Results 1 to 4 of 4
Thread: DSG Problems
    Verified VCDS User Dre892's Avatar
    Jul 2020
    New Zealand
    DSG Problems
    Hi everyone, Im new to Ross-Tech and just trying to sort out a problem on my brothers car. Its a Golf mk6 1.4 tsi. Recently when you put the car into Drive it gives a massive clunk and the car shakes, rpm lowers alot, sometime the engine dies too. If it doesn't die you can sometimes drive it but when it change to second gear the car goes into neutral and stops. It does not happen when you put it in Reverse. I have tried doing the basic settings on it but doesn't complete with success.
    What i would like to know is if i do it wrong or if its a clutch or mechatronic failure instead? I follow the steps on the following page http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0AM) , only problem is i can get the engine temp up but not gear temp because of not being able to drive it really. I have left it running but the temp stays at 27c.
    When i get to part 4|0|0|0 i start the car
    It the does its thing and gets to 255|9|0|
    Then Error:|Group060|Not|Available or sometime all boxes are just blank
    Tuesday,07,July,2020,17:34:04:05623
    VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
    VIN: WVWZZZ1KZBW177917   License Plate:
    Mileage: 97130km-60353mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZBW177917   Mileage: 97130km-60353miles
    Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
       Part No SW: 03C 906 027 CT    HW: 03C 907 309 G
       Component: MED17.5.5       G   0175
       Revision: LGH03---    Serial number:
       Coding: 0000077
       VCID: 75A2CEEB1CD4C12E28-8020
    Readiness: 0110 0101
       Part No SW: 0AM 300 051 L    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 9030
       Revision: 00043014    Serial number: CU501308225411
       Shop #: WSC 01972 002 1048576
       VCID: 332630F352209F1EC6-8066
    006013 - Dual Clutch
                   P177D - 000 - Torque too High - Intermittent
                        Reset counter: 10
                        Mileage: 97137 km
                        Date: 2014.11.28
                        Time: 23:33:26
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 133B600D09290001C81406E590200080350000
       VCID: 76A0C9E7C1D2CA3621-8022
       Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000001002
       VCID: 6E90E187B182F2F6E9-803A
       Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
       Component: BCM PQ35  H   104 0615
       Revision: 00104 AE
       Coding: 40180A3A88251AC0400800803400892443550088736D8D60648000200040
       VCID: 3A381DD7B54A6E5605-806E
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 02121  26  0512
       Coding: 009795
       Component: RLS 081210 05  54  0403
       Coding: 0B30AD
                        Fault Status: 00101010
                        Fault Frequency: 13
                        Reset counter: 67
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 23:07:50
                        Voltage: 14.20 V
                            Term 50 Off
                        Fault Status: 00101110
                        Reset counter: 66
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 23:17:28
                        Voltage: 14.20 V
                            Term 50 Off
       Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0012
       Revision: --------    Serial number: 12591032721366
       Coding: 108101
       VCID: 383C07DF8B467C46F3-806C
       Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
       Component: AirbagVW10G   013 0613
       Serial number: 003G7R002LYO
       Coding: 00003933
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 332630F39A209F1EC6-8066
       Serial number: 3572MSME116B605AZZZX
       Serial number: 3582MSME5E41025BZZZ-
       Serial number: 3512QSME3C56791AZZZ1
       Serial number: 3522QSME00197A10ZZZK
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JL1000LD
       Coding: 1892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76A0C9E7C9D2CA3621-8022
       Serial number: 50000000000000255011
       Coding: E30000
       Part No SW: 5K0 920 871     HW: 5K0 920 871
       Component: KOMBI         H20 0420
       Coding: 570F01
       VCID: 6B96E893829007DECE-803E
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 071210F2001839
       Coding: 350003
       VCID: 302C3FFF6336A406BB-8064
    00469 - Infotainment Databus in Single Wire Operation
                        Fault Status: 00101011
                        Reset counter: 67
                        Mileage: 97137 km
                        Date: 2014.11.28
                        Time: 23:11:28
    01304 - Radio
                        Reset counter: 66
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 17:59:51
       Component: IMMO          H20 0420
       VCID: 6A98ED978D6A1ED6B5-803E
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2120
       Coding: 0004790
       VCID: 322835F7AD3A9616CD-8066
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 000    3501
       Revision: 00H17000
       Shop #: WSC 58055 000 1048576
       VCID: 393A02DB704C654E0C-806C
       Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
       Component: Tuer-SG         009 2152
       Coding: 0005046
       VCID: 35220EEB5C54812EE8-8060
       Coding: 1443164
       VCID: 342433EF572E9826DF-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
                        Reset counter: 175
                        Mileage: 93424 km
                        Date: 2014.06.06
                        Time: 14:13:49
                        Voltage: 13.49 V
                            ABS 1
    Address 56: Radio
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Coding: 0000144
       VCID: 362009E741528A36E1-8062
    End----------(Elapsed Time: 01:05, VBatt start/end: 12.8V/12.3V)-----------
       Coding: 0000077
                        Reset counter: 10
                        Mileage: 97137 km
                        Date: 2014.11.28
                        Time: 23:33:26
       Revision: 00H31001
       Revision: 00003001
       Coding: 0000001002
       Revision: 00104 AE
       Coding: 009795
       Coding: 0B30AD
                        Fault Frequency: 13
                        Reset counter: 67
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 23:07:50
                        Voltage: 14.20 V
                            Term 50 Off
                        Reset counter: 66
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 23:17:28
                        Voltage: 14.20 V
                            Term 50 Off
       Coding: 108101
       Coding: 00003933
       Coding: 1892140000
       Coding: E30000
       Coding: 570F01
       Coding: 350003
                        Reset counter: 67
                        Mileage: 97137 km
                        Date: 2014.11.28
                        Time: 23:11:28
    01304 - Radio
                        Reset counter: 66
                        Mileage: 97137 km
                        Date: 2014.11.27
                        Time: 17:59:51
       Coding: 0004790
       Revision: 00H17000
       Coding: 0005046
       Coding: 1443164
       Coding: 00000022
       Coding: 00000022
                        Reset counter: 175
                        Mileage: 93424 km
                        Date: 2014.06.06
                        Time: 14:13:49
                        Voltage: 13.49 V
                            ABS 1
    Address 56: Radio
       Coding: 0000144
       Coding: 0000144
    End----(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Any advice would be appreciated
    Thanks in advance
    Andre
    Did you know firmware isn't up to date for TCU or ECU?
    Time to tear down and measure test mechanical components, not expect an adaption to make up for missing tolerances.
  3. Likes Dre892 liked this post
    Jul 2020
    New Zealand
    Update:
    I took out the mechatronics, gave it a good service, replace the oil and gearbox oil. The car was better from startup. Tried to do the basic settings again but this time would stop at random places. I drove it a few times after trying basic settings again and again... I finally got to a point where it would drive 100% in gear 1,3,5,7 but when changing to gear 2,4,6 or reversing the would be a big clutch delay. I left it for a few hours and did basic settings again and then accepted it. The car is now changing gears like i remember.
  5. Likes Jack@European_Parts, Uwe liked this post
  6. #4
    Did you know that is why we sand and polish the clutch pack with leading edges to wear in faster and blend to adapt kiss points?
