2010 Audi S5 4.2L M/T P0087 Fuel Rail Pressure EPC light
Shake and Bake
C?ID=410407
Intermittent EPC light. MIL and/or EPC light come on under normal heavy acceleration (like entering a highway) or in higher gear at WOT (heavy load). Just picked VCDS up. Generic code reader would show P2293 and P0087. Haven't seen P2293 with VCDS scans. Generic scanner did not pick up motor mount or knock codes. P1575, P1571, and P0327 respectively. Looks like motor mount faults show upon starting engine (<400 rpm). Starting to log data but also getting used to the program. I can share that data too but need to know the way it's done. Second autoscan is most recent. It shows all codes but P0087 with no check engine light on at the dash. DTCs were cleared before I went on a babied 5+ mile ride to the store for some adult beverages, which is why the P0087 code didn't show I suspect.
Parameters for any PIDs that may relate to my issue would be welcomed.
Friday,10,July,2020,16:49:09:44565
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUGVAFR5AA052342   License Plate:
Mileage: 137550km-85469mi   Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          6C
VIN: WAUGVAFR5AA052342   Mileage: 137550km-85469miles
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 S    HW: 8T0 907 560
   Component: 4.2l V8/4V    H12 0004
   Revision: 76H12---
   Coding: 01140009180F0120
   Shop #: WSC 49179 001 1048576
   VCID: 4ACD67C92CB5E80BCDF-801E
005493 - Right Engine Mount Solenoid Valve (N145)
               P1575 - 001 - Short to Plus
                    Fault Status: 01100001
                    Mileage: 137484 km
                    Date: 2020.07.09
                    Time: 20:05:31
                    RPM: 379 /min
                    Load: 92.9 %
                    Temperature: 93.0°C
                    Temperature: 73.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.557 V
005489 - Left Engine Mount Solenoid Valve (N144)
               P1571 - 001 - Short to Plus
                    Mileage: 137484 km
                    Date: 2020.07.09
                    Time: 20:05:31
                    RPM: 379 /min
                    Load: 92.9 %
                    Temperature: 93.0°C
                    Temperature: 73.0°C
                    Voltage: 11.557 V
000135 - Fuel Rail/System Pressure
               P0087 - 008 - Too Low - MIL ON
                    Fault Status: 11101000
                    Mileage: 137508 km
                    Date: 2020.07.10
                    Time: 07:44:57
                    RPM: 2368 /min
                    Load: 68.2 %
                    Speed: 64.0 km/h
                    Temperature: 92.0°C
                    Temperature: 32.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000807 - Knock Sensor 1 (G61)
               P0327 - 002 - Signal too Low - Intermittent
                    Mileage: 137546 km
                    Date: 2020.07.10
                    Time: 16:21:45
                    RPM: 2656 /min
                    Load: 49.8 %
                    Speed: 72.0 km/h
                    Temperature: 93.0°C
                    Temperature: 38.0°C
                    Voltage: 13.970 V
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 110D18
   Shop #: WSC 06325 000 00000
   VCID: 7AADF7093CD5B88B1DF-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0327
   Coding: 0B0000
   VCID: 78A9ED0102D9AA9B6BB-802C
   Subsystem 1 - Part No SW: 8T0 959 754 M    HW: 8T0 959 754 M
   Serial number: 0509000059318016
   Serial number: 0209000106123007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010057546
   Coding: 00017025002C00000000
   VCID: 43D34AED0B9F39430E9-8016
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01180120101059
   Coding: 48122000
   VCID: 005985E15A09E25B53B-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000436430
   Coding: 26001091063CAF010000080300003D3D0F1C138800010161000000
   VCID: 3C213111766146BB4F3-8068
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 190110  H14 0070
   Serial number: SWF10010195357
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10742535
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000801100917
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51230935000488
   Coding: 200002
   VCID: 47CB5EFD3FA71563D21-8012
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD05ESPW
   Coding: 303338334330303030304A55304C38543053
   VCID: 42DD4FE91405304B05F-8016
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900005JUZ
   Serial number: 6334MSME4E01545FL
   Serial number: 6344MSME4E04693ES
   Serial number: 6352QSME324B341EJ
   Serial number: 6362QSME6F4B0704P
   Serial number: 63732SME794A312E6
   Serial number: 63832SME794A3018%
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90315JAF000GK
   Coding: 000016
   VCID: 3D273C156D7B4FB378D-8068
   Part No SW: 8T0 920 981 N    HW: 8T0 920 981 N
   Component: KOMBIINSTR.   H34 0255
   Revision: 00000000    Serial number: CI575UA1A
   Coding: 8B1501000300D705020000
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E10111813D
   Coding: 00C303
   VCID: 52FD7FA9C4E5A0CBB5F-8006
   Component: J367-BDM  H07 0170
   Serial number: 10001438110110
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010057819
   Shop #: WSC 41690 001 1048576
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1201
   Coding: 011C03224000120102
   VCID: 50F975A1CAE9D2DB83B-8004
   Revision: 00002001    Serial number: 0124723584
   Coding: 0106029A007A444400B0003200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000207509
   Component: J245EE20SKB13  H01 0220
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34882001010501
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1201
   VCID: 4FFB76DDD7D7CD239A1-801A
   Revision: 00000003    Serial number: 00000000544464
   VCID: 343119315E318EFB873-8060
   Part No: 8K5 907 357
   Shop #: WSC 06324 000 00000
   VCID: 77ABEE3D03C7A5E3621-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335AL0A7547010
   Coding: 020000010000000001
   VCID: 1D67DC95CDBB2FB358D-8048
   Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 490AP0A7543430
   Coding: 010200020206A1EF41000B0E000000030000
   VCID: 372B2E3D4F4765E3A21-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356L/0A1163639
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000445526
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
   Revision: --H03---    Serial number: 525PA8-J9Y92N6
   Coding: 1000008
   VCID: 38292D014E596A9BABB-806C
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/11.9V)-----------
Easy cruise with no heavy acceleration. DTCs cleared prior.
Friday,10,July,2020,19:12:07:44565
Mileage: 137560km-85475mi   Repair Order:
          6C
VIN: WAUGVAFR5AA052342   Mileage: 137560km-85475miles
   Revision: 76H12---
                    Mileage: 137556 km
                    Date: 2020.07.10
                    Time: 18:35:05
                    RPM: 228 /min
                    Load: 100.0 %
                    Temperature: 69.0°C
                    Temperature: 63.0°C
                    Voltage: 10.668 V
                    Mileage: 137556 km
                    Date: 2020.07.10
                    Time: 18:35:05
                    RPM: 228 /min
                    Load: 100.0 %
                    Temperature: 69.0°C
                    Temperature: 63.0°C
                    Voltage: 10.668 V
                    Fault Status: 01100010
                    Mileage: 137556 km
                    Date: 2020.07.10
                    Time: 18:46:30
                    RPM: 2678 /min
                    Load: 42.3 %
                    Speed: 38.0 km/h
                    Temperature: 93.0°C
                    Temperature: 56.0°C
                    Voltage: 13.970 V
Readiness: 0000 1101
   Coding: 110D18
   Coding: 0B0000
   Coding: 48122000
   Coding: 00FD11
   Coding: 02532C
   Coding: 200002
   Coding: 000016
   Coding: 00C303
   Coding: 1000008
End----------(Elapsed Time: 01:37, VBatt start/end: 12.0V/11.9V)-----------
Is this car barely under useful life warranty extension?
JPPSG yet?
What is status of fuel filter?
Is lift fuel pump and HPP operating correctly and did you check cam follower and stroke run out?
Did you check PSI sensor and corelate to gauge plus do a volume output check?
Shake and Bake
C?ID=410407
Hello Jack
No warranty. What is JPPSG? I understand the fuel filter is internal to the tank with the pump. Haven't checked. Would likely replace pump too if I have to go that far. Cam followers look good. There's two fuel pressure sensors according to schematic. One HP under intake on fuel rail and the other in plain view on low side. Which one and what are the parameters? I have data logs under different driving conditions. I'd like to start there before ripping and tearing components apart.
You are not expecting the forum to be used to circumvent tests using RTFB specification's and going to cross check values of sensors to block values with DVOM and do mechanical tests while using WD locator to identify a component, right?
What was delivery date if vehicle into service or commerce do you know?
Why are you sure no useful life warranty?
