I was wondering if you could possibly help, i have had a engine replacement and new turbo and DPF, and i have the vehicle back, and during acceleration the engine management light comes on. below is a scan of the vehicle, and i was wondering if anybod could advise the the Turbo intlet valve is and its location and control system?
Brian
Brian
Sunday,05,July,2020,17:58:19:27820
VIN: WV1ZZZ7HZBH117101 License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZBH117101 Mileage: 203930km-126716miles
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JF HW: 03L 907 309 H
Component: R4 2,0L EDC H34 9108
Revision: 22H34--- Serial number: 00000000000000
Coding: 01194012232400080000
Shop #: WSC 33868 000 1048576
ASAM Dataset: EV_ECM20BTD01103L906022JF 002011
ROD: EV_ECM20BTD01103L906022JB.rod
VCID: 72BED2E42429EB5B55F-8026
11872 - Turbocharger Inlet Valve
P22D3 00 [167] - Stuck Closed
Mileage: 203937 km
Date: 2020.07.05
Time: 17:54:58
Engine speed: 946.50 /min
Normed load value: 20.4 %
Vehicle speed: 92 km/h
Coolant temperature: 92 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.060 V
Actuator for low press turbocharger: activation: 9.95 %
Bypass valve f high press turboch turbine inlet: actual value: 99.89 %
Bypass valve f high press turboch turbine inlet: offset closed: 0.59 %
Bypass valve for high press turboch turbine inlet: activation: 5.00 %
Bypass valve for high press turboch turbine inlet: uncond volt: 732.4 mV
Charge air pressure: actual value: 1063.6 hPa
Address 03: ABS Brakes
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AK HW: 7E5 907 047 AK
Component: Climatic-T5 H11 0203
Revision: 00005001
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 78AAE0CC4255810B6BB-802C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Revision: BO047001 Serial number: 0396 073110318
Coding: B8B079BA2E61241192284E107E6F8CDC0080430F60844040300000000000
Shop #: WSC 02734 790 12345
VCID: 372823F00F4B4E73A21-8062
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 40000000000000289794
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 B HW: 7E0 919 475
Component: PARKHILFE 4K H11 0010
Revision: -------- Serial number: 47301100400055
Coding: 108001
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_VW75XParkAssis4K A01005
ROD: EV_VW75XParkAssis4K_A01_VN75.rod
VCID: 313C1DE8E1AF9043EC5-8064
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL004HV18
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 353429F815C7BC63B0D-8060
Part No SW: 7E0 920 970 C HW: 7E0 920 970 C
Component: KOMBI H20 0220
Coding: 470800
VCID: 2A0E0A84CC79E39B2DF-807E
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 042300
VCID: 70BAD8EC2AA5D94BA3B-8024
Component: IMMO H20 0220
VCID: 6A8ECA840CF9239BEDF-803E
Address 56: Radio
End----------(Elapsed Time: 01:51, VBatt start/end: 14.3V/14.2V)-----------
