Audi A3 OAM DSG7 Faults: P177C P177B & 00470 Company Comfort Databus
Multitask
Australia
C?ID=272124
Helpppppp,
Purchased this car for my wife, test drove ok. Took it home few days later it would shift from 1st to 3rd perfectly but then just stay in 3rd unless i put in neutral then back to D and it will shift rest of the gears.
I thought maybe changing the oil in the mechatronics and resetting the adaptations using Basic settings 060. What a big mistake it drives really well until about a kilometre, than she starts thumping through the gear changes. Checked faults and it came up with 006012 - Clutch 2 P177C - 003 - Tolerance limit reached and a 00470 - Company comfort databus in a single wire that was there previously and wont clear after numerous resets.
Have tried basic settings group 60 numerous times with no success, will drive fine till about a kilometre or so later during the adaptation test drive.
Is their any way of keeping the adaptation settings from the first kilometre of the drive? gear changes are fine after the group 60 reset but then moments later jerks and thumps in every gear. Have read in other posts possible worn clutches but wouldnt it be slipping if that was the case? Any way of increasing the tolerance in the clutches? is there anyone on the forum that can update the firmware remotely on the OAM gearbox for me? I'm happy to pay...
Please view VCDS scanned data:
Monday,06,July,2020,17:28:20:53481
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8P29A140462   License Plate:
Mileage: 138210km-85879mi   Repair Order:
Gateway Installation List:  1K0 907 530 S
Saturday,11,July,2020,16:37:51:53481
Mileage: 138390km-85991mi   Repair Order:
                Address 19: CAN Gateway       Labels: 1K0-907-530-V4.clb
Control Module Part Number: 1K0 907 530 S    HW: 1K0 907 951
  Component and/or Version: J533__Gateway   H16 0210
           Software Coding: EDA07F06100602001103
            Work Shop Code: WSC 00010 822 175807
                      VCID: 377D4675469D6D3EFA-8062
                    Reset counter: 222
                    Mileage: 138398 km
                    Date: 2020.07.11
                    Time: 16:26:12
Tuesday,07,July,2020,19:07:54:53481
                Address 02: Auto Trans       Labels:
           Software Coding:
            Work Shop Code:
                      VCID: 55A1ECFDBFD1BF2E08-5106
006011 - Clutch 1
               P177B - 003 - Tolerance Limit Reached
                    Fault Status: 01100011
                    Reset counter: 10
                    Mileage: 138251 km
                    Date: 2019.11.16
                    Time: 09:00:58
006012 - Clutch 2
               P177C - 003 - Tolerance Limit Reached
                    Reset counter: 10
                    Mileage: 138256 km
                    Date: 2019.11.16
                    Time: 09:15:25
Please if anyone can help.
Thanks in advance.
PetrolDave
Westbury, UK
C?ID=1423
That's just edited sections of a VCDS Auto-Scan, please just post the complete unedited Auto-Scan (which you will find in C:\Ross-Tech\VCDS\Scans).
Multitask
Australia
C?ID=272124
Hi PetrolDave, thanks for your message please view full scan:
Regarding tiptronic isnt it meant to display what gear you are in on the dash? when i place into tiptronic mode the PRNDS switches off. That fault probably explains why i can only go 1,2 but wont go up anymore, then place into D it changes though in tip tronic most of the time it seems to downshift fine sometimes alittle delayed. when i first bought the car was alittle hard to get the selector into S, but i disconnected the cable on the gearbox moved it to far right and now seems good.
Sunday,12,July,2020,17:31:28:53481
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P29A140462   Mileage: 138470km-86041miles
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 997 016 A    HW: 03C 906 016 F
   Component: MED17.5.5           8016
   Revision: LCH02---    Serial number: AUX7Z0I3FNG033
   Coding: 0000077
   Shop #: WSC 31870 822 92148
   VCID: 275D9635963DFDBE6A-8072
Readiness: 0000 0001
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 13424012512600FAC80F02EA8A1B00803900
   Shop #: WSC 56100 001 1048576
   VCID: 77FD8675C61DAD3E3A-8022
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000854      Serial number: 8P0820043BG
   VCID: 72EBB7616D7FC8160D-8026
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009535628
   Coding: 10AC2F81B0141380EF00001C0000000000084A0564010403002800000000
   Shop #: WSC 06314 000 08192
   VCID: 489F35893B6312C683-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
02389 - Release Signal Transmission; Position P/N
                    Reset counter: 9
                    Mileage: 138450 km
                    Date: 2020.07.12
                    Time: 11:28:00
                    Voltage: 13.80 V
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93630912800814
   Coding: 000103
   Shop #: WSC 72520 812 90802
   VCID: 428B27A1DD5F38965D-8016
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CA0062MW1
   Coding: 303142383038303030374A55305238503053
   Shop #: WSC 06314 000 00000
   ROD: EV_Airba10AURB4.rod
   VCID: 4999308DE869EBCE9C-801C
   Serial number: 3572DRB400008128C29S
   Serial number: 3582DRB400008128D27S
   Serial number: 35128RB400004CA1C07L
   Serial number: 35228RB400004C9C57E$
   Serial number: 35547RB400004CDBEADE
   Serial number: 35647RB400004CDBF081
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0014012
   VCID: 418928AD1859238E44-8014
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
   Component: KOMBIINSTR. VDO H19 0860
   Revision: D0H19007    Serial number: 2243I007051276
   Coding: 0000728
   Shop #: WSC 52642 001 1048576
   VCID: 448721B9074B36A66F-8010
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K0940200E1
   Shop #: WSC 00010 822 175807
                    Fault Frequency: 12
                    Reset counter: 225
                    Mileage: 138450 km
                    Date: 2020.07.12
                    Time: 11:21:53
   Revision: D0H19007    Serial number: AUX7Z0I3FNG033
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000660
   VCID: 438522A50245319E56-8016
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 232    2501
   Revision: 00H15000
   VCID: 2C5769198FDBDEE687-8078
   Part No: 8P0 959 433 L
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C9F0167
   VCID: 45813CBD0C710FAE78-8010
            007 - Short to Ground
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158948921855
   VCID: 36634B7141979436E1-8062
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000660
   Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
   Component: R Concert2+     H04 0270
   Revision: 00H04000    Serial number: AUZ1Z3I9744298
   Coding: 0710211
   VCID: 3F8D2E556EAD557E32-806A
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 428B27A11D5F38965D-8016
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005080055
   Coding: 0001222
   Shop #: WSC 42240 000 1048576
   VCID: 46833BB1317704B671-8012
End-------------------------(Elapsed Time: 02:35)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
Between those 2 scans the problem with #02 is very different - now it cannot even be reached.
I reckon you need to get the WD and check the power, ground and Powertrain CAN connections to the #02 controller first off, until the connection to the #02 are reliable all other debugging is like trying to herd cats.
Multitask
Australia
C?ID=272124
Dave you’re right I never noticed that in the full scan. The thing that doesn’t make sense to me is why in VCDS can I ‘select control module > 02-Auto Trans’ connect to it individually? And view faults or preform a group 60 in basic settings?
Though will check all connections. Need to obtain the WD from somewhere - hopefully google can help.
Thanks again
Multitask
Australia
C?ID=272124
Thanks I’ll register on Erwin.
Dave not sure if I clarified my last post but why can I connect to the Auto Trans module individually?
PetrolDave
Westbury, UK
C?ID=1423
I'll have to leave the real experts to ponder that question :confused:
Multitask
Australia
C?ID=272124
Seems when I do the autoscan and gets to address 2 it times out. When I manually select the module takes a while to respond but finally connects.
siLc
Tallinn, Estonia
C?ID=330192
Check the TCM plug for water ingress and failed connections. It can be found on the gearbox, above the starter.
Multitask
Australia
C?ID=272124
Thanks siLc. Though I did check a while back, the plug and wires all looked intact. If their was a problem with the wiring I wouldn’t be able to connect at all?
It only fails during the Autoscan but individual module connects fine just a little delayed. Maybe a firmware update might help?
MasterTommy
Amsterdam
C?ID=295586
‘Looked okay’, did you actually take the plug out and looked at the terminals on both sides?
Multitask
Australia
C?ID=272124
Tommy, plug and pins looked good as gold with no sign of corrosion. Please view screenshots of when it connects to the trans module:
https://drive.google.com/file/d/1-OSV-zBVqMka01nPKPnzfJTkzEs0QIL1/view?usp=sharing
https://drive.google.com/file/d/104ZzJFTWURahmBmtt-EVjkUe8N_33gFe/view?usp=sharing
https://drive.google.com/file/d/1BSaK8FYO7mD3rFI8bLj47sjwdM0C2Uj6/view?usp=sharing
https://drive.google.com/file/d/17uBkkOSaN792VIrdb8X1R5UGXW7D_iOo/view?usp=sharing
https://drive.google.com/file/d/1EBN4UWaMamyPyG2QYgThKMyw_V-iG9va/view?usp=sharing
https://drive.google.com/file/d/1Dx4_nbLIDURU2VLAAprEiTllAieqN95d/view?usp=sharing
Also please view Advanced ID:
Wednesday,15,July,2020,18:09:29:53481
Mileage: Repair Order: Advanced Identification
Control Module Part Number: 0AM 300 064 H
Component and/or Version: GSG DSG AG7 431 5201
Software Coding: 0000020
Work Shop Code: WSC 00046
VCID: 3365726551E5811EC6-5124
Serial number: CU501405265447
Identification: CU5-001
Revision: 00043014
Date: 26.05.14
Test stand number: 0000
Manufacturer number: 5447
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 100 10500
Flash Date: --.--.--
Software
0001
Misc.
Hardware number: 0AM 927 769 D
Lot Number: D20
Type Lock: 000
VCDS Info:
Labels: 0AM-927-769.clb
-2 successful attempts -Date: 26.05.14: So is this telling us its been flashed twice on that date? or that firmware date?
I still cant work out why in Autoscan it cant connect but in single module it finally does? any ideas guys?
siLc
Tallinn, Estonia
C?ID=330192
There's reason to believe that there is some CAN communications trouble with the TCM. If able and feasible, you could try to obtain a test mechatronic unit - you can plug it in without installing it on the gearbox. If this also doesn't show up on autoscan, then there's a CAN wiring issue somewhere.
I'd think the reason you're able to directly access the TCM is because there's a direct K-line connection from the OBD connector to the TCM.
Multitask
Australia
C?ID=272124
I knew itttt, thanks siLc for verifying. Thing is trying to get a hold of another mechatronic unit :confused:
This problem isn't contributing to those fault codes i have though? or the severe jerking. It is a lot better on take off since I increased the Hillstart aid to 2 in the ABS module though but i need to sort this out first.
