
                001 - Valeur limite supérieure dépassée - Témoin allumé
                 Capture:
                        Etat du défaut: 11100001
                        Heure: 0
    01218 - Détonateur d´airbag latéral côté passager AV (N200)
                 Capture:
                        Heure: 0
    00588 - Détonateur d´airbag (côté conducteur) (N95)
                 Capture:
                        Heure: 0
    01587 - Détonateur 2 d´airbag côté conducteur (N250)
                 Capture:
                        Heure: 0
    01589 - Détonateur d´airbag rideau côté passager AV (N252)
                 Capture:
                        Heure: 0
    01588 - Détonateur d´airbag rideau côté conducteur (N251)
                 Capture:
                        Heure: 0
    00589 - Détonateur 1 d´airbag (côté passager AV) (N131)
                 Capture:
                        Heure: 0
    00590 - Détonateur 2 d´airbag (côté passager AV) (N132)
                 Capture:
                        Heure: 0
    01639 - Capteur de collision pour airbag latéral AR côté passger (G257)
                 Capture:
                        Heure: 0
    Adresse 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       No. pièce Log: 8E0 920 932 B    Mat: 8E0 920 932 B
       Pièce: KOMBI+WFS 4     H10 0100
       Révision: 0100        No. de série: 00000000000000
       Codage: 0023108
       No. Atelier: WSC 27580 002 104857
       VCID: 2854E96F98516FC660-513C
    01304 - autoradio
    01300 - Calculateur pour système de navigation avec lecteur de CD (J401)
    Adresse 25: Anti-démarrage        Labels: 8E0-920-9xx-8EC.lbl
       Codage: 0023108
    01304 - autoradio
    Adresse 55: Portée des feux        Labels: 8P0-907-357.lbl
       No. pièce: 8P0 907 357 F
       Pièce: Dynamische LWR  H02 0010
       Révision: 00000001    No. de série:
       Codage: 0000005
       VCID: 3D7A283B64D3DA6E23-8068
    00446 - Limitation du fonctionnement due à une sous-tension
                002 - Limite inférieure non atteinte - Intermittent
                 Capture:
                        Fréquence du défaut: 0
                        Compteur de RAZ: 23
                        Heure: 0
                004 - Aucun(e) signal / communication - Témoin allumé
                 Capture:
                        Etat du défaut: 11100100
                        Compteur de RAZ: 0
                        Heure: 0
    Adresse 65: Pression pneus        Labels: 8E0-907-273.lbl
       No. pièce Log: 8E0 907 273 A    Mat: 8E0 907 273 A
       Pièce: Reifendruck 3   H04 0130
       Codage: 0022523
       No. Atelier: WSC 02197 785 00200
       VCID: 2A501367865D5DD676-515A
    00456 - Calculateur pour accès et autorisation de démarrer (J518)
                 Capture:
                        Fréquence du défaut: 5
                        Compteur de RAZ: 40
                        Heure: 0
                 Capture:
                        (sans unité): 0.0
                        Tension: 12.60 V
                        (sans unité): 33.0
                            non détecté
                            non détecté
                            non détecté
                            non détecté
    01521 - Capteur de pression de pneu
                 Capture:
                        Compteur de RAZ: 40
                        Heure: 0
                 Capture:
                        (sans unité): 124.0
                        Tension: 13.60 V
                        (sans unité): 61.0
                            non détecté
                            non détecté
                            non détecté
                            non détecté
    Adresse 76: Aide au stationnt        Labels: 8E0-919-283-8EC.lbl
       No. pièce Log: 8E0 919 283 E    Mat: 8E0 919 283 E
       Pièce: Parkhilfe 8-Kan H06 0010
       Révision: 00H06000    No. de série: 00067802120711
       Codage: 0000114
       VCID: 32600B07AE8D1516CE-513C
    Fin-------------------------(Temps écoulé: 06:22)--------------------------
    Admin Note: This is an English-language forum. In the future, please post data from the English version of VCDS. You can download it from this page and it will happily coexist on your PC with the translated version you are currently using, thanks!
    Now on to your questions: Airbag and TPMS modules are still present in the car/scan. If this is truly a track car, why have you not physically removed those modules?
    Your instrument cluster has a crude sort of Installation list in Adaptation channels 60 and 61. Please tell us what the current Stored Value is in those channels.
    Jul 2020
    France
    This is truly a track car. If TPMS ecu is connected, there is only "TPMS" displayed on the dash. If I disconnect the ecu, the "empty tire" lamp is always on what is more annoying than just the tpms message.
    For the airbag ecu, no difference between connected or disconnected... But the goal is to also remove it. I thought that it was necessary to have it connected to "disable" it completely with vcds...
    Here the new scan in english with both ecu disconnected:
    Thursday,16,July,2020,18:55:54:41588
    VCDS Version: 20.4.1.0 (x64)
    VIN: WUAZZZ8E27N907835   License Plate:
    Mileage: 168260km-104551mi   Repair Order:
              67 69 75 76 77
    VIN: WUAZZZ8E27N907835   Mileage: 168260km-104551miles
    Address 01: Engine        Labels:. 079-910-560-BNS1.lbl
       Part No SW: 8E1 910 560     HW: 8E1 907 560
       Component: 4.2L V8/4V FSI     ª0080
       Revision: --H15---    Serial number: XXXXXXXXXXXXXX
       Coding: 010C0003180F0160
       Shop #: WSC 12345 780 00200
       VCID: 63CEBE43A2F7CC9E76-8036
    049412 - No Communication with Cruise Control Module
                   U0104 - 008 -  - Intermittent
                        Mileage: 168198 km
                        Load: 0.0 %
                        Temperature: 24.0°C
                        Temperature: 33.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.319 V
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 008 -  - Intermittent
                        Mileage: 168198 km
                        Load: 0.0 %
                        Temperature: 24.0°C
                        Temperature: 33.0°C
                        Voltage: 12.319 V
    012313 - Valve for Exhaust Flap 1 (N321)
                   P3019 - 004 - Open Circuit
                        Mileage: 168198 km
                        RPM: 191 /min
                        Load: 54.1 %
                        Temperature: 19.0°C
                        Temperature: 24.0°C
                        Voltage: 10.541 V
    005495 - Right Engine Mount Solenoid Valve (N145)
                   P1577 - 004 - Open Circuit
                        Fault Frequency: 6
                        Mileage: 168198 km
                        RPM: 191 /min
                        Load: 54.1 %
                        Temperature: 19.0°C
                        Temperature: 24.0°C
                        Voltage: 10.414 V
    049489 - No Communications with Airbag Control Module
                   U0151 - 008 -
                        Fault Status: 01101000
                        Load: 0.0 %
                        Temperature: 15.0°C
                        Temperature: 18.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.446 V
    Readiness: 0000 1000
       Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
       Component: ESP8 quattro    H06 0150
       Coding: 0004533
       Shop #: WSC 06335 000 00000
       VCID: 2B5E16638AA744DE8E-807E
                        Fault Frequency: 13
                        Reset counter: 30
                        Hex Value: 0x0000
                        Hex Value: 0x4202
                        Hex Value: 0x0024
                        Hex Value: 0x01A1
                        Hex Value: 0x0001
                        Reset counter: 29
                        Hex Value: 0x0200
                        Hex Value: 0x4202
                        Hex Value: 0x001B
                        Hex Value: 0x34AB
                        Hex Value: 0x0001
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4000
                        Hex Value: 0x0013
                        Hex Value: 0x1699
                        Hex Value: 0x0001
                        Fault Frequency: 9
                        Reset counter: 40
                        Hex Value: 0x2600
                        Hex Value: 0x4006
                        Hex Value: 0x001E
                        Hex Value: 0x2EAA
                        Hex Value: 0x0001
                        Reset counter: 30
                        Hex Value: 0x0080
                        Hex Value: 0x0702
                        Hex Value: 0x0013
                        Hex Value: 0x8598
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   3233
       Coding: 00001
       Shop #: WSC 06335
       VCID: 6DDAD87B27338AEED0-513C
    8 Faults Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
                41-10 - Blocked or No Voltage - Intermittent
    01273 - Fresh Air Blower (V2)
    01172 - Temperature Sensor; Driver's Heated Seat (G59)
                30-00 - Open or Short to Plus
    01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
    00532 - Supply Voltage B+
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  ECE 0907
       Coding: 11021
       Shop #: WSC 65536
       VCID: 3D7A283B37D3DA6E20-4B18
    02071 - Local Databus
                57-00 - Electric Circuit Failure
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    Address 11: Engine II        Labels:. 079-910-560-BNS2.lbl
       Shop #: WSC 00000 780 00200
    008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
                   P2098 - 002 - Too Lean - Intermittent
                        Mileage: 166415 km
                        RPM: 2691 /min
                        Load: 17.2 %
                        Speed: 103.0 km/h
                        Temperature: 89.0°C
                        Temperature: 33.0°C
                        Voltage: 13.716 V
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
                   U0151 - 008 -
                        Load: 0.0 %
                        Temperature: 15.0°C
                        Temperature: 18.0°C
                        Voltage: 12.319 V
                        Mileage: 168198 km
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 25.0°C
                        Voltage: 12.446 V
                        Mileage: 168198 km
                        Load: 0.0 %
                        Temperature: 22.0°C
                        Temperature: 26.0°C
                        Voltage: 12.446 V
    Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
       Part No: 8E0 953 549 T
       Component: Lenksáulenmodul     0301
       Coding: 06022
       Shop #: WSC 06335
       VCID: 448C5DDF5439ABA66F-4B00
    01426 - Controls in Steering Wheel (E221)
       Part No SW: 8E0 920 932 B    HW: 8E0 920 932 B
       Component: KOMBI+WFS 4     H10 0100
       Revision: 0100        Serial number: 00000000000000
       Coding: 0023108
       Shop #: WSC 27580 002 104857
       VCID: 2854E96F98516FC663-513C
    7 Faults Found:
    01304 - Radio
       Coding: 0023108
    7 Faults Found:
    01304 - Radio
       Part No: 8E0 959 433 CQ
       Component: Komfortgerát T3B    4236
       Coding: 07018
       Shop #: WSC 06335
       VCID: 02009BC70EAD65961D-4B18
       Component: Tõrsteuer.FS BRM 0706
       Subsystem 2 - Part No: 8E1959802G
       Component: Tõrsteuer.BF BRM 0706
    14 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    00962 - Alarm via. Tilt Sensor
                35-00 - -
    01369 - Alarm triggered by Hood Switch
                35-00 - -
                35-00 - -
    01366 - Opened Due to Crash Signal
                36-00 - Open Circuit
    00956 - Key 2
                35-10 - - - Intermittent
    01403 - Glass-Break Sensors; Rear
    01705 - Selection Switch for Mirror-Adjust (E48)
                27-00 - Implausible Signal
    01559 - Drivers Door
                57-10 - Electric Circuit Failure - Intermittent
    01560 - Passenger Door
    01561 - Rear left door
       Part No: 8P0 907 357 F
       Component: Dynamische LWR  H02 0010
       Coding: 0000005
       VCID: 3D7A283B64D3DA6E20-8068
                        Fault Frequency: 0
                        Reset counter: 24
                        Fault Frequency: 0
                        Reset counter: 24
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
       Component: Parkhilfe 8-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802120711
       Coding: 0000114
       VCID: 32600B07AE8D1516CD-515A
    End-------------------------(Elapsed Time: 06:35)--------------------------
    And here the adaptation channels 60 and 61:
    Do I just need to remove the airbag value and tmps value ?
    Many thanks for your help.
  6. #6
    Jul 2020
    France
    So, now I have removed 512 to adaptation 61 value and disconnected ecu and the tpms problem seems to be solved. Many thanks!!!
    I have also removed 16 to adaptation 60. The airbag lamp is still on.
    After that I have disconnected airbag ecu and then I have abs and brake lamp on !
  7. #7
    Jul 2020
    France
    It is really a tracktool, you can trust me ;-)
  8. Likes Boki Ar liked this post
  9. #8
    Yep, if it was mine I would try:
    Subtracting 16 from the value in channel 60, i.e. change it from 1109 to 1093
    Subtracingt 512 from the value in channel 61, i.e. change it from 3843 to 3331
  10. #9
    It seems we got our streams crossed. You posted the last two message while I was composing my previous reply.
    Quote Originally Posted by BPJ MOTORSPORT View Post
    As I said above, "Airbag: Doubtful".
    The individual malfunction lights in the instrument cluster can obviously be killed or hidden with some disassembly and reassembly of the cluster. However I can't think of any solution for messages in the screen.
