Can 07 R32 Climatronic unit be programmed for 07 EOS?
bobster
Daytona area, FL, USA
C?ID=406029
Can a 2007 R32 Climatronic unit be programmed for a 2007 EOS? OR is non-compatible? OR is it defective?
The original Clim unit in the EOS was dead, no communication, no A/C, no blower function. Replaced with a "test" unit out of same year EOS but the LCDs are roasted by sun/rain and not viewable nor show any numbers. But it DOES operate as normal otherwise--I just spin the knobs all the way to the left a few rotations and assume it is on "LO". ;) This link will show you what it looks like: debay LINK
Picked up a Clim unit from a 2007 R32 that looked identical with the exception of "OFF" instead of "ON/OFF" and "AC" instead of "ECON". But externally they are identical. It did not have a part number sticker on it nor did the original. Plugged it into the EOS and it powered up and the LCDs, knobs and buttons worked but no air would come out the dash vents even though the fan was working variably as demanded with the knob. Checked module for codes shown below. The full scan following was AFTER I re-installed the "test" unit. The 01320 "no comm" codes cleared out after but were caused by the R32 unit. Noting the part #s, I see they are different... :(
So can the programming in the R32 Clim unit be modded? Or is it non-compatible? Or is it defective?
I took the original dead unit apart to see inside and if maybe I could swap the circuit board from the test unit into the pretty R32 housing but alas, the LCDs are part of the circuit boards. :( Face plates will swap not that I want or need to.
Thank you for your input!
Saturday,11,July,2020,17:22:59:64029
VCDS Version: 20.4.1.0
VIN:    License Plate: EOSAC071120
Address 08: Auto HVAC       Labels: 1K0-907-044.lbl
   Control Module Part Number: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component and/or Version: ClimatronicPQ35 120 1111
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                      VCID: 79F9DC1D30234F4E4C-802C
01273 - Fresh Air Blower (V2)
Sunday,12,July,2020,01:11:37:64029
VIN: WVWAA71F37V045539   License Plate: EOS071220
Mileage: 197220km-122546mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63 65
          72
VIN: WVWAA71F37V045539   Mileage: 197220km-122546miles
08-Auto HVAC -- Status: Sporadic communication error 1000
0F-Digital Radio -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: OK 0000
   Part No SW: 1Q0 907 115 E    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G23NG7QY
   Coding: 041C010A18070160
   Shop #: WSC 05073 444 60913
   VCID: 2E533F41B9ED58F6A9-807A
005425 - Camshaft Timing Adjustment
               P1531 - 004 - Open Circuit - MIL ON
                    Fault Status: 11100100
                    Mileage: 197223 km
                    Time: 07:58:08
                    RPM: 1243 /min
                    Load: 25.1 %
                    Temperature: 39.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.811 V
Readiness: 0110 0101
   Revision: 00H11001
   Coding: 0021218
   Shop #: WSC 00020 000 00000
   VCID: 73E5EE35124F351E06-8026
00493 - ESP-Sensor Unit (G419)
            014 - Defective
   Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: 2B5536558AFF2DDE8E-807E
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006783821
   Coding: 058C8F0340041500470000000F00000000285D035C0001
   VCID: 6CD7F5494F71EAE6C7-8038
   Component: Wischer 270307 020  0501
   Coding: 00038805
   Shop #: WSC 00020
00061 - Footwell Lights
                    Reset counter: 82
                    Mileage: 197223 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.75 V
00156 - Control Circuit for Windshield Washer Pump
                    Fault Status: 01101001
                    Reset counter: 82
                    Mileage: 197223 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.75 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 82
                    Mileage: 197223 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.75 V
                    Reset counter: 122
                    Mileage: 197223 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.75 V
Address 0F: Digital Radio
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 74 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B3001R4W
   Coding: 0014132
   VCID: 3A7B031175A5845605-806E
   Subsystem 1 - Serial number: 6332SRB404DD4D2FJ
   Subsystem 2 - Serial number: 6342SRB404DA4FADP
   Subsystem 3 - Serial number: 6372URB40203B8993
   Subsystem 4 - Serial number: 6382URB40203B8C53
02511 - Control Module for Seat Occupied Recognition (J706)
                    Fault Frequency: 12
                    Mileage: 197223 km
                    Time: 11:07:58
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Fault Status: 11101010
                    Mileage: 197223 km
                    Time: 11:08:00
00592 - Seat Belt Switch; Passenger (E25)
                    Mileage: 197223 km
                    Time: 11:08:00
                    Fault Status: 11100001
                    Mileage: 197223 km
                    Time: 11:08:00
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0000041
   VCID: 000FB1F953F91E860B-8054
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWX7Z0G23NG7QY
   Coding: 0023207
   VCID: 326B2B31ADD57C16CD-8066
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 33001073080C13
   Coding: 3DBF23600F025000
   Shop #: WSC 00020 999 00000
   VCID: 2F6D2245BEE751FEA2-807A
02649 - Digital Radio Tuner
                    Reset counter: 81
                    Mileage: 197223 km
                    Time: 11:08:03
                    Reset counter: 122
                    Mileage: 197223 km
                    Time: 06:56:45
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TK85W02
   Component: IMMO            VDD 1610
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 G    HW: 1Q0 959 255 G
   Component: Verdecksteuergeraet 0860
   Revision: 0033100R    Serial number: 141210099
   Coding: 0655360
   Shop #: WSC 55552 001 1048576
   VCID: 3C7705097F91BA6617-8068
   Part No SW: 1Q0 959 701 D    HW: 1Q0 959 701 D
   Component: Tuer-SG         006 1209
   Coding: 0001207
   VCID: 3561102D5CBB6B2EE8-8060
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   VCID: 34672D2957C17226DF-8060
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 0407BDE947E102A62F-8050
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Component: Tuer-SG         006 1215
   Coding: 0001206
   Shop #: WSC 00020 790 00000
   VCID: 377D1A2546B7993EFA-8062
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0023
   Revision: 00017000    Serial number: VWZ5Z7G2141368
   Coding: 0040401
   VCID: 2447DD69E721E2A64F-8070
02218 - Satellite Radio (R146)
                    Fault Status: 01110100
                    Reset counter: 81
                    Mileage: 197223 km
                    Time: 11:08:05
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1203
   Coding: 0000128
   Shop #: WSC 00020 000 1012544
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Coding: 0100101
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
   Shop #: WSC 00020 790 1012544
            014 - Defective
End-------------------------(Elapsed Time: 02:06)--------------------------
NZDubNurd
New Zealand
C?ID=230482
I don't know if the ECON/AC changeover point tied in, but the earlier climatronic units were designed to run a heater box with two motors to control the recirc flaps (X2). Later units used one motor to control the flaps (x2).
One of these flaps controls the air flow from outside, and one controls the flow from inside the car (recirc)
One of my motors failed, and the outside air flap wouldn't open, so the fan would run, but there was no flow, unless I turned the recirc on. With re-circ off, both flaps stayed closed and blocked all flow.
Your best best is to find a Climatronic panel from an earlier car. I suspect the R32 in the US would have actually been a 2008 model year, hence the change to AC from ECON.
You may be able to frankenstein the units, but the controls and software would probably need to remain from your EOS panel with he faulty LCDs.
bobster
C?ID=406029
I believe you are correct, Allan. :) The following is from the 2004 Golf HVAC manual, 04.2015 edition:
"7 - Vehicles through 04/2007 Recirculation Door Motor - V113- , from 05/2007 the Recirculation Door Motor -
V113- is Discontinued...
8 - Vehicles through 04/2007 Air Flow Door Motor - V71- ; from 05/2007 Fresh Air/Recirculating Air/Back Pressure
Door Motor Position Sensor - V425-
So you know anyone looking for a Climatronic unit? :D It IS in very nice condition. I'm in FL if you have any US mates looking. It is dated 08.06.07. rev 00120021, mfg 0155
I would still consider reprogramming if possible... PS: thinking about, it may not even have the control circuitry for the old-style "extra" motor... :(
siLc
Tallinn, Estonia
C?ID=330192
If the test unit was operational otherwise, you can try swapping (desolder-solder) the displays from your old unit to the test unit.
