Hello Everyone!
I'm trying to clear these 2 faults "00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation" and "01486 - System Function Test Activated 000" I did follow the steps on this video from ross tech ----->https://www.youtube.com/watch?v=b6lm9OmC2so and when I get to the all valves adjustment on group 025 it doesn't calibrate instead it says "No Valv [000/000] >000< Error 212" and I always start with a COLD! Engine in the mornings even with a Fan on what it could be? does anyone has an idea or run into the same issue? I've been trying for weeks now and nothing I'm about to take it to the dealer
here is a full Auto scan if someone could help that'll be awesome I'll PayPal some money to whoever helps me out
Thanks!
Thanks!
Wednesday,08,July,2020,09:41:43:50719
VCDS Version: 20.4.1.0 (x64)
VIN: 3VWDP7AJ0CM332726 License Plate: 790CZF
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 37 56
VIN: 3VWDP7AJ0CM332726 Mileage: 177330km-110187miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Malfunction 1010
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CJ HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1156
Revision: T4H06--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 78FFA6B80B15544633-802C
Readiness: 0010 0100
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 2041
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 000FCE5853C51C860B-8054
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B440C492508FC8D1222E6921F1061A70000
VCID: 7BF5B9B4FA237F5E5E-802E
Fault Status: 01100101
Reset counter: 107
Mileage: 177331 km
Date: 2014.11.29
Time: 09:24:54
Count: 3
Count: 12
Count: 12800
Count: 143
Count: 50176
Count: 252
Reset counter: 107
Mileage: 177331 km
Date: 2014.11.29
Time: 09:24:54
Count: 3
Count: 12
Count: 12800
Count: 320
Count: 50176
Count: 252
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AP HW: 5C0 820 047 AP
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000587157
VCID: 6ED380E079511AF6E9-803A
Reset counter: 144
Mileage: 329399 km
Date: 2016.07.09
Time: 00:02:26
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371258110384
Coding: 7A994F3808AB0B0000382000240884DD00C2500E60000000300000000000
Shop #: WSC 12345 123 61029
VCID: 2F6D5DE47EDB53FEA2-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0040262
Coding: 820000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
00975 - Heated Rear Window (Z1)
006 - Short to Plus
Fault Status: 01100110
Reset counter: 107
Mileage: 177331 km
Date: 2014.11.29
Time: 09:26:07
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM01WSGI
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 346752889FFD7026DF-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100007C120Y
Coding: 303242
Serial number: 3572MSME0C181542ZZZQ
Serial number: 3582MSME3E290442ZZZW
Serial number: 3516KSME754C4B11ZZZY
Serial number: 3526KSME2F082B11ZZZU
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6D5B1112ZZZY
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME5D4B1112ZZZX
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 107
Mileage: 177331 km
Date: 2020.07.08
Time: 09:25:41
Part No SW: 5C6 920 951 B HW: 5C6 920 951 B
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00123
VCID: 2A5B4CF04D3936D675-807E
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: 70EF9E98A3650C06FB-8024
Mileage: 329379 km
Date: 2016.07.05
Time: 17:11:01
Reset counter: 144
Reset counter: 144
Component: IMMO H04 0604
VCID: 6ADB8CF08DB9F6D6B5-803E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Mileage: 107865 km
Date: 2020.07.07
Time: 00:00:17
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 107865 km
Date: 2020.07.07
Time: 00:00:27
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4275242
Coding: 04010041010006000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 2541BFCC242719AE58-8070
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
1048627 - Rear Left Audio Signal Output
B1108 F0 [009] - Short Circuit Between Poles
Reset counter: 98
Mileage: 329308 km
Date: 2022.02.01
Time: 19:26:17
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Reset counter: 88
Mileage: 329308 km
Date: 2022.02.01
Time: 19:26:15
1048632 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Reset counter: 88
Mileage: 329308 km
Date: 2022.02.01
Time: 19:26:14
1048658 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 136
Mileage: 329345 km
Date: 2022.02.09
Time: 00:40:39
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 94
Mileage: 329333 km
Date: 2022.02.06
Time: 12:09:00
End-------------------------(Elapsed Time: 02:05)--------------------------
