Good Day everyone, i have a 2014 vw jetta that requires abs coding on the control module can you assist me with the codes please. i don't have the original coding .
Thursday,09,July,2020,08:53:07:12672
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Shift Performance
VIN: WVWZZZ16ZEM064144 License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZEM064144 Mileage: 53740km-33392miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 BT HW: 03C 907 309 F
Component: MED17.5.5 H13 7805
Revision: LCH13--- Serial number: 00000000000000
Coding: 00250012000400000000
Shop #: WSC 22345 002 1048576
ASAM Dataset: EV_ECM14TFS01103C906016BT 001010
ROD: EV_ECM14TFS01103C906016BT.rod
VCID: 72EFBFBCA59EA1160D-8026
4649 - Brake Booster Pressure Sensor
P0555 00 [175] - Electrical Malfunction
Mileage: 53749 km
Coolant temperature: 61 °C
Intake air temperature: 42 °C
Voltage terminal 30: 14.324 V
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 0.000 ms
Readiness: 1110 0101
Part No SW: 0AM 300 065 E HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6565
Revision: 00043014 Serial number: CU501403175065
Shop #: WSC 17351 003 1048576
VCID: 316D70B0A818DA0EB4-8064
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00066 000 00000
VCID: 7EF79B8CE9C6F57679-802A
16352 - Control Module - Electrical Error
Fault Status: 00101110
Reset counter: 212
Mileage: 53749 km
Date: 2014.11.30
Time: 01:44:31
Count: 2
Count: 12
Count: 24576
Count: 98
Count: 52480
Reset counter: 211
Date: 2014.11.30
Time: 01:11:28
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 43776
00150 - Plausibility Brake Booster System
Reset counter: 211
Mileage: 53749 km
Date: 2014.11.30
Time: 01:11:29
Count: 7
Count: 12
Count: 28672
Count: 398
Count: 43776
Count: 511
Part No SW: 3AA 907 044 BP HW: 3AA 907 044 BP
Component: Climatronic H05 0505
Revision: 00001K02
Coding: 001001A002
Shop #: WSC 00066 790 00191
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 7F096688E6CCFC7E72-802A
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0173
Revision: BC122001
Coding: 20000A3A982D00C440880080140081640371008870A089205CC000000040
VCID: 428F2F7CDDBE51965D-8016
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 110414 05 54 0403
Coding: 02300A
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 014 0613
Serial number: 003G6M0DU1MR
Coding: 00003241
Shop #: WSC 00066 790 00017
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 326F7FBC651EE116CD-8066
Serial number: 3572MSME0D764844ZZZ$
Serial number: 3582MSME2B363944ZZZ-
Serial number: 3516KSME5B075C2CZZZ0
Serial number: 3526KSME274C672CZZZ%
Part No SW: 1K5 953 521 BL HW: 5K0 953 569 AD
Revision: FF010042 Serial number: 20140424200832
Coding: 0882040000
ROD: EV_SMLSNGVOLWS.rod
VCID: 78FB8D94C3E2CB4633-802C
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 5C6 920 873 HW: 5C6 920 873
Component: KOMBI H04 0811
Coding: 171F00
Shop #: WSC 00066 000 00120
VCID: 6BD1A2D882B470DECE-803E
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 07061403001285
Coding: 351003
VCID: 79FD8890F0E8D24E4C-802C
Component: IMMO H04 0811
VCID: 6ADFA7DC8D4E69D6B5-803E
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0515
Revision: 12110009 Serial number: 0008544040
Coding: 0016B7
Shop #: WSC 01383 790 50316
VCID: 1C33B104179A4766F7-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1508
Serial number: 00000008710982
Coding: 000690
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 211
Mileage: 53749 km
Date: 2020.07.09
Time: 01:11:29
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 68 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 397D48907068124E0C-806C
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0515
Revision: 14110009 Serial number: 0008454026
Coding: 0017B6
VCID: 1D35BC000C804E6E00-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1508
Serial number: 00000008755074
Coding: 000690
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H06 5007
Revision: -----10S Serial number: VWZ4Z2P1370623
Coding: 05000400040006
VCID: 72EFBFBCAD9EA1160D-8026
End-------------------------(Elapsed Time: 02:32)--------------------------
