2007 S8 5.2 V10 Misfires, Fuel Trims
SeattleMatt
C?ID=282387
Hello everyone, I need some help. I have been chasing problems with my S8 5.2 v10 for a while now and I'm a bit stumped. I replaced all plugs, swapped some coilpacks around, swapped out the oil separator, checked for vacuum leaks, and did a carbon cleaning but the problems remain.I feel that there could still be a vacuum leak, but I can't locate any. I am getting very odd fuel trims and a lean code for ECU 1. These are from Engine Other (which shows both ECU's simultaneously, ECU 1 on top 2 on bottom).
For reference
group 32 = long term fuel trims
group 33 = short term fuel trims
You can see that my ECU 1 Adaptation partial is maxed out positive 25% on both banks, while the idle adaptation is maxed out negative 6.6% on both banks.
The ECU 2 also shows some questionable trims but not nearly as bad.
One thing that confuses me is that the intake has dual MAFs one on each side, with duel intake boots, but once they hit the manifold, they are combined. In my mind, this would negate any side to side vacuum leaks since there's no logical way the engine could discern between the sides on the intake vacuum.
I should also point out that the MAFs show about equal g/s so I think they are ok, I will post their numbers later. if needed. I'd be curious to know what others read on their MAFs, at idle with the same setup, this may lead me to a clue.
Additionally after I did the carbon cleaning the problem seemed to have changed to be different on either engine module, before that the fuel trims were both high negatives. I am also concerned that I messed something up in the carbon cleaning process, perhaps something leaked into the cats or o2's.
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 5AH15--- Serial number: AUX3Z0G0715212
Coding: 01060009190F0160
Shop #: WSC 22309 444 91613
VCID: 204F9C96F3EBA7862B-8074
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 -
Fault Status: 01100001
Mileage: 182875 km
Date: 2020.07.04
Time: 12:42:42
RPM: 629 /min
Load: 34.1 %
Temperature: 100.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 -
Mileage: 182875 km
Date: 2020.07.04
Time: 12:42:43
RPM: 629 /min
Load: 34.1 %
Temperature: 42.0°C
Voltage: 13.716 V
Address 11: Engine II Labels: Redir Fail!
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 182871 km
Date: 2020.07.04
Time: 12:02:57
RPM: 2478 /min
Load: 62.3 %
Speed: 46.0 km/h
Temperature: 102.0°C
Temperature: 55.0°C
Voltage: 13.589 V
000775 - Cylinder 7
P0307 - 001 - Misfire Detected - MIL ON
Mileage: 182871 km
Date: 2020.07.04
Time: 12:02:57
RPM: 2478 /min
Load: 62.3 %
Speed: 46.0 km/h
Temperature: 55.0°C
Voltage: 13.589 V
000784 - Cylinder 10
P0310 - 002 - Misfire Detected - MIL ON
Fault Status: 11100010
Mileage: 182917 km
Date: 2020.07.05
Time: 19:48:56
RPM: 1710 /min
Load: 38.8 %
Speed: 47.0 km/h
Temperature: 93.0°C
Temperature: 39.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
000776 - Cylinder 8
P0308 - 008 - Misfire Detected
Mileage: 182934 km
Date: 2020.07.09
Time: 10:43:21
RPM: 897 /min
Load: 48.6 %
Speed: 15.0 km/h
Temperature: 30.0°C
Temperature: 23.0°C
Voltage: 12.446 V
Did you isolate zones for vacuum leaks such as LDP, booster and n80 or gaskets?
Did you use flange sealant, Hylomar or Teflon on intake o-ring's to verify they float and seal?
SeattleMatt
C?ID=282387
My vacuum test was pretty basic, I put a glove on each intake boot after the filters and poked one with the pump, then pumped it with smoke, it filled and held pressure pretty much and I didn't see any leaks, so I figured it was good. I used this method before on this car and found a couple obvious leaks in the pas. I'd like to test more thoroughly if there is a better procedure and its necessary.
I used Permatex ultrablack to re-assemble the manifold after splitting it (it's o2 safe according to the package). I did not find any broken flaps or issues so that was a waste of over 4 hours.
I used 91% alcohol to soften the carbon, then scraped it with tools and zip ties, sucked it out with a pump. It's possible some small pieces of carbon were left in there, but nothing significant.
