Results 1 to 6 of 6
Thread: Audi B5 S4 ESP ABS issue
    Jun 2020
    Post Audi B5 S4 ESP ABS issue
    Pretty much first time user, main fault is esp traction light comes on when accelerating hard, if you potter around no issues but soon as you right foot it lamp comes on. It extinguishes every start up and sometimes doesnt come on at all depending how fast you go, can creep it upto 30/40 mph ish with no light. Somehow ive started a system test which i cant seem to get out of i think because of the esp pump issue, any help greatly appreciated Rich..
    Friday,10,July,2020,15:47:15:50214
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ8DZ1A089015   License Plate:
    Chassis Type: 8D (8D - Audi A4/S4/RS4 B5 (1995 > 2002))
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 8D0 907 551 D
       Component: 2.7l V6/5VT     G   0002
       Coding: 05711
       VCID: AB16A1305BC196DE0E-5160
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 8D0 907 389 E
       Component: ABS/ESP allrad      D36
       Coding: 04395
       Shop #: WSC 00001
       VCID: B52287488D85D02E68-5160
                35-00 - -
    01422 - Hydraulic Pump for Electronic Stability Program (V156)
                35-00 - -
    Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
       Part No: 8D0 820 043 N
       Component: A4     KLIMAAUTOMAT D56
       Coding: 00061
       Shop #: WSC 06325
       VCID: AB16A1305BC196DE0E-25AE
    00785 - Temp Sensor in Instrument Panel (G56)
                30-00 - Open or Short to Plus
    00792 - A/C Pressure Switch (F129)
    Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
       Part No: 8D0 959 655 J
       Component: Airbag Front+Seite 0001
       Coding: 01104
       Shop #: WSC 06325
       VCID: BD329F68B5B5086EA0-5160
    Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
       Part No: 8D0 920 980 K
       Component: B5-KOMBIINSTR. VDO D12
       Coding: 00390
       Shop #: WSC 00778
       VCID: B326B95083F1CE1E46-5160
       WAUZZZ8DZ1A089015     AUZ7Z0Y1624499
    00771 - Fuel Level Sensor (G)
    Address 35: Centr. Locks        Labels:. 8D0-862-257.clb
       Part No: 8D0 862 257 E
       Component: CV-Pump, Alarm, RC  D13
       Coding: 13130
       Shop #: WSC 00778
       VCID: AF2EB5206FD9EAFE22-4F0C
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
                35-00 - -
                35-00 - -
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
                35-00 - -
                35-00 - -
    00991 - Interior Lights
                28-00 - Short to Plus
    00956 - Key 2
                09-00 - Adaptation Limit Surpassed
    00958 - Key 4
    01134 - Alarm Horn (H12)
                49-00 - No Communications
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00101
       Shop #: WSC 06325
       VCID: E08C061C62870586EB-4AA4
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D003
       Coding: 00012
       Shop #: WSC 06325
       VCID: E58217087DA560AE18-5184
    End----(Elapsed Time: 03:49, VBatt start/end: 11.6V/11.7V. VIgn 11.7V)-----
    Is ignition switch fresh and solid because if it isn't it will keep doing this?
    Jun 2020
    Yes mate thanks ive checked and checked every thing seems ok i've fitted another pump (used). The hydraulic pump was a permanent fault open circuit on pump motor, fitted the one that's on it now and the fault clears until you accelerate hard, then just the traction light illuminates but reset's on ignition cycle until you accelerate hard again. I was unsure if there's any adaptions for the pump but somehow iv'e started a self test which has left the 2 codes and both traction and abs lights on permanent, part of me is thinking because of the pump motor fault it wont complete the self test and cant seem to be able to abort the self test, thanks for the link, Rich.
    Jun 2020
    As per ignition switch, ive got to admit, not checked this but will have a look, the cars done 325000 miles so worth a look. Thanks Rich
    Also did you check that ABS sensors and reluctor rings + sensors are completely inserted, sometimes air gap is incorrect or they back out?
