Audi A3 Airbag Error
autocar17
UAE
C?ID=396783
Dear All,
I have an Audi A3, customer went to fix the evaporator for A/C. Drive well for 2 days then have this Airbag Issue. See VCDS Report.
I checked all wiring and everything looks good.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 20.4.0
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Wednesday,08,July,2020,12:31:58:26519
VIN: WAUZZZ8V9G1100231 License Plate:
Mileage: 121696km-75618mi Repair Order:
Control Module Part Number: 5Q0 959 655 AB HW: 5Q0 959 655 AB
 Component and/or Version: AirbagVW20 015 0388
 Software Coding: 98CCC000000000005C54000000C800000065
 Work Shop Code: WSC 06385 790 00016
 ASAM Dataset: EV_AirbaVW20SMEVW37X 002130 (AU37)
 VCID: 005879ABCA857A7B532-8054
10487296 - Control Module Does Not Match Vehicle
 B2006 00 [136] - -
 [ECU does not fit to vehicle configuration]
 Mileage: 121055 km
 Date: 2020.06.29
 Time: 18:35:22
9635072 - Control Module for Front Right Belt Tensioner
 B1305 00 [136] - -
 Mileage: 121055 km
 Date: 2020.06.29
 Time: 18:35:22
16712543 - Internal Control Module Memory Check Sum Error
 B2000 00 [136] - -
 [Electronic Control Unit Malfunction]
 Mileage: 120895 km
 Date: 2020.06.26
 Time: 13:51:09
Page 2
16712545 - Internal Control Module Memory Check Sum Error
 B2000 00 [136] - -
 Mileage: 120922 km
 Date: 2020.06.27
 Time: 00:49:19
Any help will be appreciated.
I suspect the only fix for that will be to replace the airbag module, but can you please post a complete Auto-Scan for context?
Also, please do not use the [Print] function in VCDS to post data here. Please use [Copy] or [Save] and in the latter case, open the saved file with Notepad and paste the contents here.
autocar17
UAE
C?ID=396783
Ok i will do as mentioned
Can i buy a used one with same part number and will it work?
What additional coding i need?
Any help
On an 8V A3, I expect the airbag module is part of the Component Protection constellation, so even a used one will require a trip to the dealer (or someone with access to the mothership's servers).
Personally, I would never install any used airbag components in my car. I would rather have no airbags at all than a system that contains explosives aimed at me and my passengers that I do not trust.
