Hello All
Looking for some advice with a 2013 Audi A3 RHD customer complaint is on drivers side of car no sound front or rear from speakers fault codes showing as tweeters. I have disconnected both doors and tweeter at front but still showing short has any one had this before codes are 0513 0518 (B1064) (B1068)
File Autoscan below many thanks
Tuesday,07,July,2020,09:50:02:02134
VCDS Version: 20.4.1.0
VIN: WAUZZZ8V8DA026800 License Plate: DY13ONG
Mileage: 174561km-108467mi Repair Order: daz
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V8DA026800 Mileage: 174561km-108467miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC X22 4941
Revision: 83X22---
Coding: 02190012030501082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79FE67A8F8D1044E4C-802C
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 12F18AA220220A72017F060001C3294851045080608094F20079003485
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DF673B8ECF9386E60-8028
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H11 0031
Revision: 20019000 Serial number: 00000000029658
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 6FEA59F0B6955AFEE2-803A
Serial number: FB18C166000000000001
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011301002291
Coding: 07000A42C2C122FD03844000B31C07A8000C000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 4684DC54F9AFBBB671-8012
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 121120 041 0580
Serial number: 121210004355
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 20856722
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Serial number: 15 09 2012 00000025
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY123172CS3
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000055255932
524556 - Internal Control Module Memory Check Sum Error
B2000 96 [009] - Component internal failure
Mileage: 121977 km
Date: 2018.01.13
Time: 13:09:45
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831300414948
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002015
VCID: 377AA1908E45D23EFA-8062
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Serial number: 003M2R003VMO
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4B92ED60E2CD46DEAE-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 801 13
Serial number: 35767000000C3B8D7C08
Subsystem 2 - Part No SW: ----------- HW: 480 001 201 13
Serial number: 3586700000006B695C0Z
Subsystem 3 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3516502BF0D5D602F12J
Subsystem 4 - Part No SW: ----------- HW: 480 400 201 13
Serial number: 3526502BB0D5D60402EG
Subsystem 5 - Part No SW: ----------- HW: 480 402 711 12
Serial number: 3556502B10D5D6242197
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 207 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502AB0BE4C3280DR
Subsystem 7 - Part No SW: ----------- HW: 480 401 012 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B30CAF1645209
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 207 12
Component: PedP_Sensor_C 001 6149
Serial number: 2306502A90BE4C31F2BO
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Revision: -------- Serial number: 04011308491614
Coding: 8408
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 77FA6190CEC5123E3A-8022
Part No SW: 8V0 920 970 B HW: 8V0 920 970 B
Component: KOMBI H24 0570
Coding: 278509002B8046000100E800000000
VCID: 3B72BDA0B26DF65E1E-806E
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 122 1126
Revision: -------- Serial number: 0000183404
Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_008.rod
VCID: 3878A2AC835BDD46F3-806C
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 17 12 2012 A0137774
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000002990788699
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 11121200090448
Coding: 001C8E204001040000001002
VCID: 3F8AC9B0A675EA7E32-806A
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D76B3B8AC79F86E20-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 24111200010677
Coding: 001C86204001040000001002
VCID: 3E74B4B4A17FE37639-806A
Component: LWR-ECU 005 0070
Coding: 019E000001000000
VCID: 75E66B98D4C9602E28-8020
Part No SW: 8V0 035 044 J HW: 8V0 035 044
Component: MU-H-TN-EU H40 0198
Serial number: A041A0D7509464
Coding: 01730301FF0A000021110001000A00102F00010701000100DE
ROD: EV_MUHig6C3HBAS_VW48.rod
Subsystem 1 - Part No SW: V03 959 800 KN HW: -----------
Component: ECE 2013 --- 0041
Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
Component: DU High H47 0013
Serial number: AUZ8Z9CG1001HM
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 H HW: 8V0 919 614 D
Component: ControlUnit_H H64 0764
Serial number: C1000003101200010070
Component: Gracenote --- 1007
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
Reset counter: 83
Mileage: 174561 km
Date: 2020.07.07
Time: 09:31:05
Voltage terminal 30: 12.3 V
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
Reset counter: 83
Mileage: 174561 km
Date: 2020.07.07
Time: 09:31:05
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 18121200010091
Coding: 000C86204001040000001002
VCID: 418ECF48D0819C8E44-8014
Component: TSG HBFS 010 0006
Serial number: 18121200010103
End-------------------------(Elapsed Time: 04:17)--------------------------
