Results 1 to 10 of 10
Thread: VW GULF R
    Feb 2020
    Saudi Arabia
    VW GULF R
    HI
    CAN SOMEONE PLEASE TELL ME WHERE IS THE OIL TEMP SENSER
    Wednesday,17,June,2020,11:41:17:48412
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWGR2AU5GW001122   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F A9
    VIN: WVWGR2AU5GW001122   Mileage: 58389km-36281miles
    Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 00000000000000000000
       Shop #: WSC 33675 001 1048576
       ASAM Dataset: EV_ECM20TFS0205G0906259E 001006
       ROD: EV_ECM20TFS0205G0906259E.rod
       VCID: 302C365A6B9E4F06BB-8064
    15170 - Engine Oil Temp. Sensor (G8)
              P0198 00 [109] - Signal too High
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:54
                        Coolant temperature: 93 °C
                        Intake air temperature: 69 °C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 12.265 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 93 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.938 V
                        FAC_TPS_1_SAE: 15.625000 %
                        FUP_H_SAE: 20960.0 kPa
    15171 - Engine Oil Temp. Sensor (G8)
              P0196 00 [047] - Implausible Signal
                        Mileage: 58241 km
                        Date: 2020.06.14
                        Time: 00:28:04
                        Engine speed: 962.25 /min
                        Normed load value: 17.3 %
                        Vehicle speed: 2 km/h
                        Coolant temperature: 67 °C
                        Intake air temperature: 58 °C
                        Voltage terminal 30: 13.691 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: CL
                        T_AST_SAE: 32 s
                        MAP_MES_SAE: 46 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.919 V
                        FAC_TPS_1_SAE: 14.843750 %
                        FUP_H_SAE: 7920.0 kPa
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Fault Frequency: 28
                        Mileage: 58241 km
                        Date: 2020.06.14
                        Time: 00:27:32
                        Engine speed: 959.00 /min
                        Normed load value: 7.5 %
                        Coolant temperature: 63 °C
                        Intake air temperature: 60 °C
                        Voltage terminal 30: 12.070 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                        SEG_AD_MMV_ER_L[3]: 6.5308 ‰
    15364 - Engine Control Module Incorrectly Coded
              P1612 00 [047] - -
                        Mileage: 58241 km
                        Time: 00:00:00
                        Intake air temperature: 61 °C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 0.019 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 0 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 0.000 V
                        FAC_TPS_1_SAE: 0.000000 %
                        FUP_H_SAE: 0.0 kPa
    15343 - Boost Pressure Regulation
              P0299 00 [101] - Control Range Not Reached
                        Mileage: 58260 km
                        Date: 2020.06.14
                        Time: 10:08:56
                        Engine speed: 5291.75 /min
                        Normed load value: 79.6 %
                        Vehicle speed: 173 km/h
                        Coolant temperature: 86 °C
                        Intake air temperature: 64 °C
                        Engine: operating status: PL
                        STATE_BPA[0]: OPM
                        Charge air pressure control valve position: target value: 26.89 %
                        Charge air pressure control valve position: actual value: 25.69 %
                        MAP_MES_SAE: 255 kPa
                        Charge air pressure control valve activation pulse duty factor: -17.20 %
                        Charge air pressure control valve voltage: position closed: 3.6719 V
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H54 4522
       Revision: 06454104    Serial number: TFK01806201748
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDQ250021.rod
       VCID: 1F0EC5E60600C07E12-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 61085000002931
       Coding: 01FA6BA15420296D0778070241C56980D62A94E0E08296F7004200B8C208
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 48DC7EBAF30EE7C683-801C
    8216 - Databus
              [FCAN: Fahrwerk_01 message is not received]
                        Reset counter: 173
                        Date: 2020.06.13
                        Time: 21:52:21
    8314 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [009] - -
              [FCAN: Coding of ESP and TSK does not fit together]
                        Fault Frequency: 29
                        Reset counter: 182
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:24
       Revision: 00021000    Serial number: 0367145610
       Coding: 030C0C
       VCID: 3A381472BDE2855605-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020014200100001005000012101400
       VCID: 6A98E4328DC2F5D6B5-803E
       Geber für Kنltemitteldruck/Kنltemitteltemperatur:
    328964 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Reset counter: 222
                        Mileage: 58355 km
                        Date: 2020.06.16
                        Time: 09:16:48
                        Voltage terminal 30: 13.1 V
                        Outside air temperature: 41.5 °C
                        Interior temperature: 37.3 °C
                        Front air distribution flap: actual value: 24
                        Front air distribution flap: actual value: 0.0 %
                        Front air distribution flap: specified value: 40
    328965 - Motor for Front Air Distribution Flap
              B1091 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 173
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:32
                        Voltage terminal 30: 11.6 V
                        Outside air temperature: 44.0 °C
                        Interior temperature: 30.7 °C
                        Front air distribution flap: specified value: 23
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011512002495
       Coding: 00111A46C24122F30BA44080B10C07081800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 004CA69A9BBE1F860B-8054
       Component: WWS    150420  043 0551
       Serial number:         150424165425
       Component: RLHS  037 0059
       Serial number: S2Y15M05D05H13M40S02
       Coding: 90A8DD
       Serial number: 000000000ZY15089398P
       Serial number: 00000000000032300818
       Sun Roof:
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST000967VH00000
       Coding: 181801
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391512001536
       Coding: 0031151011
       VCID: 3D321F6EACCCB26E20-8068
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0JKV4$
       VCID: 41CA639ED034D68E44-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 002 003 14
       Serial number: 35767000000DA3802F0-
       Subsystem 2 - Part No SW: -----------    HW: 480 002 904 15
       Serial number: 3586700000067C8C7410
       Subsystem 3 - Part No SW: -----------    HW: 480 402 104 15
       Serial number: 3516502B51A87851030
       Subsystem 4 - Part No SW: -----------    HW: 480 402 104 15
       Serial number: 3526502B51A87850B137
       Subsystem 5 - Part No SW: -----------    HW: 480 402 204 15
       Serial number: 3556502C11A8786320A8
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 29041504401217
       Coding: 0410
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 79BACB7EF8644E4E4C-802C
       Part No SW: 5G1 920 758     HW: 5G1 920 758
       Component: KOMBI         304 4310
       Coding: 47AD08182B80000801086A001400000000000000
       VCID: 6C94E22A8736EBE6C7-8038
       Revision: --------    Serial number: 18041510800800
       Coding: 030100042F085900EF00026A1C0F00010001050000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72A8FC52A5123D160D-8026
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150000825150085174
       Coding: 29FFFF
       Serial number: 1788586503
       Serial number: HA1-00017.03.15
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_002.rod
       VCID: 46C07082F91AF1B671-8012
       Revision: 00000000    Serial number: 15000112173004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34243A4A9F867326DF-8060
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 080415BD703583
       Coding: 003E12208000040000001000
       VCID: 42C86C92D532CD965D-8016
       Serial number: 00000000000006083444
       Coding: 110000
              B122D 29 [009] - Signal Implausible
                        Reset counter: 174
                        Mileage: 58241 km
                        Date: 2020.06.14
                        Time: 09:48:25
    65604 - Door Warning Lamp
              B1326 01 [009] - Electrical Failure
                        Reset counter: 173
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:35
       Coding: 0103
       VCID: 373E0D468EF0983EFA-8062
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 170415BDH03441
       Coding: 003E10208C00040000801000
       Serial number: 00000000000005986433
       Coding: 090000
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 217
                        Mileage: 58308 km
                        Date: 2020.06.15
                        Time: 08:51:39
       Coding: 02AA00000B010200
       VCID: 40CC669ADB3EDF864B-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
    5276144 - Power Output Module for Left Headlamp
              C1081 F0 [137] - Not Coded
                        Reset counter: 173
                        Mileage: 58241 km
                        Date: 2020.06.14
                        Time: 00:27:31
    5275220 - Headlight
                        Reset counter: 173
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:44
    5275953 - Power Output Module for Left Headlamp
              C1081 31 [137] - No Signal
                        Fault Frequency: 29
                        Reset counter: 182
                        Mileage: 58241 km
                        Date: 2020.06.13
                        Time: 21:52:44
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 045 D    HW: 5G0 035 045 C
       Component: MU-H-N-RW     H44 0377
       Serial number: A311D0F7513508
       Coding: 0273000CFF00000011110001001800031F0207D40100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 210AC31E3074F68E24-8074
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU3016V3
       Subsystem 2 - Part No SW: V03 959 801 QH    HW: -----------
       Component: ROW 2015  --- 0039
       Component: Gracenote  --- 4006
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 150214200823
       VCID: 2D122F2E7CAC22EE90-8078
    End----(Elapsed Time: 01:57, VBatt start/end: 12.4V/12.2V. VIgn 0.0V)------
    Mar 2019
    Poland
    The temperature and oil level sensor is from the bottom of the oil pan.
    Feb 2020
    Saudi Arabia
    so they are the same sensor?
    Subscription to www.partslink24.com or see your dealer.
    Aug 2016
    Eindhoven, NB, NL
    Number 1:
  6. Likes Jack@European_Parts, Uwe liked this post
    HQ
    #1? Any newbie can clearly see that is N 015 082 10, a standard M6 shouldered hex nut. I mean, what are we-- to believe that this is some sort of a--a magic nut or something? Boy, I really hope somebody got fired for that blunder.
    Item #2, part number 03F 907 660 E as per Partslink24.com.
    Jef
  8. Likes Jack@European_Parts, Uwe, myounus liked this post
    Aug 2016
    Eindhoven, NB, NL
    Jef, that typo is on me. Sorry
  11. #8
    Quote Originally Posted by Maher-audi-shop View Post
    What has happened to your Engine Coding
  12. #9
    Feb 2020
    Saudi Arabia
  13. #10
    I'm 99.99999999% sure the engine coding shouldn't be all zeroes - fix that and maybe(?) the oil temp sensor DTC will go away...
  14. Likes myounus, Uwe liked this post
