Results 1 to 5 of 5
Thread: 2010 Audi S5 4.2L M/T P0087 Fuel Rail Pressure EPC light
    Jul 2020
    Intermittent EPC light. MIL and/or EPC light come on under normal heavy acceleration (like entering a highway) or in higher gear at WOT (heavy load). Just picked VCDS up. Generic code reader would show P2293 and P0087. Haven't seen P2293 with VCDS scans. Generic scanner did not pick up motor mount or knock codes. P1575, P1571, and P0327 respectively. Looks like motor mount faults show upon starting engine (<400 rpm). Starting to log data but also getting used to the program. I can share that data too but need to know the way it's done. Second autoscan is most recent. It shows all codes but P0087 with no check engine light on at the dash. DTCs were cleared before I went on a babied 5+ mile ride to the store for some adult beverages, which is why the P0087 code didn't show I suspect.
    Parameters for any PIDs that may relate to my issue would be welcomed.
    Friday,10,July,2020,16:49:09:44565
    VIN: WAUGVAFR5AA052342   License Plate:
    Mileage: 137550km-85469mi   Repair Order:
    Chassis Type: FR-AU48 (8T0)
    Scan: 01 03 05 06 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
              6C
    VIN: WAUGVAFR5AA052342   Mileage: 137550km-85469miles
    Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
       Part No SW: 8T0 907 560 S    HW: 8T0 907 560
       Component: 4.2l V8/4V    H12 0004
       Revision: 76H12---
       Coding: 01140009180F0120
       Shop #: WSC 49179 001 1048576
       VCID: 4ACD67C92CB5E80BCDF-801E
    005493 - Right Engine Mount Solenoid Valve (N145)
                   P1575 - 001 - Short to Plus
                        Fault Status: 01100001
                        Mileage: 137484 km
                        Date: 2020.07.09
                        Time: 20:05:31
                        RPM: 379 /min
                        Load: 92.9 %
                        Temperature: 93.0°C
                        Temperature: 73.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.557 V
    005489 - Left Engine Mount Solenoid Valve (N144)
                   P1571 - 001 - Short to Plus
                        Mileage: 137484 km
                        Date: 2020.07.09
                        Time: 20:05:31
                        RPM: 379 /min
                        Load: 92.9 %
                        Temperature: 93.0°C
                        Temperature: 73.0°C
                        Voltage: 11.557 V
                   P0087 - 008 - Too Low - MIL ON
                        Fault Status: 11101000
                        Mileage: 137508 km
                        Date: 2020.07.10
                        Time: 07:44:57
                        RPM: 2368 /min
                        Load: 68.2 %
                        Speed: 64.0 km/h
                        Temperature: 92.0°C
                        Temperature: 32.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.843 V
    000807 - Knock Sensor 1 (G61)
                   P0327 - 002 - Signal too Low - Intermittent
                        Mileage: 137546 km
                        Date: 2020.07.10
                        Time: 16:21:45
                        RPM: 2656 /min
                        Load: 49.8 %
                        Speed: 72.0 km/h
                        Temperature: 93.0°C
                        Temperature: 38.0°C
                        Voltage: 13.970 V
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 110D18
       Shop #: WSC 06325 000 00000
       VCID: 7AADF7093CD5B88B1DF-802E
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0327
       Coding: 0B0000
       VCID: 78A9ED0102D9AA9B6BB-802C
       Subsystem 1 - Part No SW: 8T0 959 754 M    HW: 8T0 959 754 M
       Serial number: 0509000059318016
       Serial number: 0209000106123007
       Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
       Component: MEM-BFS       H10 0074
       Revision: AA000000    Serial number: 00001010057546
       Coding: 00017025002C00000000
       VCID: 43D34AED0B9F39430E9-8016
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01180120101059
       Coding: 48122000
       VCID: 005985E15A09E25B53B-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000436430
       Coding: 26001091063CAF010000080300003D3D0F1C138800010161000000
       VCID: 3C213111766146BB4F3-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 190110  H14 0070
       Serial number: SWF10010195357
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10742535
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000801100917
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51230935000488
       Coding: 200002
       VCID: 47CB5EFD3FA71563D21-8012
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD05ESPW
       Coding: 303338334330303030304A55304C38543053
       VCID: 42DD4FE91405304B05F-8016
       Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
       Component: BF-Gewichtss.  H01 0050
       Serial number: 5810000R0900005JUZ
       Serial number: 6334MSME4E01545FL
       Serial number: 6344MSME4E04693ES
       Serial number: 6352QSME324B341EJ
       Serial number: 6362QSME6F4B0704P
       Serial number: 63732SME794A312E6
       Serial number: 63832SME794A3018%
       Revision: --------    Serial number: 90315JAF000GK
       Coding: 000016
       VCID: 3D273C156D7B4FB378D-8068
       Part No SW: 8T0 920 981 N    HW: 8T0 920 981 N
       Component: KOMBIINSTR.   H34 0255
       Revision: 00000000    Serial number: CI575UA1A
       Coding: 8B1501000300D705020000
       Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0105
       Revision: EB800053    Serial number: 5300E10111813D
       Coding: 00C303
       VCID: 52FD7FA9C4E5A0CBB5F-8006
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 10001438110110
       Component: MEM-FS        H10 0074
       Revision: AA000000    Serial number: 00001010057819
       Shop #: WSC 41690 001 1048576
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1201
       Coding: 011C03224000120102
       VCID: 50F975A1CAE9D2DB83B-8004
       Revision: 00002001    Serial number: 0124723584
       Coding: 0106029A007A444400B0003200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000207509
       Component: J245EE20SKB13  H01 0220
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34882001010501
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1201
       VCID: 4FFB76DDD7D7CD239A1-801A
       Revision: 00000003    Serial number: 00000000544464
       VCID: 343119315E318EFB873-8060
       Part No: 8K5 907 357
       Shop #: WSC 06324 000 00000
       VCID: 77ABEE3D03C7A5E3621-8022
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335AL0A7547010
       Coding: 020000010000000001
       VCID: 1D67DC95CDBB2FB358D-8048
       Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
       Component: H-BN-NA       H47 0042
       Revision: --------    Serial number: 490AP0A7543430
       Coding: 010200020206A1EF41000B0E000000030000
       VCID: 372B2E3D4F4765E3A21-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356L/0A1163639
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000445526
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Revision: --H03---    Serial number: 525PA8-J9Y92N6
       Coding: 1000008
       VCID: 38292D014E596A9BABB-806C
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/11.9V)-----------
    Easy cruise with no heavy acceleration. DTCs cleared prior.
    Friday,10,July,2020,19:12:07:44565
    Mileage: 137560km-85475mi   Repair Order:
              6C
    VIN: WAUGVAFR5AA052342   Mileage: 137560km-85475miles
       Revision: 76H12---
                        Mileage: 137556 km
                        Date: 2020.07.10
                        Time: 18:35:05
                        RPM: 228 /min
                        Load: 100.0 %
                        Temperature: 69.0°C
                        Temperature: 63.0°C
                        Voltage: 10.668 V
                        Mileage: 137556 km
                        Date: 2020.07.10
                        Time: 18:35:05
                        RPM: 228 /min
                        Load: 100.0 %
                        Temperature: 69.0°C
                        Temperature: 63.0°C
                        Voltage: 10.668 V
                        Fault Status: 01100010
                        Mileage: 137556 km
                        Date: 2020.07.10
                        Time: 18:46:30
                        RPM: 2678 /min
                        Load: 42.3 %
                        Speed: 38.0 km/h
                        Temperature: 93.0°C
                        Temperature: 56.0°C
                        Voltage: 13.970 V
    Readiness: 0000 1101
       Coding: 110D18
       Coding: 0B0000
       Coding: 48122000
       Coding: 00FD11
       Coding: 02532C
       Coding: 200002
       Coding: 000016
       Coding: 00C303
       Coding: 1000008
    End----------(Elapsed Time: 01:37, VBatt start/end: 12.0V/11.9V)-----------
    Is this car barely under useful life warranty extension?
    JPPSG yet?
    What is status of fuel filter?
    Is lift fuel pump and HPP operating correctly and did you check cam follower and stroke run out?
    Did you check PSI sensor and corelate to gauge plus do a volume output check?
    Jul 2020
    Hello Jack
    No warranty. What is JPPSG? I understand the fuel filter is internal to the tank with the pump. Haven't checked. Would likely replace pump too if I have to go that far. Cam followers look good. There's two fuel pressure sensors according to schematic. One HP under intake on fuel rail and the other in plain view on low side. Which one and what are the parameters? I have data logs under different driving conditions. I'd like to start there before ripping and tearing components apart.
    Quote Originally Posted by Shake and Bake View Post
    What is JPPSG?
    See https://forums.ross-tech.com/showthr...uot-JPPSG-quot
  5. Likes Uwe liked this post
    You are not expecting the forum to be used to circumvent tests using RTFB specification's and going to cross check values of sensors to block values with DVOM and do mechanical tests while using WD locator to identify a component, right?
    What was delivery date if vehicle into service or commerce do you know?
    Why are you sure no useful life warranty?
