Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Programming new remote
    Jul 2020
    Sweden
    I have a new remote key for my audi A2, but I fail to save the key to the position I've chosen. The key is recognised and the position becomes occupied, but the key is not saved. I start the procedure by resetting all adaptations. On group 7 I can successfully read 0000. After the adaptation I can se that the position is occupied, it now states 1000. Pressing the different remote buttons is recognised under group 7, but the remote is not saved. What is wrong?
    Moved to Car Repair Support.
    Jul 2020
    Sweden
    But I believe this might be a bug in the program.
    Jul 2020
    Sweden
    Sunday,05,July,2020,18:24:52:25243
    VCDS Version: 20.4.1.0 (x64)
    VIN: WAUZZZ8ZZ1N029759   License Plate:
    Mileage: 283700km-176283mi   Repair Order:
    Chassis Type: 8Z (8Z - Audi A2 (2000 > 2005))
    Scan: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
    VIN: WAUZZZ8ZZ1N029759   Mileage: 283700km-176283miles
    Address 01: Engine        Labels: 036-906-034-APE.lbl
       Part No: 036 906 034 Q
       Component:  MARELLI 4LV       3720
       Coding: 00051
       Shop #: WSC 02138
       VCID: 204A7A39A0A178862B-4B24
       WAUZZZ8ZZ1N029759     AUZ7Z0Y1658402
    Readiness: 1010 0101
    Address 03: ABS Brakes        Labels: 8Z0-907-379-MK20.lbl
       Part No: 8Z0 907 379 B
       Component: ESP     20    CAN  V015
       Coding: 10758
       Shop #: WSC 02154
       VCID: 4798C1A565CF6FBE8A-4ADA
       Part No: 8Z0 820 043 A
       Component: A2-KLIMAVOLLAUTOMAT 0406
       VCID: 346286690459F426DF-2566
    00818 - Sensor for Evaporator Outlet Temperature (G263)
                30-00 - Open or Short to Plus
    Address 15: Airbags        Labels: 8Z0-959-655.lbl
       Part No: 8Z0 959 655 E
       Component: Airbag Front+Seite 4005
       Coding: 00102
       Shop #: WSC 02152
       VCID: 4E96F4818AB5BEF6C9-5106
    Address 17: Instruments        Labels: 8Z0-920-xxx-17.lbl
       Part No: 8Z0 920 900 A
       Component: W1-KOMBIINSTR. VDO D13
       Coding: 05142
       Shop #: WSC 12701
       VCID: 3778B165152F1F3EFA-5122
    Address 46: Central Conv.        Labels: 8Z0-959-433.lbl
       Part No: 8Z0 959 433 C
       Component: KomfortgerŠt T05    03B1
       Coding: 06720
       Shop #: WSC 02138
       VCID: 4686CCA162C576B671-4ADA
       Component: Z1959001      TűrpteuerFS BR
       Component: Z1959002      TűrpteuerBF BR
    No Faults Found
    End-------------------------(Elapsed Time: 03:58)--------------------------
    Quote Originally Posted by drdanbah View Post
       Coding: 06720
       Shop #: WSC 02138
    No Faults Found
    Interesting. The highlighted part is indicative of a communications error. If you go directly to 46, are the comms stable? Are there any fault codes there?
    Jul 2020
    Sweden
    Stable yes, fault code 01561 - Rear Left Door: Won't De-Safe
    But the door works normally, the deadlock as well.
  7. #7
    Is VCDS configured with WSC, tester number and importer number set?
    Can you try a recode of 0x46-07 to default?
    Are you hitting save in VCDS in adaption of remote new value position if supported?
  8. #8
    Jul 2020
    Sweden
    Yes I can recode to default 0000, by writing to position 5 (there are only 4 positions, so the number 5 is a reset command according to audi repair manual), but not when doing a reset the way ross-tech dictates. Yes I am hitting save, and I can see that the position is occupied from 0000 to 1000. But the key is not saved. Pressing the buttons I get 1,2,3 but the number of keys matched is still 0. VCDS is not configured with any WSC, default value is 0 everywhere.
  9. #9
    This is the first thing I would change - some modules do not accept coding when VCDS uses these values. Change them to something relevant to your country/car - by looking at the values in the modules on the car (shown in the Auto-Scan).
  11. #10
    Jul 2020
    Sweden
    The instructions on the Ross-Tech website doesn't match the audi repair manual; checking Audi A2 forums, there seem to be a general agreement that instructions are wrong. Maybe it's time to update the information. PetrolDave I don't believe your suggestion is correct. VCDS is running in stealth mode. The module is not new, new modules might have a problem accepting 0.
