MK5 golf gt ABS coding ESP MK60EC1
Allyn78
C?ID=271977
i have a mk5 golf 1K 1.4 gt the abs and the traction control light is on scaned it fault code 01042 came up can any one help
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7B022047   Mileage: 147540km-91677miles
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 A    HW: 03C 906 032
   Component: MED17.5.1           9975
   Revision: 96H06---    Serial number: VWZ7Z0F8011583
   Coding: 0000072
   Shop #: WSC 00191 264 15243
   VCID: 1B35BA11DA397A5EF7-804E
Readiness: 0010 0001
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Shop #: WSC 01316 785 00200
   VCID: 74E7B1ADD727952616-8020
                    Reset counter: 25
                    Count: 3
                    Count: 4608
                    Count: 195
                    Count: 49408
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 77FD86A10651FE3E33-8022
   Revision: 00H54000    Serial number: 00000008510156
   Coding: E58D8F2700041532471400001400000000087F075C000100000000000000
   Shop #: WSC 12345 785 00200
   VCID: 336572B152A9D21ECF-8066
   Component: Wischer 280508 021  0501
   Coding: 00038805
   Shop #: WSC 12345
   Component: RLS     120608 054  0402
   Coding: 00209069
   Shop #: WSC 12345
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD21ZD6K
   Coding: 0013112
   Shop #: WSC 01373 785 00200
   VCID: 3D71548964ED146E29-8068
   Subsystem 1 - Serial number: 6332MSME25754E68M
   Subsystem 2 - Serial number: 6342MSME2D21083FG
   Subsystem 3 - Serial number: 6352QSME6E5C3833V
   Subsystem 4 - Serial number: 6362QSME62711A15B
   Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
   Coding: 0000012
   Shop #: WSC 01392 785 00200
   VCID: 73E5B2B11229921E0F-8026
   Part No SW: 1K0 920 963 D    HW: 1K0 920 963 D
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F8011583
   Coding: 0003403
   Shop #: WSC 00526 210 56162
   VCID: 2D5164C9B48D84EE99-8078
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 300508F1000849
   Coding: E9807F060002020003
   VCID: 35614CA95CDDCC2EE1-8060
   Component: IMMO            VDD 1610
   Shop #: WSC 00712 210 87494
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 1K0 959 701 AK    HW: 1K0 959 701 AK
   Component: Tuer-SG         006 1204
   Coding: 0000692
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A5B6FD5856393D67C-807E
   Coding: 999002005103087F2D04840570085FC690FCA0
   Shop #: WSC 00056 210 70964
   VCID: 0305E2714289A29E1F-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Component: Tuer-SG         006 1220
   Coding: 0000692
   VCID: 3979409970C5284E05-806C
   Part No: 1K0 035 186 AF
   Component: Radio GR0       035 0034
   Revision: 0003505S    Serial number: VWZ2Z2H1134442
   Coding: 0040400
   VCID: 6ADBAFD545E353D6BC-803E
00856 - Radio Antenna
   Component: Tuer-SG         006 1302
   Coding: 0000144
   Shop #: WSC 01392 785 1012552
   VCID: 387F459D4BCF3146FA-806C
   Part No SW: 5K0 959 704     HW: 5K0 959 704
   Component: Tuer-SG         007 2106
   Coding: 0000144
   VCID: 72EBB7B56D339B1604-8026
End-------------------------(Elapsed Time: 01:42)--------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Based on VIS:
The following code has been computed for the control unit MK60EC1: 113B200D092400FC881B04E8902000413000
Allyn78
C?ID=271977
how do i enter that code?
thanks
Allyn78
C?ID=271977
entered that code in the car but it refused it even tried the orignal coding that i found but that
was refused
the car had is a1.4 gt 140bhp and i bought a set of clocks ignition ,engine ecu for a 170 bhp car the car runs but the abs problem came up
Can't do that.... Install correct parts for PC configuration.
Allyn78
C?ID=271977
what do you mean the pc configuration
Allyn78
C?ID=271977
so to fit this ecu what else do i need i have complete car
See Audi dealer, authorized agent or become one.
ERWIN has a portal to let you know what is required for independent service pools.
