2013 Beetle 2.0 Turbo, mulltiple codes- everyone's stumped. Please help.
herbiemania
C?ID=329122
2013 Beetle 2.0 Turbo with DSG Transmission and just over 73k miles, experiencing problems that nobody can seem to figure out. It all began with a stumbling at idle and then moved to stalling at idle. Driving above idle was normal. Originally no check engine or EPC lights came on. Codes showed fuel pressure too high, too low, and misfires on all cylinders. Had the fuel pressure switch replaced. Ran great for a month and then same issue once again. Replaced the fuel pressure switch again with a new Bosch unit. Drove good for another month and then the same issues. This time I would get the check engine light and EPC lights but they would go off. Took it to a mechanic friend who said that the issue was a tear in the diaphragm on the valve cover. Replaced it. On my way home the car stalled out again. Keep in mind that all through this mess the car was showing the same codes for fuel pressure too high and too low, and misfires on all cylinders. I bought this car four years ago with 22k on it. Here is a list of every repair done so far in addition to regular services. Water pump replaced and supposedly a carbon cleaning of the valves. Fuel pressure switch, diaphragm, control module over in tank fuel pump, and the in tank fuel pump have been replaced. Also had the upper timing cover seal done due to an oil leak. I also just replaced the spark plugs and coil packs just to be on the safe side. People have told me it's carbon on the valves, crank seal between the engine and transmission, and a crank position sensor. My mechanic friend said the crank sensor checked out ok. The last time he had it in his shop he replaced the in tank fuel pump and said he drove it for two days without issue. When I picked it up it stalled on me again just like before. Now my friend doesn't want to work on it and I am at a loss. This guy has worked on these engines since day one so he is very familiar with them. My newest VW prior to this was a MK3 Golf so I am several generations behind. I'd rather not take it to the dealer but if I have to I'd like to know what I might be facing going in. I've driven the car twice in the last few months. It's just sitting in my driveway. I occasionally charge the battery to keep it up. I'm totally new here and am hoping someone has had a similar issue. I hate to just throw parts at it. I bought the software just to repair this car and it has not been helpful. :banghead: I just ran codes again and it has some new ones along with the same old ones. Here's the list.
Tuesday,07,July,2020,12:24:53:10234
VIN:    License Plate:
Mileage: 118340km-73533mi   Repair Order:
Chassis Type: AT-VW32 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 56 77
VIN: 3VWV67ATXDM613460   Mileage: 118340km-73533miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FL    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 4354
   Revision: P3H07---    Serial number:
   Coding: 0403010A1C070160
   VCID: 7AAD0F9590DD267B1D6-802E
7 Faults Found:
000402 - Fuel Pressure Sensor (G247)
               P0192 - 000 - Short to GND - Intermittent
                    Fault Frequency: 17
                    Mileage: 118321 km
                    Date: 2014.10.12
                    Time: 19:19:07
                    RPM: 130 /min
                    Load: 77.2 %
                    Temperature: 33.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.684 V
               P0300 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 118321 km
                    Date: 2014.10.12
                    Time: 19:19:34
                    RPM: 740 /min
                    Load: 36.8 %
                    Temperature: 112.0°C
                    Temperature: 45.0°C
                    Voltage: 13.462 V
000136 - Fuel Rail/System Pressure
               P0088 - 000 - Too High - Intermittent
                    Mileage: 118329 km
                    Date: 2014.10.12
                    Time: 19:26:12
                    RPM: 872 /min
                    Load: 25.9 %
                    Speed: 3.0 km/h
                    Temperature: 110.0°C
                    Temperature: 44.0°C
                    Voltage: 13.462 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - MIL ON
                    Mileage: 118339 km
                    Date: 2014.10.12
                    Time: 19:34:27
                    RPM: 1887 /min
                    Load: 83.1 %
                    Speed: 73.0 km/h
                    Temperature: 111.0°C
                    Temperature: 42.0°C
                    Voltage: 13.462 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - MIL ON
                    Mileage: 118339 km
                    Date: 2014.10.12
                    Time: 19:34:27
                    RPM: 1887 /min
                    Load: 83.1 %
                    Speed: 73.0 km/h
                    Temperature: 42.0°C
                    Voltage: 13.462 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - MIL ON
                    Mileage: 118339 km
                    Date: 2014.10.12
                    Time: 19:34:27
                    RPM: 1887 /min
                    Load: 83.1 %
                    Speed: 73.0 km/h
                    Temperature: 42.0°C
                    Voltage: 13.462 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - MIL ON
                    Mileage: 118339 km
                    Date: 2014.10.12
                    Time: 19:34:27
                    RPM: 1887 /min
                    Load: 83.1 %
                    Speed: 73.0 km/h
                    Temperature: 42.0°C
                    Voltage: 13.462 V
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3523
   Revision: 05551213    Serial number: 00001205310735
   VCID: 25170CE949E37983004-8070
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: F14B6016492300FD8F0F06EA92190041A71800
   VCID: 2E05F3C510153ADBF1E-807A
02214 - Tire Pressure Warning
                    Reset counter: 125
                    Mileage: 117711 km
                    Date: 2014.06.18
                    Time: 12:43:11
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 49408
                    Count: 254
                    Count: 64512
                    Fault Status: 00101101
                    Reset counter: 150
                    Mileage: 118222 km
                    Date: 2014.08.15
                    Time: 15:08:21
                    Count: 14
                    Count: 12800
                    Count: 8193
                    Count: 50176
                    Count: 256
                    Count: 255
   Part No SW: 5C0 820 047 BC    HW: 5C0 820 047 BC
   Component: J301  Klimaanlage   0204
   Revision: 2001111S    Serial number: 00000001107160
   VCID: 629D57F5184DCEBB256-8036
   Part No SW: 5C5 937 087 A    HW: 5C5 937 087 A
   Component: BCM25 JLB H+3 H68 0256
   Revision: B6068001    Serial number: 04431187120033
   Coding: 3BBC2918088B080000A02800640D84C400C2400F60840000B20004000000
   VCID: 3039EDBD0A212C2BE32-8064
   Subsystem 1 - Part No SW: 5C5 959 801 M    HW: 5C5 959 801 M
   Component: J386__TSG_FT  011 1032
   Coding: 800000
   Subsystem 2 - Part No SW: 5C5 959 802 P    HW: 5C5 959 802 P
   Component: J387__TSG_BT  011 1032
   Coding: 800000
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 153
00447 - Function Limitation due to Over-Voltage
                    Reset counter: 153
03444 - Ignition Starter Switch
                    Fault Frequency: 140
                    Reset counter: 113
                    Mileage: 117703 km
                    Date: 2014.05.13
                    Time: 13:32:35
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM01YEA$
   Coding: 00004E45
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40D9BD7DBA01BCAB132-8014
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000GUA40U
   Coding: 30304E
   Serial number: 3572MSME7C4B7162ZZZ0
   Serial number: 3582MSME5D4C7162ZZZ1
   Subsystem 4 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME341D731BZZZ.
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3566LSME7D1B731BZZZ6
   Part No SW: 5C5 920 950 F    HW: 5C5 920 950 F
   Component: KOMBI         H22 0103
   Revision: X0022005    Serial number:
   Coding: 250A01
   Shop #: WSC 00066 000 00126
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 2C01F9CD268948CBDFA-8078
   Part No SW: 6N0 909 901     HW: 5C5 937 087 A
   Component: GW-K-CAN TP20 H68 0256
   Revision: B6068001
   Coding: 402000
   VCID: 70B92DBDCAA16C2BA32-8024
   Part No SW: 5K0 953 234     HW: 5C5 920 950 F
   Component: IMMO          H22 0103
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A8D3FD5ECFD96FBED6-803E
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 372BD6A1E34FFB13A28-8062
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6M3398810
   Coding: 05000400040002
   VCID: 231312F14BD787B36E0-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007662857705
   Coding: 0A10040000010100
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2DCF95DCDDE67B5D6-806E
9458195 - Control Module for Cellular Telephone
          B1052 13 [008] - Open Circuit
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                    Fault Frequency: 124
                    Reset counter: 153
                    Mileage: 117703 km
                    Date: 2019.12.18
                    Time: 21:43:23
End----------(Elapsed Time: 00:54, VBatt start/end: 12.0V/12.1V)-----------
Hi and welcome.
Fuel Pressure Sensor (G247) - Short to GND - Intermittent
This is surely an electrical fault. If the car were mine, I would start with here. Do you have wiring diagrams for this car?
herbiemania
C?ID=329122
I might have access to ones for a 2012 model. Not sure if they are the same. Not even sure where to begin.
First OP isn't this car under useful life warranty for 10/120K?
Are you going to try and get reimbursed for all those aforementioned repairs and this one provided it isn't for example from rodent damage or from an outside influence such as accident?
I don't see injectors or intake on this list and are they not extended for warranty even by the OEM including issues with the harness for widespread inadequacy of useful life function warranted of a safety recall?
Have you checked with EPA, CARB and NHTSA to cover yourself?
The aforementioned said by Uwe & I agree, have you ever JPPSG yet and the entire thread?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Have you familiarized circuits in WD by RTFB and qualified them with load light and function of ECU stack by decade box?
You would be surprised what can be achieved with a tone generator and load light even without an RTFB to isolate and find tracks or test them.
herbiemania
C?ID=329122
Brand new here so I appreciate the tips. Will check out the links.
herbiemania
C?ID=329122
Hi and welcome.
Has anyone actually experienced a ground issue like mentioned above? If so, where were the grounds located that were problematic?
herbiemania
C?ID=329122
The car went back to driving normal. Cleared codes and has been driving fine for a week.
They will ALL be back shortly after some brief CAN messages............. :p
Do not worry VCDS will be there to display the conduct code messages.
Larry Manton
C?ID=112505
As Jack stated they don't fix themselves, codes will be back. Up side runs good when it runs, so probably good mechanically.
On the WIRING thought I did not like this one.00532 - Supply Voltage B+
Reset counter: 153
Sometimes if alternator does not see a target circuit to battery, I,E. Alternator it can go ballistic, just a thought but alternator for some reason is not happy occasioaly, again as stated a WIRING issue. Would be interesting to look at the ripple of the alternator. Also is it surging causing fuel pressure to pulse?
Larry
herbiemania
C?ID=329122
Larry,
Thank you for your input. The car did go back to the problems again, and then "fixed" itself again today. Seems this is now the established pattern for whatever is going on. I ended up taking it to the VW dealer to have them check it out. I have a friend who is a tech there so I hope it will be in good hands. I've provided him all of the back story and will forward your input as well. If he is able to determine the issue I will post the outcome here. This is the newest VW I have ever owned (and the most complex). I've always worked on my own vehicles but this one seems to be beyond my expertise. I think I might just go back to driving the older VWs again.
herbiemania
C?ID=329122
Just wanted to update all of you. I took my car to an independent VW shop that has been working on VWs since the 90s. He could not resolve the issue but thought it might be the crankshaft seal. Took it to the dealer and they guessed the same. Said it would cost $2k but no guarantee it would fix the problem. Went to a third shop (ex dealer tech) to have the seal replaced. He questioned why I wanted to replace it and then asked for some time to diagnose. Turned out that the issue was a wiring harness under the intake manifold rubbing and occasionally shorting things out. The rubbing had caused some small cuts in the wiring. He sealed up the wires and rerouted them and the car has driven perfect ever since.
thigg12
C?ID=371417
I appreciate the follow through on this one as I am having similar problems with my Tiguan and it's been an on and off battle for the last 2 years. No one VW included seems to be able ot figure it out. Lack of CEL and overall "intermittent" driveability issues.
Do you know what wiring harness they repaired? Was it the one connected to the G247 sensor? If you don't mind me asking, how much did your mechanic run you? Did they need to remove intake?
