Skoda Fabia vRS 2006 tdi - 03 ABS Brakes - intermittent connection to module
RallyeSport
Cheltenham, UK
C?ID=238394
I have a Skoda Fabia vRS 1.9 tdi 2006, since the last time I used my VCDS and software updates, I'm finding I can't connect to 03 ABS Brakes as I used to be able to?
I last used VCDS in March, whereby I serviced the car, so I reset the service interval and obviously did an autoscan at the time for good measure as I usually do, I always have the HVAC motor recirc issue, a few of my fellow Fabia owners do, I think its down to a lazy motor?
Anyway, I connected VCDS to the car again last week, to find that VCDS is struggling to connect to the 03 ABS Brakes module, whereby before it was trouble free, last time it brought on the instrument cluster lights for ABS and Traction control when its talking to the module, but this time the lights don't come on at all? VCDS tries to talk to the module, and sometimes successfully connects and reports no faults, then sometime I get no response at all with no report for faults, then sometimes the controller tries a few times (I think 3 failed attempts) and moves on to the next module which is HVAC. If it does connect and reports no faults, right at the last few seconds the ABS/Traction control lights come on and you hear the ABS module humm into life, then once disconnected it stops again?
I've deleted 20.4.1 from my newish Lenovo laptop (windows 10), and reinstalled VCDS and attempted Firmware update, but it said the firmware was up to date. Ive tried deleting and reinstalling numerous times, thinking that there was a corrupt file possibly, and I still have the same issue.
I then used my Samsung Netbook (windows 7 pro), installed VCDS and am still having the same issue, I did buy a short connecting lead from Gendan here in the UK to eliminate possible pin slackness issues, but again has made no difference. Gendan advised me today to tick the "bypass CAN init" box as my car does not use CAN protocol apparently, but this didn't help either.
The only thing I can think of possibly with the car itself, was that I had no choice to go through some standing water after it rained heavily recently, the ABS module is quite high up on the passenger side of the front bulkhead, I went through the water slowly, but like someone has said who is a Skoda mechanic, if there was a fault with the ABS module it would put up all the fault lights up on the instrument cluster, these test and go out as normal when the ignition is turned on, as they always have done. I might this weekend check the ABS module plug, which is under the airbox and have a see if there's been any water ingress and check the wiring run around the general area for issues, to rule the car out.
I tend to think though that the fault might lie with the VCDS software itself? Ive noticed a couple of times VCDS is not responding, almost as if there has been a glitch, when VCDS checks 03 ABS Brakes it labour's in the module quite a long time, whereby say in Airbags it brings the light up on the dash as normal as its communicating, and quickly skips to the next module.
I've included a log to help someone help me possibly?
The following log shows on the first attempt it connects and reports no faults, I delete all codes and try again, this time 03 ABS Brakes doesn't report back the no faults outcome?
Ive been as specific as I can be this first time around, Gendan have been very helpful, encouraging me to report the issue on here.
Cheers Dean
Monday,13,July,2020,17:20:27:46810
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
VIN: TMBWU46Y364636917   License Plate: M30 DSL 13/7/2020
Mileage: 54180km-33665mi   Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU46Y364636917   Mileage: 54180km-33665miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 NJ
   Component: 1,9l R4 EDC G200SG  7331
   Coding: 00102
   Shop #: WSC 13765
   VCID: 6C81C3635F909ACB9F3-4B3C
   TMBWU46Y364636917     SKZ7Z0F3587786
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels:
   VCID: 55F78687EC0A3B0350D-FFFE
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Y0 820 045
   Component: Klimaanlage        X0840
   VCID: 72BDDD1B7DB44C3B55F-50D0
01596 - Motor for Outside/Recirculated Air Flap (V154)
            55-00 - Adaptation Not Successful
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25994
   Shop #: WSC 13765
   VCID: 3C2133236F70CA4B4F3-50D0
   Part No: 1C0 909 601 A
   Component: 0S AIRBAG VW51      0009
   Coding: 12371
   Shop #: WSC 13765
   VCID: 1E65D9ABD9ACB85B417-50D0
Address 17: Instruments        Labels: 6Y0-920-xx3-17.lbl
   Part No: 6Y0 920 943 S
   Component: KOMBIINSTRUMENT VDO V04
   Coding: 28401
   Shop #: WSC 14456
   VCID: 4DC76EE7C4CA73C3E8D-50D0
   Part No: 6N0 909 901
   Component: 003D GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: 70B9D71373B87E2BA3B-50D0
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER VDO V04
   Coding: 28401
   Shop #: WSC 14456
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10120
   Shop #: WSC 13765
   VCID: 6FBBD46F6E8661D3BA1-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 60 Komfortgerát     0002
   Coding: 00018
   Shop #: WSC 13765
   VCID: 3D273E27746AC34378D-4B1E
Address 55: Headlight Range        Labels: 6N0-907-503.lbl
   Part No: 6N0 907 503
   Component: Leuchtweiteregelung 0005
   Coding: 00010
   Shop #: WSC 13765
   VCID: 6C81C3635F909ACB9F3-51A8
End----(Elapsed Time: 02:47, VBatt start/end: 12.5V/12.6V. VIgn 0.0V)------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 55: DTCs cleared
Address 03: DTCs cleared
   Coding: 00102
   Shop #: WSC 13765
Address 03: ABS Brakes        Labels: 6R0-907-37x-ASR80.clb
   Part No SW: 6Q0 907 379 AG    HW: 6Q0 907 379 AG
   Component: MABS 8.0 front  H04 0002
   Shop #: WSC 13765 000 00000
   VCID: 025D8DDB48147CBB45F-50D0
   Coding: 25994
   Shop #: WSC 13765
   Coding: 12371
   Shop #: WSC 13765
   Coding: 28401
   Shop #: WSC 14456
   Coding: 00014
   Shop #: WSC 13765
   Coding: 28401
   Shop #: WSC 14456
   Coding: 10120
   Shop #: WSC 13765
   Coding: 00018
   Shop #: WSC 13765
   Coding: 00010
   Shop #: WSC 13765
End----(Elapsed Time: 02:36, VBatt start/end: 12.6V/12.5V. VIgn 0.0V)------
I can't be certain, but my gut says your ABS module is losing its mind.
It looks like the firmware in your HEX-V2 has not changed since December, so I think we can rule that out. If you wish to try the previous 19.6 Release, I can PM you a link.
RallyeSport
Cheltenham, UK
C?ID=238394
If I go into 03 ABS Brakes module itself and go to output tests, if I press start/stop to test the module I get an error message, I once heard the pump run, But usually only have the abs/traction lights flash quickly on the instrument cluster.
This is the error message which comes up -
“Requirements for output test not met”
Can I go back to an older version?
Cheers Dean
Mike@Gendan
Swansea, UK
C?ID=57030
Is 19.6.2 compatible with the firmware updated in December?
Dean emailed overnight to say on 19.6.2 he can't connect to the engine either.
RallyeSport
Cheltenham, UK
C?ID=238394
As mike at Gendan has said I have uploaded 19.6.2 and found now that I can’t connect to the engine module/ECU either, the problem of erratic comms with abs still exists. Also everything seems slower now too with the software.
Mike has given me a link to 20.4.1 to try later when I’m home from work.
I think though I’m chasing my tail here.
Cheers Dean
Mike@Gendan
Swansea, UK
C?ID=57030
The link was actually 20.4.0, in case it's a bug introduced in 20.4.1 (which is the current release which you've already tried)
RallyeSport
Cheltenham, UK
C?ID=238394
I've now uploaded 20.4.0 and ran autoscan twice now, both times reports back no faults, first time didn't bring up the dashboard ABS/TC lights, second time they came on momentarily as did the humm from the ABS module at the end near when the module disconnected?
its also now talking to the engine ECU, as 19.6.2 didn't possibly due to firmware.
In the past though, like I've now repeated many times to the people ive spoken to, as far as I've always found, VCDS connects to the module and the telltale instrument cluster light comes on, whether it be ABS/TC or airbag, I then feel confident it has connected successfully, this happens randomly with the ABS/TC module.
I enclose a copy of the scan -
Tuesday,14,July,2020,10:44:14:46810
VCDS Version: 20.4.0.1 HEX-V2 CB: 0.4508.4
VIN: TMBWU46Y364636917 Mileage: 54190km-33672miles
Coding: 00102
Shop #: WSC 13765
VCID: 6C81C3635F909ACB9FA-4B3C
Coding: 0002229
VCID: 025D8DDB48147CBB456-50D0
VCID: 72BDDD1B7DB44C3B556-50D0
Coding: 25994
Shop #: WSC 13765
VCID: 3C2133236F70CA4B4FA-50D0
Coding: 12371
Shop #: WSC 13765
VCID: 1E65D9ABD9ACB85B41E-50D0
Coding: 28401
Shop #: WSC 14456
VCID: 4DC76EE7C4CA73C3E84-50D0
Coding: 00014
Shop #: WSC 13765
VCID: 70B9D71373B87E2BA32-50D0
Coding: 28401
Shop #: WSC 14456
Coding: 10120
Shop #: WSC 13765
VCID: 6FBBD46F6E8661D3BA8-50D0
Coding: 00018
Shop #: WSC 13765
VCID: 3D273E27746AC343784-4B1E
Coding: 00010
Shop #: WSC 13765
VCID: 6C81C3635F909ACB9FA-51A8
End----(Elapsed Time: 02:42, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
Mike@Gendan
Swansea, UK
C?ID=57030
I've now uploaded 20.4.1
*20.4.0
If you're not convinced it's connected, maybe try viewing measuring blocks from the wheel speed sensors and drive the car forward?
RallyeSport
Cheltenham, UK
C?ID=238394
My mistake, typed it in wrong.
20.4.0
I will try that later.
With 20.4.1 in output tests I had the error message -
REQUIREMENTS FOR OUTPUT TEST NOT MET.
