Results 1 to 5 of 5
Thread: VCDS HEX-NET Pro problem
    Jun 2020
    Estonia
    I need some advice. I have brand new VCDS HEX-NET device. First of all I got message “SD critical error! Please ... “ Problem seemsed to be solved after I pressed and hold on red bottom on device for 50 seconds and then released it.
    After I plugged device on car I got message “Sorry, no coding information available for this ECU... So my question is are those problems related somehow or what might be solution for that coding problem.
    Regards,
    Rain
    Tuesday,07,July,2020,19:53:17:23739
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ4GXEN121702   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 22 28 34 3B 3C 42
              44 46 47 52 53 55 56 5F 62 69 6C 6D 72 82 85 8B 8E 8F 90 A9
              C0
    VIN: WAUZZZ4GXEN121702   Mileage: 201668km-125310miles
    Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
       Part No SW: 4G0 907 589 C    HW: 4G0 907 589
       Component: 3.0BTD EDC17  H25 0002
       Revision: 57H25---
       Coding: 322A403A25760B020000
       ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
       ROD: EV_ECM30BTD0114G0907589C.rod
       VCID: B424B1EE1F6754265F-80E0
    4483 - Function Restriction due to Faults in Other Modules
              U1113 00 [032] - -
       Part No SW: 4G0 927 158 L    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1006
       Revision: --H16---
       Coding: 000001
       VCID: B73E86E20E11BF3E7A-80E2
       Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
       Coding: 49B7DF0592EDFBA0EB00
       VCID: BB369AD232399B5E9E-80EE
    0629 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 226
                        Mileage: 198667 km
                        Date: 2020.06.15
                        Time: 11:46:34
                        VzRef: 84
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 30
                        Uz: B9
       Part No SW: 4H0 907 064 EP    HW: 4H0 907 064 EP
       Component: BCM2 2.0      H36 0521
       Coding: 05A92F06000000000000
       VCID: FBB65AD27AB95B5EDE-80AE
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0093
       Serial number: 10021400040728
       Coding: 369200783D
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: EA986F960D23D2D635-80BE
       Revision: 11012002    Serial number: 00000001695812
       Coding: 0907A01109749FE2A98100C320001800CF9C67082E080201000108546F01
       Shop #: WSC 51220 001 104857
       VCID: EFAE7E823EC137FE62-80BA
       Component: WWS57X 140201  H37 0080
       Serial number:         140204192535
       Coding: 0045F7
       Serial number: 22234953
       Coding: 0200FD
       Subsystem 3 - Part No SW: 4G0 941 531 AA    HW: 4G0 941 531 AA
       Component: E1 - LDS  H07 0044
       Serial number: 27 01 2014  00001149
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000010021400010714
       Coding: 110000
       Serial number: 00000010021400010412
       Coding: 110000
       Serial number: B2188F07000000000001
       Revision: 11001001    Serial number: 61061404400411
       Coding: A9EB0C
       VCID: F1AA78FA20F5210E74-80A4
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: A81C559ED3AF20C6E3-80FC
    12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] - -
              [FAULT_MAR_PRE_MISALIGNMENT]
                        Reset counter: 247
                        Mileage: 200527 km
                        Date: 2020.06.29
                        Time: 18:27:32
                        Control Module temperature: 21 °C
                        Voltage terminal 15: 14.131 V
                        Velocity_vehicle_reference: 26.54 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.05 m/s²
       Revision: --------    Serial number: 003JG00GP41+
       Coding: 30323436313330303339554A304C34473053
       VCID: B6208BE6091B463661-80E2
       Serial number: 3575HRB405L2B0IMD908
       Serial number: 3585HRB405R2DGACB1RW
       Serial number: 3515JRB400E50RN6G0D7
       Serial number: 3525JRB400850T8IEODN
       Serial number: 3554VRB400A50TIMPGRR
       Serial number: 3564VRB400A50TIMB0FT
       Revision: --------    Serial number: 90372NB5000L1
       Coding: 0004FD
       VCID: B83C85DE0B0FB04673-80EC
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 18 09 2013  D0312489
       Part No SW: 4G9 920 950 M    HW: 4G9 920 950 M
       Component: TDieRdwAccNv  H58 0621
       Revision: 29131235    Serial number: 658070214596008
       Coding: 138F21089F550008000600
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: BA389FD63D03A25685-80EE
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
       Component: Standheizung  H24 0260
       Revision: 66006006    Serial number: 20140124223615
       Coding: 5D3F01
       VCID: A6005BA6D1BB36B6D1-80F2
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001269218
       Coding: 00CD077D00
       VCID: F2A877F625F31A168D-80A6
       Serial number: 2274692403
       Voltage stabilizer:
       Serial number: 13112800000000000501
       Revision: AA001002
       Coding: 040182646E6E645A5A253D3E00
       VCID: FCB459CE7FB75C66D7-80A8
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H16 0013
       Serial number: 000702140001666
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: A71E56A2DEB12FBEEA-80F2
       Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
       Component: KLIMA FOND    H08 0093
       Serial number: 07021400041302
       Coding: 21
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: B93A80DA3805A94E8C-80EC
    0025 - Motor for Rear Left Upper Body Vent
              B10D3 22 [009] - Signal Amplitude Too High
                        Fault Frequency: 210
                        Reset counter: 218
                        Mileage: 194474 km
                        Date: 2020.04.23
                        Time: 08:00:00
                        Voltage terminal 30: 13.32 V
                        Outside air temperature: 20.5 °C
                        Left Rear Upper Body Vent Motor-Act.val.: 12030
                        Left Rear Upper Body Vent Motor-Specified value: 12030
                        Left Rear Upper Body Vent Motor-Stop open: 11429
                        Left Rear Upper Body Vent Motor-Stop closed: 10000
                        Left Rear Upper Body Vent Motor-Last active operating mode: 5
                        Left Rear Upper Body Vent Motor-Active operating mode before last: 6
    0026 - Motor for Rear Left Upper Body Vent
              B10D3 21 [008] - Signal Amplitude Too Low
                        Reset counter: 3
                        Mileage: 201118 km
                        Date: 2020.07.03
                        Time: 15:06:39
                        Voltage terminal 30: 14.36 V
                        Outside air temperature: 22.0 °C
                        Left Rear Upper Body Vent Motor-Act.val.: 9399
                        Left Rear Upper Body Vent Motor-Specified value: 9399
    0033 - Motor for Rear Right Upper Body Vent
              B10D4 22 [008] - Signal Amplitude Too High
                        Fault Frequency: 63
                        Reset counter: 3
                        Mileage: 194481 km
                        Date: 2020.04.23
                        Time: 17:51:52
                        Voltage terminal 30: 14.47 V
                        Outside air temperature: 16.0 °C
                        Right Rear Upper Body Vent Motor-Act.val.: 11730
                        Right Rear Upper Body Vent Motor-Specified value: 11730
                        Right Rear Upper Body Vent Motor-Stop open: 11429
                        Right Rear Upper Body Vent Motor-Stop closed: 10000
                        Right Rear Upper Body Vent Motor-Last active operating mode: 5
                        Right Rear Upper Body Vent Motor-Active operating mode before last: 6
    0034 - Motor for Rear Right Upper Body Vent
              B10D4 21 [008] - Signal Amplitude Too Low
                        Fault Frequency: 38
                        Reset counter: 3
                        Mileage: 194487 km
                        Date: 2020.04.23
                        Time: 18:41:20
                        Voltage terminal 30: 14.38 V
                        Outside air temperature: 17.5 °C
                        Right Rear Upper Body Vent Motor-Act.val.: 9699
                        Right Rear Upper Body Vent Motor-Specified value: 9699
                        Right Rear Upper Body Vent Motor-Active operating mode before last: 4
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 222
                        Mileage: 196067 km
                        Date: 2020.05.16
                        Time: 14:42:52
                        Outside air temperature: 14.0 °C
                        Left rear vent temperature: 8.8 °C
       Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H18 0782
       Coding: 008003
       ROD: EV_AirSuspe_VW51.rod
       VCID: AE10A386F14B7EF629-80FA
              C10C8 00 [008] - -
                        Reset counter: 248
                        Mileage: 198601 km
                        Date: 2020.06.15
                        Time: 10:51:42
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E00VD7N
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Part No SW: 4G0 907 566 E    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0040
       Revision: 00H04000    Serial number: 6PZ 010 287-04
       Coding: 0010104
       VCID: B12AB8FA2875610E34-80E4
       Subsystem 1 - Part No: 4G0 907 568 E
       Component: J770  SWA Slave H04 0040
       Subsystem 2 - Serial number: 6PZ 010 287-24
       Subsystem 3 - Serial number: 5F28.01.1400H04000AMS14965˙
       Subsystem 4 - Serial number: S14965˙
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F16015C00628002080013
       VCID: C5C2FC2A4CFDDDAEF8-8090
                        Reset counter: 208
                        Mileage: 200823 km
                        Date: 2020.07.01
                        Time: 17:17:53
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0030264104
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: B228B7F6E5735A164D-80E6
       Revision: 00002001    Serial number: 0326664508
       Coding: 01000E2820B93095832009842E010F470000000000000000000000000000
       Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:     WOO2659864E
       Coding: 901F00
       Subsystem 2 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
       Serial number: 0000000AP00005975631
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     WOO26614801
       Coding: 801F00
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 218
                        Mileage: 201653 km
                        Date: 2020.07.07
                        Time: 14:58:59
       Revision: CJ007001    Serial number: 00000000080126
       Coding: 030000
       VCID: 9D72744A84EDF56E80-80C8
       Coding: 011F16015E00628002080002
       VCID: C6C0FB2671FBD6B6F1-8092
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000000957598
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AD12A48AFC4D05EE10-80F8
       Serial number: 140207-0002-210
       Coding: 11226F601002A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227B20E7980477
       Coding: 010003010000000001
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 J
       Component: H-BNT-EU      H53 1034
       Revision: --------    Serial number: 190B+0E7567941
       Coding: 080100050003FFEF3DB0EB1E00000003080001000200000000
       VCID: B12AB8FAE875610E34-80E4
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD003SS45
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349NB7001C7
       Component: CD-Database  5571
                        Reset counter: 204
                        Mileage: 200387 km
                        Date: 2020.06.26
                        Time: 20:55:53
                        Text: DUA009,Front,M,0,0,6
                        Fault Frequency: 25
                        Reset counter: 3
                        Mileage: 201653 km
                        Date: 2020.07.07
                        Time: 14:03:47
                        Bin. Bits: 10111111 11111110
                        Bin. Bits: 10001110 10001110
                        Bin. Bits: 00000000 00010110
                        Bin. Bits: 00000000 00000000
    03278 - Functionality Limited due to Missing Messages
                        Fault Frequency: 7
                        Reset counter: 3
                        Mileage: 201653 km
                        Date: 2020.07.07
                        Time: 14:04:08
                        Bin. Bits: 00000000 00011111
                        Bin. Bits: 00000000 00010100
    03623 - Invalid Security/Release Code
                        Reset counter: 128
                        Mileage: 195085 km
                        Date: 2020.05.03
                        Time: 15:41:52
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Coding: 010F14004000628002080002
       VCID: C9DAF01A60E539CE1C-809C
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H11 0100
       Revision: 5G001001    Serial number: 00000326144003
       Coding: 0109080000000000
       VCID: F1AA78FA28F5210E74-80A4
       Revision: --H08---    Serial number: 525 PA8J41G5V3
       Coding: 1090005
       VCID: A6005BA611BB36B6D1-80F2
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 026400983
       Coding: 097205C011
       ROD: EV_HDSGAu571.rod
       VCID: B5228CEA141D4D2E68-80E0
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
       Component: HeadUpDisplay 005 0203
       Coding: 470000
       ASAM Dataset: EV_HUDContiC7 001023
       ROD: EV_HUDContiC7.rod
       VCID: B326B2F21A69531E46-80E6
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: FA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: A6005BA6D9BB36B6D1-80F2
    0001 - Front Heater for Lane-Holding Assist
              C1101 15 [008] - Open or Short to Plus
                        Reset counter: 4
                        Mileage: 194474 km
                        Date: 2020.04.23
                        Time: 07:59:48
                        Outside air temperature: -39.5 °C
                        Voltage terminal 15: 12.8 V
                        Control Module temperature: 20.0 °C
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000121102147
       Coding: 04C0BB1E1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: B12AB8FAE075610E34-80E4
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
       Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 140122200825
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: AB16AA92C2590BDE0E-80FE
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0007
       Serial number: 140131200492
       VCID: A40441AEAF87C4A6CF-80F0
    End----------(Elapsed Time: 02:51, VBatt start/end: 12.2V/12.1V)-----------
    Is there a specific procedure that you are trying to perform? Many of those modules are UDS, in which case any modifications that can be done would often be found under adaptations and not coding, have you checked there?
    Jun 2020
    Estonia
    53- Parking Brake. Tried to deactivate automatic parking brake when door is open. Under coding I got notification “Sorry, no coding information available for this ECU..
    29-Left Light; 39 Right Light Both are giving notifications "No Response from Controller"
    Quote Originally Posted by ReneK123 View Post
    I don't think that tweak is done in the parking brake module itself; more likely one of the BCMs, either 09 or 46.
    The car does not those modules. Headlight control is by 55-Headlight Range.
    I take that back.
    Have a look at the Adaptation channels in 53-Parking Brake. Maybe make and post a map of those channels before you change any of them.
