Results 1 to 9 of 9
Thread: Audi A3 with entertainment fault
    Feb 2017
    Hello All
    Looking for some advice with a 2013 Audi A3 RHD customer complaint is on drivers side of car no sound front or rear from speakers fault codes showing as tweeters. I have disconnected both doors and tweeter at front but still showing short has any one had this before codes are 0513 0518 (B1064) (B1068)
    File Autoscan below many thanks
    Tuesday,07,July,2020,09:50:02:02134
    VCDS Version: 20.4.1.0
    VIN: WAUZZZ8V8DA026800   License Plate: DY13ONG
    Mileage: 174561km-108467mi   Repair Order: daz
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V8DA026800   Mileage: 174561km-108467miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   X22 4941
       Revision: 83X22---
       Coding: 02190012030501082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79FE67A8F8D1044E4C-802C
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 12F18AA220220A72017F060001C3294851045080608094F20079003485
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7DF673B8ECF9386E60-8028
       Part No SW: 8V0 820 043     HW: 8V0 820 043
       Component: AC Automat    H11 0031
       Revision: 20019000    Serial number: 00000000029658
       Coding: 03100104002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
       VCID: 6FEA59F0B6955AFEE2-803A
       Serial number: FB18C166000000000001
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011301002291
       Coding: 07000A42C2C122FD03844000B31C07A8000C000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 4684DC54F9AFBBB671-8012
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 121120  041 0580
       Serial number:         121210004355
       Coding: 0A47F7
       Serial number: 20856722
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 15 09 2012  00000025
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY123172CS3
       Serial number: 00000000000055255932
    524556 - Internal Control Module Memory Check Sum Error
              B2000 96 [009] - Component internal failure
                        Mileage: 121977 km
                        Date: 2018.01.13
                        Time: 13:09:45
       Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  009 0026
       Revision: --------    Serial number: 60831300414948
       Coding: 0000040001
       ASAM Dataset: EV_EPHVA14AU3700000 002015
       VCID: 377AA1908E45D23EFA-8062
       Serial number: 003M2R003VMO
       ROD: EV_AirbaVW20SMEVW37X_VW48.rod
       VCID: 4B92ED60E2CD46DEAE-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 000 801 13
       Serial number: 35767000000C3B8D7C08
       Subsystem 2 - Part No SW: -----------    HW: 480 001 201 13
       Serial number: 3586700000006B695C0Z
       Subsystem 3 - Part No SW: -----------    HW: 480 400 201 13
       Serial number: 3516502BF0D5D602F12J
       Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
       Serial number: 3526502BB0D5D60402EG
       Subsystem 5 - Part No SW: -----------    HW: 480 402 711 12
       Serial number: 3556502B10D5D6242197
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 12
       Serial number: 2286502AB0BE4C3280DR
       Subsystem 7 - Part No SW: -----------    HW: 480 401 012 12
       Serial number: 2296502B30CAF1645209
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 207 12
       Serial number: 2306502A90BE4C31F2BO
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
       Revision: --------    Serial number: 04011308491614
       Coding: 8408
       ROD: EV_SMLSKLOMQB_009_AU37.rod
       VCID: 77FA6190CEC5123E3A-8022
    No ASAM data for: "EV_SMLSKLOMQB" (AU37)
       Part No SW: 8V0 920 970 B    HW: 8V0 920 970 B
       Component: KOMBI         H24 0570
       Coding: 278509002B8046000100E800000000
       VCID: 3B72BDA0B26DF65E1E-806E
       Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
       Component: GW MQB High   122 1126
       Revision: --------    Serial number: 0000183404
       Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 008010
       ROD: EV_GatewLear_008.rod
       VCID: 3878A2AC835BDD46F3-806C
       Serial number: 17 12 2012  A0137774
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000002990788699
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 11121200090448
       Coding: 001C8E204001040000001002
       VCID: 3F8AC9B0A675EA7E32-806A
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D76B3B8AC79F86E20-8068
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 24111200010677
       Coding: 001C86204001040000001002
       VCID: 3E74B4B4A17FE37639-806A
       Component: LWR-ECU       005 0070
       Coding: 019E000001000000
       VCID: 75E66B98D4C9602E28-8020
       Part No SW: 8V0 035 044 J    HW: 8V0 035 044
       Component: MU-H-TN-EU    H40 0198
       Serial number: A041A0D7509464
       Coding: 01730301FF0A000021110001000A00102F00010701000100DE
       ROD: EV_MUHig6C3HBAS_VW48.rod
       Subsystem 1 - Part No SW: V03 959 800 KN    HW: -----------
       Component: ECE 2013  --- 0041
       Subsystem 2 - Part No SW: 8V0 919 604 A    HW: 8V0 919 604 A
       Component: DU High  H47 0013
       Serial number: AUZ8Z9CG1001HM
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 H    HW: 8V0 919 614 D
       Component: ControlUnit_H  H64 0764
       Serial number: C1000003101200010070
       Component: Gracenote  --- 1007
    0513 - Rear Right Treble Speaker
              B1068 13 [009] - Open Circuit
                        Reset counter: 83
                        Mileage: 174561 km
                        Date: 2020.07.07
                        Time: 09:31:05
                        Voltage terminal 30: 12.3 V
              B1064 13 [009] - Open Circuit
                        Reset counter: 83
                        Mileage: 174561 km
                        Date: 2020.07.07
                        Time: 09:31:05
       Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
       Component: TSG HFS       010 0006
       Serial number: 18121200010091
       Coding: 000C86204001040000001002
       VCID: 418ECF48D0819C8E44-8014
       Component: TSG HBFS      010 0006
       Serial number: 18121200010103
    End-------------------------(Elapsed Time: 04:17)--------------------------
    Those faults don't show "short", they show "open".
    Got wiring diagrams and a DVOM?
    ^^^ wingman: interesting DTCs in the hex5F module in your scan - not so much because of the faults described, but more because of the faults not described!!
    On my A3 (which is also RHD) - the output arrangement where the hex5F module is used as the amplifier is fairly simple in that the 4 x channels (front/rear, left/right) have their Base/Treble speakers connected in parallel. In your scan, there are no Base speaker errors which imply that the open circuit fault (for both front/rear right channels) must be downstream of the base/treble connection in the door wiring harness.
    The other interesting feature about your "downstream" DTCs is that they have both occurred in quite unconnected parts of the wiring loom (i.e behind 2 x separate door skins) - suggesting that they may have resulted from human intervention, rather than being the result of inherent faults in a the vehicle's wiring-infrastructure/equipment!
    I'm a firm believer in applying Occum's razor to any diagnostic exercise and I have the upmost respect for any advice that Uwe provides - but in this particular instance, before you fire-up the DVOM, perhaps it might be prudent for your client to answer some questions, maybe?
  4. Likes Uwe, downtime, Jack@European_Parts liked this post
    Feb 2017
    Thanks for reply guys, the VCDS scan was with both front doors disconnected, but it was still showing a fault as a short I also scaned car with TEXA diagnostics and got fault code B106813 and B106413 saying open circuit, when putting VCDS on to output tests would not do it due to fault.. Does any one know where the MMI amp unit is on the card and I will meter speakers out? or does anyone have a diagram.. forgot to mention when radio is playing the front right tweeter sometimes cracks as if a short
    May 2017
    Again, they are not shorted, they are OPEN like Uwe stated. Means the wiring is cut from somewhere.
    Usual suspect is the wiring between chassis and the door. The black rubber, pop it out from the door side and check the wiring is intact.
    The MMI unit is in the glove box. You need special radio removal tool to get it out :
    But I would do what Don suggested first, ask the customer what they have done
  7. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Thanks for reply, I have had both looms for doors out knowing this is common problem and they are fine, when I first scanned it, it came up with short on front and rear right channel speaker system. I then disconnected front windscreen tweeter, fault still showed no sound from right speakers, then disconnected one loom at a time with all disconnected still came up with fault code on tweeter, and still left speaker sometimes cracked as if short, but left speakers worked fine, I have not got customers car back in garage as yet, thought i would do some research help with you guys. Not seen MMI unit in glove box? does it have a separate amp? if so where will it be!
    May 2017
    Which type of unit it is? One on the left or one on the right?
    Left one I think the unit is integrated to the controls and is one unit. Right side is only display and the MMI unit or the brains, is visible when you open the glovebox
  11. #8
    Feb 2017
    Thanks for that it is the one on the right, does any one have a wiring diagram for the unit
  12. #9
    May 2017
    Buy one hour access to Erwin Audi and you can download all the schematics, workshop guides etc. Price is only 8€ for one hour including printing rights.
  13. Likes DV52, Uwe, PetrolDave liked this post
