Results 1 to 10 of 20
Thread: ABS CODING 2011 VW JETTA
    Jul 2020
    India
    Dear all,
    please help me to find the ABS module code
    when the ECM fails i changed ECM, INSTRUMENT CLUSTER, & KEY SET, now car runs fine but ABS,TRACTION & HANDBRAKE warning lights are blinking.
    during scanning its showing ABS control module not coded.
    Actual VIN:
    Vehicle Identification No. WVWJ11161CA550977
    Model Jetta
    JE
    Date of production 24.09.2011
    Model year 2012
    Sales type 162462
    7KK Vehicle class differentiation -160-
    Engine Code CLCB
    Transmission Code NFP
    G0K 6-speed manual transmission
    L0R Right-hand drive
    B79 Type approval country India
    1N3 Speed-related variable steering assist (Servotronic)
    0N4 4-link rear suspension
    0YE Weight range 5 installation control only, no requirement forecast
    2UB Heavy-duty version
    1AT Electronic stability control (ESC)
    1ZE Disc brakes in front (Geomet D)
    1KS Disc brakes in rear (Geomet D)
    UG1 Hill start assist
    7K0 Without tyre pressure monitor
    7L3 Without start-stop system without regenerative braking
    7X2 Park distance control in front and rear
    Wrong diagnostic VIN:
    Vehicle Identification No. WVWH101K3AA553074
    Model Jetta
    JE
    Date of production 03.08.2010
    Model year 2010
    Sales type 1K223A
    Engine Code CLCA
    Transmission Code KQM
    Friday,10,July,2020,09:14:55:59768
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    ADDRESS 1
    Friday,10,July,2020,18:19:31:59768
    VCDS Version: Release 20.4.1 (x64)
                    Address 01: Engine
    Control Module Part Number: 03L 906 018 EN
      Component and/or Version: R4 2.0l TDI   H21 9977
               Software Coding: 00110012040500080000
                Work Shop Code: WSC 00046
                          VCID: 7AB81CAFFD36215645-802E
    Advanced Identification/FAZIT
         Identification: BPG-810
         Revision: 42H21---
         Date: 18.05.10
         Manufacturer number: 1236
         Test stand number: 0406
    Flash Status
         Programming Attempts(application): 3/3/3/3
         Successful Attempts(application): 3/3/3/3
         Flash Date: 20.01.29
    Misc.
         Hardware number: 03L 907 309 R
         Workshop System Name: J623
         ASAM Dataset: EV_ECM20TDI01103L906018EN
         ASAM Dataset Revision: 003008
    Car Info
         Chassis Number: WVWH101K3AA553074
         Engine code: CLCA
    VCDS Info:
           Labels: 03L-906-018-CFF.clb
           Readiness: No script available
           ROD: EV_ECM20TDI01103L906018EN.rod
    ADDRESS 17
    Friday,10,July,2020,18:21:04:59768
                    Address 17: Instruments
    Control Module Part Number: 5M0 920 860 E
      Component and/or Version: KOMBI         H05 0308
               Software Coding: 170B00
                Work Shop Code: WSC 73430
                          VCID: 302CFE876BCA2B06BB-8064
         Identification: VD1-048
         Date: 11.05.10
         Manufacturer number: 7392
         Test stand number: 4347
    Flash Status
         Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Programming Status: 00000000
         Flash Date: 00.00.00
    Software
         OSEK-OS: 03.14.00
         HiSpd Net: 01.10.00
    Misc.
         Hardware number: 5M0 920 860 E
         Workshop System Name: J285
         Equipment/PR Code: 2D2D2D2D2D2D2D2D
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: ------------------
         ASAM Dataset: EV_Kombi_UDS_VDD_RM09
         ASAM Dataset Revision: A04052
    Car Info
    VCDS Info:
           Labels: 5K0-920-xxx-17.clb-SRI1
    ADDRESS 25
    Friday,10,July,2020,18:22:06:59768
                    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
      Component and/or Version: IMMO          H05 0308
               Software Coding: 000000
                Work Shop Code: WSC 00000
                          VCID: 6A982CEF8D9691D6B5-803E
         Date: 11.05.10
    Flash Status
    Software
         OSEK-OS: 03.14.00
         HiSpd Net: 01.10.00
    Misc.
         Hardware number: 5K0 953 234
         Workshop System Name: J334
         ASAM Dataset: EV_Immo_UDS_VDD_RM09
         ASAM Dataset Revision: A03005
    Car Info
    Immobilizer
         Transponder ID (Current val.): 2AD8350A
         Transponder ID 1: 6C1444DE
         Transponder ID 2: 6C144084
         Transponder ID 3: 2AD8350A
    VCDS Info:
           Labels: 5K0-920-xxx-25.clb
    This is not a complete auto-scan please post it.
    Please post picture of vin tag in door and dash area.
  3. Likes Uwe liked this post
    Jul 2020
    India
    VIN: WVWH101K3AA553074   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWH101K3AA553074   Mileage: 122270km-75975miles
    Address 01: Engine (J623-CLCA)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 EN    HW: 03L 907 309 R
       Component: R4 2.0l TDI   H21 9977
       Revision: 42H21---    Serial number:
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018EN 003008
       Revision: 00H31001
       VCID: 7BB619ABFA0C185E5E-802E
                        Reset counter: 103
                        Mileage: 122235 km
                        Date: 2014.11.26
                        Time: 07:20:25
                        Count: 16391
                        Count: 32768
                        Count: 12800
                        Count: 4233
                        Count: 49921
                        Count: 16
                        Count: 5888
                        Reset counter: 61
                        Mileage: 122226 km
                        Count: 3
                        Count: 2
                        Count: 4096
                        Count: 195
                        Count: 44544
                        Count: 65280
    01130 - ABS Operation
                        Reset counter: 61
                        Mileage: 122226 km
                        Count: 2
                        Count: 2
                        Count: 4096
                        Count: 124
                        Count: 44288
                        Count: 65280
       Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
       Component: AC Manuell    H19 0304
       Revision: 00001015
       Coding: 0000001002
       Shop #: WSC 00047 000 00091
       VCID: 7F4EEDBBE614047E72-802A
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0046
       Revision: BC011001
       Coding: 02000A3A902D00C040080080140081E40171008850A081605C8000000040
       VCID: 3B36D9ABBA8CD85E1E-806E
       Component: RLS 250711 05  54  0403
       Coding: 03300A
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5C6 919 475     HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0005
       Revision: --------    Serial number: 84091114301692
       Coding: 108001
       ASAM Dataset: EV_EPHVA18VW3610000 001003
       ROD: EV_EPHVA18VW3610000.rod
       VCID: 71AA3B83A040620EF4-8024
    1111316 - Speaker for Front Parking Aid
              B10F5 14 [009] - Open or Short to Ground
                        Reset counter: 61
                        Mileage: 122226 km
                        Date: 2020.07.04
                        Time: 19:26:25
       Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
       Component: AirbagVW10G   013 0613
       Serial number: 003G7RA0EE5A
       Coding: 00003241
       Shop #: WSC 00047 000 00000
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3326F18B9ADC101EC6-8066
       Serial number: 3572MSME35351562ZZZN
       Serial number: 3582MSME19736561ZZZW
       Serial number: 3516KSME22102B11ZZZ9
       Serial number: 3526KSME03122B11ZZZB
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110613301866
       Coding: 0082140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76A0089FC92E453621-8022
       Coding: 820000
       Part No SW: 5M0 920 860 E    HW: 5M0 920 860 E
       Component: KOMBI         H05 0308
       Coding: 170B00
       Shop #: WSC 73430 790 00051
       Revision:   H42       Serial number: 080711F2000135
       Coding: 351003
       VCID: 3522CF939CA80E2EE8-8060
       Component: IMMO          H05 0308
       Revision: A1001003    Serial number: 7660337301
       VCID: 291A13E340105ACE7C-807C
    03138 - Input AUX IN
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 63
                        Mileage: 122273 km
                        Date: 2014.12.01
                        Time: 09:08:57
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0516
       Revision: 12110009    Serial number: 0002908566
       Coding: 0012B7
       Shop #: WSC 01383 790 50316
       VCID: 1C743A371742BF66F7-8048
       Slave Driver:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000005839114
       Coding: 000290
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 69     3201
       Revision: 00H20000
       VCID: 3424F29757D21726DF-8060
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0516
       Revision: 14110009    Serial number: 0002917830
       Coding: 0012B6
       VCID: 1D7237330C58B66E00-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000005854206
       Coding: 000290
       Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
       Component: Radio RCD510  052 0208
       Revision: 00000001    Serial number: VWZ1Z3L1592442
       Coding: 01000400040006
       VCID: 230601CB223C809E36-8076
    End----------(Elapsed Time: 01:03, VBatt start/end: 12.1V/12.0V)-----------
  5. Likes Dana liked this post
  6. #4
    Jul 2020
    India
    [IMG]https://imgur.com/undefined[/IMG]
    Could you please plug in other parts exchanged and post another complete auto-scan?
    Jul 2020
    India
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #7
    Jul 2020
    India
    dear sir , i dont have the exchanged parts with me.
    https://imgur.com/a/8saot0G
  11. #8
    Vin number needs to be corrected in controllers by valid locksmith or dealer session because otherwise it might be considered changing a configuration.
  12. #9
    Jul 2020
    India
    in addresses 1,17 & 25 same VIN(i mean the new VIN) is coded
    posted the advance ID for addresses 1,17 &25 in 1st post
  13. #10
    It is not correct for the car.
    NO MATCH FOR ENGINE CODE OR TRANS CODE!
    FOD!
    Microfiche says NOPE!
  14. Likes PetrolDave liked this post
