Moving to get this back on the road after sitting outside in the North East for 6 years.
Per the scan and reviewing the youtube link below, I believe I have an issue with communication regarding the ABS module and / or fusebox / or grounding, and am looking for confirmation on a direction to take in further troubleshooting the issue, if possible, or replacing suspected parts.
Regarding this topic, I have the following to add: ABS light on, "brake" light flashing, steering light, 3 audible beeps on start, no speedometer movement, and limited power steering.
https://www.youtube.com/watch?v=4XOgCvLS_pQ
I believe I also have other issues with sensors: MAF and engine coolant, but am looking for confirmation.
Saturday,04,July,2020,14:27:30:52382
VCDS Version: 17.1.3.0 (x64)
VIN: WVWAB71K28W058160 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAB71K28W058160 Mileage: 93940km-58371miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine (CBU) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 BH HW: 07K 906 032 Q
Component: 2,5l R5/4V G 1566
Revision: 1NH01--- Serial number: VWX7Z0G63N383C
Coding: 0000001
Shop #: WSC 65728 1018 854933
VCID: 70EF2C4C636F8DC119-FFFE
8 Faults Found:
P0300 - 002 - - Intermittent
Mileage: 93944 km
Time: 04:53:10
RPM: 671 /min
Load: 16.5 %
Temperature: 80.0°C
Temperature: 30.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.081 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected - Intermittent
Mileage: 93944 km
Time: 04:53:10
000773 - Cylinder 5
P0305 - 002 - Misfire Detected - Intermittent
Mileage: 93944 km
Time: 04:53:18
RPM: 687 /min
Load: 16.1 %
Temperature: 81.0°C
Temperature: 30.0°C
Voltage: 13.081 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Mileage: 93944 km
Time: 04:53:18
049441 - No Communication with ABS Brake Control Module
U0121 - 008 -
Mileage: 93944 km
Time: 04:53:18
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 002 - Signal too High - Intermittent
Mileage: 93944 km
Time: 04:53:18
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent - MIL ON
Mileage: 93944 km
Time: 04:53:18
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent - MIL ON
Mileage: 93944 km
Time: 04:53:18
Readiness: N/A
Address 03: ABS Brakes
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6ED33234795B9B310B-803A
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01316 - ABS Control Module
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 01000007210321
Coding: 008D0F214004150047140000001400000008730B5C000100000000000000
Shop #: WSC 01287 785 00200
VCID: 6FED2F307E51923900-803A
Component: Wischer 070707 021 0501
Coding: 00038805
Shop #: WSC 01287
10 Faults Found:
Fault Status: 01111100
Reset counter: 109
Mileage: 93947 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
Reset counter: 109
Mileage: 93947 km
Date: 2005.09.13
Time: 31:63:63
Fault Status: 01101100
Reset counter: 109
Mileage: 93943 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.25 V
Reset counter: 109
Mileage: 93943 km
Date: 2005.09.13
Time: 31:63:63
00532 - Supply Voltage B+
Reset counter: 149
Mileage: 93944 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 8.60 V
010 - Open or Short to Plus
Reset counter: 149
Mileage: 93944 km
Date: 2005.09.13
Time: 31:63:63
Fault Status: 01101010
Reset counter: 109
Mileage: 93947 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.25 V
Reset counter: 109
Mileage: 93947 km
Date: 2005.09.13
Time: 31:63:63
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 136
Mileage: 93944 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 9.50 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 136
Mileage: 93944 km
Date: 2005.09.13
Time: 31:63:63
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0933LQ
Coding: 0013899
Shop #: WSC 01269 785 00200
VCID: 6CD7383C4F47692125-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME186022583
Subsystem 3 - Serial number: 6342MSME1C363359E
Subsystem 4 - Serial number: 6352QSME314242632
Subsystem 5 - Serial number: 6362QSME31462757D
Subsystem 6 - Serial number: 63727SME0D492E1FI
Subsystem 7 - Serial number: 63827SME0E112408Y
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
010 - Open or Short to Plus - Intermittent - MIL ON
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000022
VCID: 74E7205C1777B1E1FD-8020
015 - Cannot Be Tested at this Time - MIL ON
Part No SW: 1K0 920 954 F HW: 1K0 920 954 F
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G63N383C
Coding: 0007203
VCID: 2F6DEF30BED1D23940-807A
Fault Frequency: 13
Reset counter: 149
Mileage: 93944 km
Time: 06:29:52
Reset counter: 148
Mileage: 93944 km
Time: 06:38:16
Reset counter: 148
Mileage: 93944 km
Time: 06:38:16
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 040707F2001362
Coding: 3D8F034007000000
Reset counter: 109
Mileage: 93947 km
Time: 17:59:28
Reset counter: 147
Mileage: 93945 km
Time: 00:01:19
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.clb
Component: Tuer-SG 006 120A
Coding: 0001077
VCID: 387FD46C4B9F158111-806C
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561DD585C8DE8E90A-8060
00625 - Vehicle Speed Signal
Mileage: 93930 km
Temperature: 26.0°C
Voltage: 11.90 V
Voltage: 11.70 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Coding: 139006885103083F0004058FB0080A04889C80
VCID: 0407709C47D78161CD-8050
Reset counter: 136
Mileage: 93944 km
Time: 06:38:53
00830 - Convertible Top Control Module (J256)
Fault Frequency: 6
Reset counter: 148
Fault Frequency: 6
Reset counter: 148
Reset counter: 109
Mileage: 93947 km
Time: 18:24:57
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.clb
Coding: 0001076
VCID: 3979D16870950C89EE-806C
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6258206
Coding: 0040401
VCID: 1F4D1FF0CE7142B9F0-804A
Component: RDK 0450
Coding: 0100101
008 - Implausible Signal
Fault Status: 01111000
Reset counter: 109
Mileage: 93947 km
Time: 17:59:27
End-------------------------(Elapsed Time: 01:41)--------------------------
