I need some advice. I have brand new VCDS HEX-NET device. First of all I got message “SD critical error! Please ... “ Problem seemsed to be solved after I pressed and hold on red bottom on device for 50 seconds and then released it.
After I plugged device on car I got message “Sorry, no coding information available for this ECU... So my question is are those problems related somehow or what might be solution for that coding problem.
Regards,
Rain
Regards,
Rain
Tuesday,07,July,2020,19:53:17:23739
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ4GXEN121702 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 28 34 3B 3C 42
44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90 A9
C0
VIN: WAUZZZ4GXEN121702 Mileage: 201668km-125310miles
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 C HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0002
Revision: 57H25---
Coding: 322A403A25760B020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
ROD: EV_ECM30BTD0114G0907589C.rod
VCID: B424B1EE1F6754265F-80E0
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Part No SW: 4G0 927 158 L HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1006
Revision: --H16---
VCID: B73E86E20E11BF3E7A-80E2
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 49B7DF0592EDFBA0EB00
VCID: BB369AD232399B5E9E-80EE
0629 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 226
Mileage: 198667 km
Date: 2020.06.15
Time: 11:46:34
VzRef: 84
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 30
Uz: B9
Part No SW: 4H0 907 064 EP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0521
Coding: 05A92F06000000000000
VCID: FBB65AD27AB95B5EDE-80AE
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 10021400040728
Coding: 369200783D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: EA986F960D23D2D635-80BE
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001695812
Coding: 0907A01109749FE2A98100C320001800CF9C67082E080201000108546F01
Shop #: WSC 51220 001 104857
VCID: EFAE7E823EC137FE62-80BA
Component: WWS57X 140201 H37 0080
Serial number: 140204192535
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22234953
Coding: 0200FD
Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
Component: E1 - LDS H07 0044
Serial number: 27 01 2014 00001149
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000010021400010714
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000010021400010412
Coding: 110000
Serial number: B2188F07000000000001
Revision: 11001001 Serial number: 61061404400411
Coding: A9EB0C
VCID: F1AA78FA20F5210E74-80A4
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7F04010202
VCID: A81C559ED3AF20C6E3-80FC
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
[FAULT_MAR_PRE_MISALIGNMENT]
Fault Frequency: 8
Reset counter: 247
Mileage: 200527 km
Date: 2020.06.29
Time: 18:27:32
Control Module temperature: 21 °C
Voltage terminal 15: 14.131 V
Velocity_vehicle_reference: 26.54 m/s
Longitudinal_acceleration_vehicle_reference: -0.05 m/s²
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00GP41+
Coding: 30323436313330303339554A304C34473053
VCID: B6208BE6091B463661-80E2
Serial number: 3575HRB405L2B0IMD908
Serial number: 3585HRB405R2DGACB1RW
Serial number: 3515JRB400E50RN6G0D7
Serial number: 3525JRB400850T8IEODN
Serial number: 3554VRB400A50TIMPGRR
Serial number: 3564VRB400A50TIMB0FT
Revision: -------- Serial number: 90372NB5000L1
Coding: 0004FD
VCID: B83C85DE0B0FB04673-80EC
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 18 09 2013 D0312489
Part No SW: 4G9 920 950 M HW: 4G9 920 950 M
Component: TDieRdwAccNv H58 0621
Revision: 29131235 Serial number: 658070214596008
Coding: 138F21089F550008000600
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: BA389FD63D03A25685-80EE
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 G HW: 4H0 265 105 G
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20140124223615
Coding: 5D3F01
VCID: A6005BA6D1BB36B6D1-80F2
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001269218
Coding: 00CD077D00
VCID: F2A877F625F31A168D-80A6
Serial number: 2274692403
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13112800000000000501
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 040182646E6E645A5A253D3E00
VCID: FCB459CE7FB75C66D7-80A8
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 000702140001666
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: A71E56A2DEB12FBEEA-80F2
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 07021400041302
Coding: 21
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
VCID: B93A80DA3805A94E8C-80EC
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [009] - Signal Amplitude Too High
Fault Frequency: 210
Reset counter: 218
Mileage: 194474 km
Date: 2020.04.23
Time: 08:00:00
Voltage terminal 30: 13.32 V
Outside air temperature: 20.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 12030
Left Rear Upper Body Vent Motor-Specified value: 12030
Left Rear Upper Body Vent Motor-Stop open: 11429
Left Rear Upper Body Vent Motor-Stop closed: 10000
Left Rear Upper Body Vent Motor-Last active operating mode: 5
Left Rear Upper Body Vent Motor-Active operating mode before last: 6
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [008] - Signal Amplitude Too Low
Fault Frequency: 6
Reset counter: 3
Mileage: 201118 km
Date: 2020.07.03
Time: 15:06:39
Voltage terminal 30: 14.36 V
Outside air temperature: 22.0 °C
Left Rear Upper Body Vent Motor-Act.val.: 9399
Left Rear Upper Body Vent Motor-Specified value: 9399
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Fault Frequency: 63
Reset counter: 3
Mileage: 194481 km
Date: 2020.04.23
Time: 17:51:52
Voltage terminal 30: 14.47 V
Outside air temperature: 16.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 11730
Right Rear Upper Body Vent Motor-Specified value: 11730
Right Rear Upper Body Vent Motor-Stop open: 11429
Right Rear Upper Body Vent Motor-Stop closed: 10000
Right Rear Upper Body Vent Motor-Last active operating mode: 5
Right Rear Upper Body Vent Motor-Active operating mode before last: 6
0034 - Motor for Rear Right Upper Body Vent
B10D4 21 [008] - Signal Amplitude Too Low
Fault Frequency: 38
Reset counter: 3
Mileage: 194487 km
Date: 2020.04.23
Time: 18:41:20
Voltage terminal 30: 14.38 V
Outside air temperature: 17.5 °C
Right Rear Upper Body Vent Motor-Act.val.: 9699
Right Rear Upper Body Vent Motor-Specified value: 9699
Right Rear Upper Body Vent Motor-Active operating mode before last: 4
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 222
Mileage: 196067 km
Date: 2020.05.16
Time: 14:42:52
Outside air temperature: 14.0 °C
Left rear vent temperature: 8.8 °C
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008003
ROD: EV_AirSuspe_VW51.rod
VCID: AE10A386F14B7EF629-80FA
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Reset counter: 248
Mileage: 198601 km
Date: 2020.06.15
Time: 10:51:42
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H03 0056
Revision: -------- Serial number: EJ1BPA7E00VD7N
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G0 907 566 E HW: 4G0 907 566
Component: J769 SWA MasterH04 0040
Revision: 00H04000 Serial number: 6PZ 010 287-04
Coding: 0010104
VCID: B12AB8FA2875610E34-80E4
Subsystem 1 - Part No: 4G0 907 568 E
Component: J770 SWA Slave H04 0040
Subsystem 2 - Serial number: 6PZ 010 287-24
Subsystem 3 - Serial number: 5F28.01.1400H04000AMS14965ÿ
Subsystem 4 - Serial number: S14965ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16015C00628002080013
VCID: C5C2FC2A4CFDDDAEF8-8090
Fault Status: 01101100
Reset counter: 208
Mileage: 200823 km
Date: 2020.07.01
Time: 17:17:53
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0030264104
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B228B7F6E5735A164D-80E6
Revision: 00002001 Serial number: 0326664508
Coding: 01000E2820B93095832009842E010F470000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO2659864E
Coding: 901F00
Subsystem 2 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00005975631
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO26614801
Coding: 801F00
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 218
Mileage: 201653 km
Date: 2020.07.07
Time: 14:58:59
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000080126
Coding: 030000
VCID: 9D72744A84EDF56E80-80C8
Component: TSG BF H03 0507
Coding: 011F16015E00628002080002
VCID: C6C0FB2671FBD6B6F1-8092
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000000957598
ROD: EV_ParkiBrake_VW51.rod
VCID: AD12A48AFC4D05EE10-80F8
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140207-0002-210
Coding: 11226F601002A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227B20E7980477
Coding: 010003010000000001
Part No SW: 4G0 035 670 Q HW: 4G0 035 670 J
Component: H-BNT-EU H53 1034
Revision: -------- Serial number: 190B+0E7567941
Coding: 080100050003FFEF3DB0EB1E00000003080001000200000000
VCID: B12AB8FAE875610E34-80E4
Subsystem 1 - Part No: 8R0 060 884 GA
Component: EUR 2019 2802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD003SS45
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Serial number: 90349NB7001C7
Component: CD-Database 5571
Reset counter: 204
Mileage: 200387 km
Date: 2020.06.26
Time: 20:55:53
Text: DUA009,Front,M,0,0,6
Fault Frequency: 25
Reset counter: 3
Mileage: 201653 km
Date: 2020.07.07
Time: 14:03:47
Bin. Bits: 10111111 11111110
Bin. Bits: 10001110 10001110
Bin. Bits: 00000000 00010110
Bin. Bits: 00000000 00000000
Fault Frequency: 7
Reset counter: 3
Mileage: 201653 km
Date: 2020.07.07
Time: 14:04:08
Bin. Bits: 00000000 00011111
Bin. Bits: 00000000 00010100
03623 - Invalid Security/Release Code
Reset counter: 128
Mileage: 195085 km
Date: 2020.05.03
Time: 15:41:52
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: C9DAF01A60E539CE1C-809C
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H11 0100
Revision: 5G001001 Serial number: 00000326144003
Coding: 0109080000000000
VCID: F1AA78FA28F5210E74-80A4
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H08--- Serial number: 525 PA8J41G5V3
Coding: 1090005
VCID: A6005BA611BB36B6D1-80F2
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 026400983
Coding: 097205C011
ROD: EV_HDSGAu571.rod
VCID: B5228CEA141D4D2E68-80E0
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 K HW: 4G0 919 604 K
Component: HeadUpDisplay 005 0203
Coding: 470000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: B326B2F21A69531E46-80E6
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: FA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: A6005BA6D9BB36B6D1-80F2
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Reset counter: 4
Mileage: 194474 km
Date: 2020.04.23
Time: 07:59:48
Outside air temperature: -39.5 °C
Voltage terminal 15: 12.8 V
Control Module temperature: 20.0 °C
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7F04010202
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121102147
Coding: 04C0BB1E1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: B12AB8FAE075610E34-80E4
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 140122200825
VCID: AB16AA92C2590BDE0E-80FE
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0007
Serial number: 140131200492
VCID: A40441AEAF87C4A6CF-80F0
End----------(Elapsed Time: 02:51, VBatt start/end: 12.2V/12.1V)-----------
