Very slow 2012 Jetta TDI
hbre78a
C?ID=409020
Hello everyone, I own a 2012 Jetta TDI DSG with 178k miles on it. I recently bought it, so i don't know if this is normal or not. It's tuned staged 2 malone, and deleted. My questions the car seems to be VERY slow off the line, like golf cart acceleration slow. Once it gets going to appears to be much better, but i dread red lights and stop signs as it takes so much time to get going again. I've done full scans with my rosstech cable and there are no faults. Any suggestions as to what it could be or where i should start looking first? This can't be normal. TIA
Remove tuning, scan car, post scan, fix as per RTFB to comport.
hbre78a
C?ID=409020
sorry what does fix as per RTFB to comport mean?
hbre78a
C?ID=409020
Thursday,09,July,2020,09:59:26:50019
VIN: 3VWLL7AJ9CM374903   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 47 56 77
VIN: 3VWLL7AJ9CM374903   Mileage: 288150km-179048miles
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 M    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 87381 042 00000
   VCID: 38292D556E5FBDFBABB-806C
11 Faults Found:
001166 - Sensor for Exhaust Flap
               P048E - 000 - Short to Plus
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Voltage: 11.86 V
                    Lambda: 99.4 %
                    Lambda: -12.6 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
001158 - Exhaust Gas Recirculation Sensor 2
               P0486 - 001 - Electrical Malfunction
                    Fault Status: 01100001
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Voltage: 11.86 V
                    Lambda: 99.4 %
                    Lambda: -1.6 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
009258 - Exhaust Gas Temperature Sensor; B1 S3
               P242A - 001 - Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Voltage: 11.86 V
                    Temperature: 27.9°C
                    Temperature: 30.0°C
                    Temperature: 930.0°C
                    Temperature: 24.0°C
008241 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
               P2031 - 001 - Electrical Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Voltage: 11.86 V
                    Temperature: 27.9°C
                    Temperature: 30.0°C
                    Temperature: 24.0°C
009298 - Diesel Particle Filter; Differential Pressure Sensor
               P2452 - 000 - Elect. Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Mileage: 930 km
                    Pressure: 0 mbar
                    Pressure: 0 mbar
                    (no units): 0.0
                    Temperature: 30.6°C
001136 - Exhaust Pressure Sensor 1
               P0470 - 000 - Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:50
                    Temperature: 19.8°C
                    Temperature: 27.9°C
                    Temperature: -48.0°C
                    Pressure: 0 mbar
                    Pressure: 0 mbar
001114 - EGR Valve 2 (N213)
               P045A - 000 - Electrical Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:51
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 27.9°C
001141 - Exhaust Pressure Control Valve
               P0475 - 000 - Electrical Malfunction
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:51
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Temperature: 24.0°C
                    Temperature: 27.9°C
000321 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
               P0141 - 002 - Malfunction
                    Fault Status: 01100010
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:54
                    Lambda: 0.8 %
                    Voltage: 0.000 V
                    Angle: 0.000°
                    Voltage: 3.300 V
               P2031 - 000 - Electrical Malfunction - MIL ON
                    Fault Status: 11100000
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:54
                    Voltage: 11.93 V
                    Temperature: 27.9°C
                    Temperature: 30.0°C
                    Temperature: 24.0°C
               P242A - 000 - Malfunction - MIL ON
                    Mileage: 288152 km
                    Date: 2014.11.30
                    Time: 12:44:54
                    Voltage: 11.93 V
                    Temperature: 27.9°C
                    Temperature: 30.0°C
                    Temperature: 24.0°C
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9430
   Revision: 05551213    Serial number: 00001111161664
   VCID: 1471B9E51277B99BE73-8040
   Revision: 00H31001
   Coding: B14B400C492900FE8D1402E4921C0042A71000
   VCID: 7DA7FC410DFD58D338D-8028
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000762969
   VCID: 6FBBD6095B913A43BA1-803A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0257
   Revision: B2066001    Serial number: 04371013120614
   Coding: 7B994BBF08AB0B0008382000240884C50082502E60000000300000000000
   Shop #: WSC 07209 002 104857
   VCID: 2F3B160997117A43FA1-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH0003TBY4
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Serial number: 0890861
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM03PN6+
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343119657EB7599B873-8060
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000APUH09
   Coding: 303036
   Serial number: 3572MSME030A034AZZZN
   Serial number: 3582MSME7905034AZZZW
   Serial number: 3516KSME570E0316ZZZP
   Serial number: 3526KSME50192216ZZZG
   Serial number: 3556LSME3F467E14ZZZ5
   Serial number: 3566LSME46122214ZZZH
   Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
   Component: KOMBI         H04 0604
   Coding: 270A01
   Shop #: WSC 00066 000 00123
   VCID: 290FF811A9751473245-807C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0257
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D5754AAF25BBA3B-8024
   Component: IMMO          H04 0604
   VCID: 6A8DC71D6CF3DF6BEDF-803E
   Revision: A1001003    Serial number: 7660916648
   VCID: 290FF811A9F51473245-807C
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   VCID: 35372461794D4093B0D-8060
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225319961955
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 303915758AAF65BBE3B-8064
Address 56: Radio
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661127991
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BFE29BF612203321-8072
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 99
                    Mileage: 288152 km
                    Date: 2020.07.09
                    Time: 12:51:39
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 99
                    Mileage: 288152 km
                    Date: 2020.07.09
                    Time: 12:51:39
End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
hbre78a
C?ID=409020
here's my log with the tune installed.
Thursday,09,July,2020,10:25:28:50019
   Coding: 0050078
   Shop #: WSC 74291 008 00000
Readiness: 0 0 0 X X
   Revision: 00H31001
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00003936
   Coding: 303036
   Coding: 270A01
   Revision: B2066001
   Coding: 102200
   Revision: 00H22000
Address 56: Radio
   ROD: UHVNA.rod
                    Reset counter: 99
                    Mileage: 288152 km
                    Date: 2020.07.09
                    Time: 13:17:57
                    Reset counter: 99
                    Mileage: 288152 km
                    Date: 2020.07.09
                    Time: 13:17:57
End----------(Elapsed Time: 01:39, VBatt start/end: 13.4V/13.5V)-----------
PetrolDave
Westbury, UK
C?ID=1423
Those scans suggest that the tune is masking a lot of engine problems - 11 faults with the standard code, none with the tune :facepalm:
hbre78a
C?ID=409020
well i mean most of the faults in the non tuned scan are due to everything being deleted, right? I would think non tuned scan would throw codes for exhaust flap, egr, dpf and what not being non of the stuff is there. Correct me if i'm wrong
PetrolDave
Westbury, UK
C?ID=1423
All those sensors deleted - are you 100% sure about that?
BTW is it legal in your state to delete the DPF and EGR, etc.(I think Jack will be along to say it's not legal IIRC)? It certainly isn't legal where I live over the pond.
Doesn't the EPA CAA make that the case? :rolleyes:
This section is for repairs that are qualified using the repair manual, not a place to aid in the willful nefarious unlawful purported acts to remove AECD's, than again the cars were originally certified as a means of an unlawful act were they not & was not the company put in the hurt locker worldwide and still dealing with repercussions?
Remove modified defeat devices and return car to config approved by EPA.
If all the stuff that's been deleted in the tune has physically been removed from the car, then yes, the stock software would throw faults for the things that are physically missing.
But since you have no fault codes with the ECU delete software, I'm not sure what you should look for. I might suggest contacting Malone for advice, since this thing is effectively "their" engine now.
Is "Their" is or depending on what "Their" is?
And their liability for all repairs to get back to comporting configuration and trebled right + mandatory penalties and discretionary fines + inflation factor of CFR to all be adjudicated?
scarley
I honestly don't know what your problem is. Maybe it is mechanical like bad engine mounts and bushings. I am sure bad sway bar bushings won't help either.
scarley
It is a good discussion. Maybe I will take my VCDS and see if I can program a faster car.
