Audi a8 abs coding
Frikki
South Africa
C?ID=357723
hi there all. please advise on coding audi a8 abs coding. I have tried using various codings without any success. this is the log. also tried different log ins without success. many thanks. keep well.
Wednesday,08,July,2020,15:19:05:62451
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4E57N022996   License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 72 76 77
VIN: WAUZZZ4E57N022996   Mileage: 167410km-104023miles
Address 01: Engine        Labels:. 079-907-560-BVJ.clb
   Part No SW: 4E1 910 560 B    HW: 4E1 907 560
   Component: 4.2l V8/4V          0030
   Revision: 71H21---    Serial number: AUX3Z0G4123987
   Coding: 01060000190F0120
   Shop #: WSC 02313 785 00200
   VCID: 211E11F7EDC6D5337C5-8074
               P1653 - 008 -
                    Fault Status: 01101000
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:02:57
                    Load: 0.0 %
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.557 V
006535 - Function Limited due to Brake Temperature
               P1987 - 008 -  - Intermittent
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:43
                    Load: 0.0 %
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Voltage: 11.557 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:44
                    Load: 0.0 %
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Voltage: 11.557 V
053250 - Please Check Fault Codes in Comfort System Control Module (J393)
               U1002 - 008 -  - Intermittent
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:46
                    Load: 0.0 %
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Voltage: 11.557 V
Readiness: 0110 1101
   Part No SW: 4E1 910 156 C    HW: 09L 927 156 A
   Component: AG6 09L 4,2lFSI RdW 0030
   Revision: --H01---    Serial number:        4330364
   Coding: 0000001
   VCID: 23121BFFF7DAC7236E9-8076
049442 - No Communication with ESP (Vehicle Dynamics) Control Module
               U0122 - 000 -  - Intermittent
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:45
                    (no units): 30.0
                    (no units): 130.0
                    Temperature: 20.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H46 0510
   Coding: 0000000
   VCID: 221C1EFBE8C0CE2B65F-8076
00003 - Control Module
            014 - Defective
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 G
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0G4123987
   Coding: 0265216
   Shop #: WSC 02311 785 00200
   VCID: 58E87C13FE1C54FB4BB-800C
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Fault Frequency: 0
                    Reset counter: 214
                    Mileage: 167408 km
                    Date: 2020.06.24
                    Time: 04:58:36
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3670624
   Shop #: WSC 04762 996 69814
   VCID: 241018E3F2D4C01B173-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 732     HW: 4E0 035 729
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 343EG077600432
   VCID: 5F9A570F9B32A3C30A1-800A
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000036993
   Subsystem 3 - Serial number: 0127.04.070000000100010025ÿ
   Subsystem 4 - Serial number: 010025ÿ
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 F
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000121734
   Coding: 0002049
   VCID: 1C602003CAA4F8DBAF3-8048
                    Reset counter: 213
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:21:04
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0143122
   VCID: 3634D2AB5448428BB97-8062
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000036
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00139548
   Shop #: WSC 02313
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H14 4210
   Revision: 91H14421    Serial number: 0037P0G0CZBN
   Coding: 0430707
   VCID: 270A0FEF83E22B03321-8072
   Subsystem 1 - Serial number: 63328RB402522B7AH
   Subsystem 2 - Serial number: 63428RB402522B87G
   Subsystem 3 - Serial number: 63528RB402522BE0G
   Subsystem 4 - Serial number: 63628RB402522B85G
   Subsystem 5 - Serial number: 63729RB4026490A3H
   Subsystem 6 - Serial number: 63829RB402648A76R
01316 - ABS Control Module
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:45
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H14 0040
   Coding: 0112041
   VCID: 659645E7B96EF913C0D-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 901 A    HW: 4E0 920 901 A
   Component: KOMBIINSTR. VDO H82 0530
   Revision: D05         Serial number: AUDID3G4005948
   Coding: 0000813
   Shop #: WSC 00999 067 57207
   VCID: 1E642A0BDCB8EACB417-804A
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H11 0090
   Revision: 11          Serial number: 200030750580E4
   Coding: FCFE7BDC2B3104
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:14:31
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046004    Serial number: AUZ5ZBG3407191
   VCID: 18683C133E9C94FB8BB-804C
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0265216
   XXXXXXXXXXX ELV                 XXXX
                    Fault Frequency: 0
                    Reset counter: 214
                    Mileage: 167408 km
                    Date: 2020.06.24
                    Time: 04:58:36
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0015510
   Shop #: WSC 04632 996 13564
   VCID: 28080CD38EFC247B3BB-807C
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:47
   Component: Sitzmemory FS  H02  0010
   Coding: 3670114
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1030
   Revision: 00000000    Serial number: 364E$077684692
   VCID: 3E24CA8B7C788ACB617-806A
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:49
                    Bin. Bits:     1100
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000711800068
   Coding: 0035984
   VCID: 1D662D07D1BEF1D358D-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 D
   Component: Türsteuer.FS BRM005 0180
   Coding: 0028462
   VCID: 201814F3E6CCDC3B73B-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H08 0020
   Revision: 00200008    Serial number:  W040705230024
   Coding: 0004812
   VCID: 2A0CF6DB90F0166B2DF-807E
01134 - Alarm Horn (H12)
                    Reset counter: 212
                    Mileage: 159920 km
                    Date: 2017.06.12
                    Time: 08:44:10
00984 - Left Tail Light (M4)
                    Reset counter: 214
                    Mileage: 133499 km
                    Date: 2015.08.26
                    Time: 16:52:42
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:46
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H03 0120
   Revision: PROD_01     Serial number: 00000000000337
   Coding: 0000017
   VCID: 2C00F0C39A04085BDF3-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000115923
   Coding: 0010101
                    Reset counter: 253
                    Mileage: 167408 km
                    Date: 2020.06.22
                    Time: 04:07:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 D
   Component: Türsteuer.BF BRM005 0180
   Coding: 0028462
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000921
   Shop #: WSC 52912 001 1048576
                    Reset counter: 253
                    Mileage: 167408 km
                    Date: 2020.06.22
                    Time: 04:07:45
                    Voltage: 10.56 V
                    Count: 242
                    Reset counter: 253
                    Voltage: 10.56 V
                    Count: 231
00576 - Terminal 15
                    Fault Status: 00101100
                    Reset counter: 253
                    Mileage: 167408 km
                    Date: 2020.06.22
                    Time: 02:46:42
                    Voltage: 10.77 V
                    Count: 41
   Part No: 8P0 907 357 F
   Component: Dynamische LWR  H02 0010
   Coding: 0000006
   VCID: 3D26CD87717E91D378D-8068
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 167416 km
                    Date: 2020.06.22
                    Time: 04:07:45
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396E 077573941
   Coding: 0000001
   VCID: 2E04FACBAC187A4BF17-807A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000006692
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  2705211056
   Coding: 344530393135313035412056413032373035323131303536
   Shop #: WSC 00000 128 00289
02274 - Quiescent Current Stage 3
                    Mileage: 167410 km
                    Date: 2020.06.24
                    Time: 04:58:23
02272 - Quiescent Current Stage 1
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 18:07:45
02273 - Quiescent Current Stage 2
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 18:10:54
02276 - Quiescent Current Stage 5
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 18:11:04
02277 - Quiescent Current Stage 6
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 18:11:24
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0028462
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0028462
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720713603404
   Coding: 0201008
                    Reset counter: 253
                    Mileage: 167410 km
                    Date: 2020.06.22
                    Time: 04:07:46
Address 77: Telephone
End----(Elapsed Time: 01:58, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
Jef
HQ
ABS coding info here:
http://wiki.ross-tech.com/wiki/index.php/Audi_A8_(4E)_Brake_Electronics
As per the VIN, Login = 06297 and Coding = 0007597
If the ABS module keeps flagging the 00003 - Control Module Defective code, verify the powers/grounds for the ABS module are not suffering from a voltage drop issue, otherwise you will be wasting time/money swapping out the ABS module. I personally suggest using the 180 LoadPro for testing voltage drops.
