Results 1 to 4 of 4
Thread: VW T5.1 2.0tdi P0087 fault code..
    Dec 2015
    I have this fault code and have changed both fuel pumps and both fuel rail sensors for genuine new parts but still same fault code and limp mode..
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 15 17 18 19 25 37 56
    VIN: WV2ZZZ7HZBH116353   Mileage: 275640km-171274miles
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H41 9126
       Revision: 26H41---    Serial number: 00000000000000
       Coding: 0119401A230400080000
       Shop #: WSC 00208 210 87028
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
       ROD: EV_ECM20TDI01103L906019AM_002.rod
       VCID: 6DD1A88DBCF0B8EED9-8038
    5211 - Fuel Rail/System Pressure
              P0087 00 [101] - Too Low
                        Mileage: 275643 km
                        Date: 2020.07.04
                        Time: 11:20:26
                        Engine speed: 3985.00 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 88 km/h
                        Coolant temperature: 91 ∞C
                        Intake air temperature: 53 ∞C
                        Voltage terminal 30: 14.160 V
                        Unlearning counter according OBD: 80
                        Fuel temperature: 39.3 ∞C
                        Mean injection quantity: 44.84 mg/stroke
                        Rail pressure regulation: status-Bits 0-7: 5
                        Fuel high pressure: actual value: 1.6045e+006 hPa
                        High fuel pressure: specified value: 1.7969e+006 hPa
                        Pressure control valve adaptation factor: 1.0576
                        Fuel level: 20.00 l
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0105
       Revision: 00H43001
       Coding: 208724AD09A5049B24A59076AA6110
       Shop #: WSC 02756 790 49152
       VCID: 366347E181263B36E8-8062
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 AJ    HW: 7E5 907 047 AJ
       Component: Climatic-T5   H11 0203
       Revision: 00005001
       Coding: 0000000002
       Shop #: WSC 02757 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 77FD8AE5CEAC023E33-8022
       Part No SW: 7H0 937 087 F    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0230
       Revision: BO047001    Serial number: 0396 073110133
       Coding: A0B0793A0E612413922848103E2B8CD50000418F60040000300000000000
       Shop #: WSC 02754 790 12345
       VCID: 377D4AE5862CC23EF3-8062
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3311
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3311
       Subsystem 3 - Part No: 7E1 951 171
       Subsystem 5 - Part No: 7E1 951 171
       Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Serial number: 40000000000000824824
       Coding: E20000
    01758 - Bulbs for Brake Lamps
                        Fault Status: 00101011
                        Reset counter: 166
                        Date: 2014.11.25
                        Time: 09:26:22
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H06 0013
       Revision: --------    Serial number: 003HL004GNB9
       Shop #: WSC 02754 790 50316
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 356140ED9420302EE1-8060
       Part No SW: 7E0 920 970 C    HW: 7E0 920 970 C
       Component: KOMBI         H20 0220
       Coding: 160E00
       Shop #: WSC 02756 790 50316
       VCID: 2A5B63914D9E6FD67C-807E
    9453330 - Outside temperature sensor
              B103F 1B [008] - Resistance Too High
                        Reset counter: 163
                        Date: 2020.06.30
                        Time: 17:33:01
    Address 18: Aux. Heat        Labels: None
       Part No: 7E0 815 071 A
       Component: J737__Standheizung  0404
       Revision: 00085000    Serial number: 09019275D00000
       Coding: 0000031
       Shop #: WSC 02757 790 00000
       VCID: 23458EB5E2B4BE9E3F-8076
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0230
       Coding: 042300
       VCID: 70EFB1F9A3C25506F2-8024
       Component: IMMO          H20 0220
       VCID: 6ADBA3918D1EAFD6BC-803E
       Part No SW: 3C0 035 279 M    HW: 3C0 035 279 M
       Component: RNS315-EU   H52 0319
       Serial number: VWZAZ2M5986330
       Coding: 000004400400000000000002
       Shop #: WSC 00015 115 12345
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2D51688D7C7078EE99-8078
       Component: EUR_W_V9  0069
    1048632 - Antenna 1 for Radio
              B1119 13 [008] - Open Circuit
                        Reset counter: 167
                        Mileage: 275501 km
                        Date: 2020.06.29
                        Time: 00:01:21
    1048641 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 126
                        Mileage: 275501 km
                        Date: 2020.06.29
                        Time: 00:07:01
                        Correction for sound system: OK
                        Traffic sign display: OK
                        CD changer: OK
                        Status of antenna 2 for radio: ERROR
                        Digital radio (DAB): OK
                        Antenna diagnostic: OK
                        Telephone baseplate diagnostic: OK
                        Speaker status: OK
                        Rearview camera: OK
                        Telephone Transceiver: OK
    Fully loaded vw eos exclusive ..
    Component: R4 2,0L EDC H41 9126 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed?
    Was there not a firmware update to address this condition or is pump timing stroke correct?
    Pick a card?
    Part Version FL_03L906022CH 7538, 5920, 8739, 9126, 9970
    Dec 2015
    I thought it could be the fuel pump timing so I changed the belt and used the correct tools..
    Dec 2015
    I will call vw commercial tomorrow...
