A4 b7 motor for intake flap V157
Rallycraig
C?ID=400101
Hi all, first post on here, go easy with me!
Car has come to me from another garage, v157 fault code, ignition based, it’s had a new flap motor already, loom checks out good and an overlay loom tried too. I’ve had the ecu tested (ok apparently, though I’m questioning it) fuses all good, am I missing something glaringly obvious? anyone had this before? Thanks
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ8E38A127197 License Plate:
Address 01: Engine Labels: 03G-906-018-BRD.clb
Control Module Part Number: 03G 906 018 AQ HW: 03G 906 018 AQ
Component and/or Version: R4 2.0l PPD1.3 9888
Software Coding: 0000072
Work Shop Code: WSC 66565 257 00032
VCID: 74A4F7B017EF29261F-8020
012545 - Motor for Intake Manifold Flap (V157)
P3101 - 009 - Open or Short to Ground
Fault Status: 01010100
Reset counter: 40
Torque: 0.0 Nm
0.00 %
Voltage: 11.41 V
Torque: 1016.0 Nm
Torque: 0.0 Nm
Readiness: N/A
TFSI
Maryland, USA
C?ID=66650
Hello New user,
welcome on board. Can you do and post autoscan so members can have a full picture of whats going on with car and contribute?
Rallycraig
C?ID=400101
Friday,10,July,2020,21:22:36:21510
          67 69 75 76 77
VIN: WAUZZZ8E38A127197   Mileage: 172950km-107466miles
   Part No SW: 03G 906 018 AQ    HW: 03G 906 018 AQ
   Component: R4 2.0l PPD1.3      9888
   Revision: --H53---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   Shop #: WSC 66565 257 00032
                    Reset counter: 40
                    Torque: 0.0 Nm
                        0.00 %
                    Voltage: 9.15 V
                    Torque: 1016.0 Nm
                    Torque: 0.0 Nm
Readiness: N/A
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004405
   Shop #: WSC 06335 000 00000
   VCID: 2C142FD08F5F31E687-8078
                    Reset counter: 39
                    Hex Value: 0x0000
                    Hex Value: 0x5222
                    Hex Value: 0x0024
                    Hex Value: 0x0191
                    Hex Value: 0x0001
                    Reset counter: 40
                    Hex Value: 0x0080
                    Hex Value: 0x0722
                    Hex Value: 0x0013
                    Hex Value: 0x8596
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BL
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6C94EFD01EDFF1E6C7-5160
            30-00 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 00001
   Shop #: WSC 06335
   VCID: 3D3212943525A86E20-4B1E
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H14 4230
   Revision: 91H14423    Serial number: 0036M00CGUGJ
   Coding: 0031612
   VCID: 3B361C8C7A31A65E1E-806E
   Subsystem 1 - Serial number: 6332DRB4068E501EV
   Subsystem 2 - Serial number: 6342DRB4068C8B9E9
   Subsystem 3 - Serial number: 6352ARB40326B19ES
   Subsystem 4 - Serial number: 6362ARB40337AFAE2
   Subsystem 5 - Serial number: 63729RB402C9A101I
   Subsystem 6 - Serial number: 63829RB402C9A0D4Y
00532 - Supply Voltage B+
                    Reset counter: 39
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 02011
   Shop #: WSC 06335
   VCID: 41CA6E6449DDCC8E44-4B1E
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 982 M    HW: 8E0 920 982 M
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0006418
   Shop #: WSC 00047 067 57207
   VCID: 383C03804A078D46F3-5184
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0006418
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 T    HW: 8E0 035 192 T
   Component: RNS-E HIGH EU   H74 0650
   Revision:      05S    Serial number: AUZBZ7G1169466
   Coding: 0301117
   VCID: 35220AB45E15702EE8-5160
                    Reset counter: 192
                    Date: 2006.07.18
                    Time: 00:00:36
                    Voltage: 11.80 V
                    Reset counter: 192
                    Date: 2006.07.18
                    Time: 00:00:30
                    Voltage: 10.80 V
                    Mileage: 655350 km
                    Count: 308
                    Clock: 07:02
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6B96ECCC1BD1F6DECE-50F4
01463 - Alarm triggered by Sensor for anti-theft alarm System
            43-00 - Closed
   Part No: 8E0 959 433 CQ
   Component: Komfortgerát T3B    4336
   Coding: 06895
   Shop #: WSC 06335
   VCID: 0248A1680C5B17961D-4B1E
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Component: Tõrsteuer.HR BRM 0606
8 Faults Found:
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
00955 - Key 1
            35-10 - - - Intermittent
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0301117
                    Reset counter: 192
                    Date: 2006.07.18
                    Time: 00:00:36
                    Voltage: 11.80 V
                    Reset counter: 192
                    Date: 2006.07.18
                    Time: 00:00:30
                    Voltage: 10.80 V
                    Mileage: 655350 km
                    Count: 308
                    Clock: 07:02
End----(Elapsed Time: 05:23, VBatt start/end: 11.1V/10.8V. VIgn 10.7V)-----
Rallycraig
C?ID=400101
Battery voltage is getting low as I’ve been looking at it this afternoon, can’t get it near my charger til tomorrow but that v157 code has been there throughout.
Rallycraig
C?ID=400101
I keep a fair number of OE plugs in stock, made up a 4pin for this, took the throttle body up to the ecu box, pin 1 to earth, pin 2 from the wire bundle (red/blue) at the15a fuse, managed to de-pin 3 from the ecu connector, pin 4 I unfortunately had to cut and join.
I have a bkd Seat Leon here, very similar flap motor (not checked the wiring diagram yet to confirm 4 pins go to the same places) but with key off engine off, I have around 12v at each connector pin, On the offending Audi pin 1&2 is 12v, pin 3/4 from ecu showing nothing.
Rallycraig
C?ID=400101
I have continuity on all 4 wires, And seemingly low resistance, will try a 55w bulb today for load checking on the ecu wires.
Rallycraig
C?ID=400101
Load tested both ecu wires, both light up a 55w bulb and show 11.9v, battery currently at 12.5v. To me it’s looking like the ‘tested ok’ ecu clearly isn’t 🤔
Feeds to ECU + grounds checked too, did you isolate ECU zones or qualify with decade box?
Rallycraig
C?ID=400101
Feeds and grounds checked. I don’t have a decade box, unfortunately the customer as had to have the car back, it’s coming back in a few days. The original problem apparently was the dpf isn’t regenerating, other garages have fired parts at it to no avail but past experience shows with this code present it fails a regen anyway. It’d be nice to fix it for him, I’m now considering a plug/play ecu I’ve found online or even an engine loom, though the tests check out ok maybe there is a rub through somewhere, this is the loom that’s foam insulated across the bulkhead that you can’t unwrap.
Did you load test the wires yet on feed side?
Do faults clear if you unplug engine bay side of ECU?
Rallycraig
C?ID=400101
Only load tested from the ecu to the v157, can’t recall clearing the codes with engine bay side disconnected. Daft thing is the flap works and does it’s job when you switch the engine off etc, but with this stored code it’s not allowing the dpf to regenerate
