Automatic headlight
drdanbah
Sweden
C?ID=124310
Hi I have an imported audi A2 from Germany. In Sweden it's mandatory with headlight on all the time. Is it possible to code that? I have to turn the switch manually
PetrolDave
Westbury, UK
C?ID=1423
A full unedited Auto-Scan of your A2 would be needed to answer your question... see my sig for a link to a How-To
drdanbah
Sweden
C?ID=124310
Sunday,05,July,2020,18:24:52:25243
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8ZZ1N029759   License Plate: SED329
Mileage: 283700km-176283mi   Repair Order:
Chassis Type: 8Z (8Z - Audi A2 (2000 > 2005))
Scan: 01 02 03 08 15 16 17 18 37 45 46 56 57 75 76 77
VIN: WAUZZZ8ZZ1N029759   Mileage: 283700km-176283miles
Address 01: Engine        Labels: 036-906-034-APE.lbl
   Part No: 036 906 034 Q
   Component:  MARELLI 4LV       3720
   Coding: 00051
   Shop #: WSC 02138
   VCID: 204A7A39A0A178862B-4B24
   WAUZZZ8ZZ1N029759     AUZ7Z0Y1658402
Readiness: 1010 0101
Address 03: ABS Brakes        Labels: 8Z0-907-379-MK20.lbl
   Part No: 8Z0 907 379 B
   Component: ESP     20    CAN  V015
   Coding: 10758
   Shop #: WSC 02154
   VCID: 4798C1A565CF6FBE8A-4ADA
   Part No: 8Z0 820 043 A
   Component: A2-KLIMAVOLLAUTOMAT 0406
   VCID: 346286690459F426DF-2566
00818 - Sensor for Evaporator Outlet Temperature (G263)
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 8Z0-959-655.lbl
   Part No: 8Z0 959 655 E
   Component: Airbag Front+Seite 4005
   Coding: 00102
   Shop #: WSC 02152
   VCID: 4E96F4818AB5BEF6C9-5106
Address 17: Instruments        Labels: 8Z0-920-xxx-17.lbl
   Part No: 8Z0 920 900 A
   Component: W1-KOMBIINSTR. VDO D13
   Coding: 05142
   Shop #: WSC 12701
   VCID: 3778B165152F1F3EFA-5122
Address 46: Central Conv.        Labels: 8Z0-959-433.lbl
   Part No: 8Z0 959 433 C
   Component: Komfortgerát T05    03B1
   Coding: 06720
   Shop #: WSC 02138
   VCID: 4686CCA162C576B671-4ADA
   Component: Z1959001      TõrpteuerFS BR
   Component: Z1959002      TõrpteuerBF BR
No Faults Found
End-------------------------(Elapsed Time: 03:58)--------------------------
I don't think it can be programmed. This car doesn't even have a Central Electric module (which isn't terribly surprising considering it's an economy car designed in the late 90s). This means that the lights aren't computer-controlled. On such cars, permanent DRLs were usually implemented with a wiring change and/or an additional relay.
darkchina811
ITALY
C?ID=333184
here is what I used on old cars to implement Daytime Running Lights (they are on with engine on ONLY), of course it can be adjusted for any load.
https://www.dropbox.com/s/9kzv38lmd2bpv2h/radio.jpg
APERTURA you can omit, together with its diode;
CHIAVE connect to the wire triggering the starter motor;
CHIUSURA connect to Terminal 15 (switched +12V);
+12 connect to Terminal 30 (fused battery power feeding the load);
RADIO is your new output for the load.
