Hello all! Thanks in advance for your time. New to this game, so I'm sure this is user error caused.
Trying to retrofit RS3 with direct TPMS, but unable to perform all the steps contained in these directions:
https://www.audizine.com/forum/showthread.php/824924-Direct-TPMS-Retrofit-Guide
AND HERE
https://forums.ross-tech.com/showthread.php?19273-Direct-TPMS-on-8V-2-RS3-Display-does-not-stay
Specifically cannot modify Byte 12,23, 27, and 28 in 03-ABS, as it says coding is out of range.
Also received a VCDS could not find ROD data when attempting to Long Code ABS-Bytes 27 and 28.
Autoscan inline:
AND HERE
Autoscan inline:
Sunday,05,July,2020,15:45:23:51561
VIN: WUABWGFF1J1902957 License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
47 4B 52 5F 65 6C A5 BB BC CF D6 D7
VIN: WUABWGFF1J1902957 Mileage: 15629km-9711miles
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: R5 2.5l TFSI X22 0004
Revision: 53X22000
Coding: 0A250032246600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D27C70B5DFD387378D-8068
Readiness: 0010 0101
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
VCID: 2E05F047809BD3EBF17-807A
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 62497000000614
Coding: 2EAA6B7DD4990BAB899A0B6981986974D62BD091D08196341841508402A812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_070.rod
VCID: 392FD31B49D50453545-806C
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0455670547
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C21CA0F46E7317B4F3-8068
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001357051
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40D9BEFF2A0F559B13B-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 40919DC800PAG0MUFU03
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001727400033
ROD: EV_BCMBOSCH_018.rod
VCID: 065568E748ABBBAB697-8052
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 170830 043 0585
Serial number: 170911023950
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 63010230
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 13 05 2017 00001680
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000070907531
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST001SMRCI00000
Coding: 101F00
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617269
Coding: 0470155811
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 4BC399D3134986C3F69-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: B50087C119FFC42474988055000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
VCID: 3B23C91343E93643469-806E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 160917004
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 45D7AFEB352D70B320D-8010
Component: AirbagVW20 010 0830
Serial number: 003GCR09GBS-
Coding: 9DCCFCC0008000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 47CBA5E30F2162A3D21-8012
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34258931A07091740512
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34258932A13071740150
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001N4P1U
Coding: 303337
Subsystem 4 - Part No SW: ----------- HW: 480 002 709 17
Serial number: 35700000000346B8B82P
Subsystem 5 - Part No SW: ----------- HW: 480 002 709 17
Serial number: 35800000000B46B8B82Y
Subsystem 6 - Part No SW: ----------- HW: 480 402 709 17
Serial number: 3510001BB262AD346552
Subsystem 7 - Part No SW: ----------- HW: 480 402 709 17
Serial number: 3520001A5262AD36E556
Subsystem 8 - Part No SW: ----------- HW: 480 401 008 17
Serial number: 3550002BB241971292B%
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 008 17
Serial number: 3560002B92419710A20T
Part No SW: 8V0 953 521 KT HW: 5Q0 953 549 E
Revision: -------- Serial number: 29091704401723
Coding: 6818
ROD: EV_SMLSKLOMQB_019_AU37.rod
VCID: 167538A7180B0B2B997-8042
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 890 A HW: 8V0 920 890 A
Component: FBenUSA H16 0066
Coding: 084D18D37F88CF050284EC041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
16777014 - Tire Pressure Monitoring Module
U0127 00 [008] - No Communications
[RDK_0x07 communication error bap_error_timeout heartbeat]
Reset counter: 87
Mileage: 15620 km
Date: 2020.07.05
Time: 09:17:14
16776973 - Databus
[RKA_01 communication error can_error_timeout]
Reset counter: 47
Mileage: 15620 km
Date: 2020.07.05
Time: 09:44:47
16776989 - Databus
[RDK_02 communication error can_error_timeout]
Reset counter: 87
Mileage: 15620 km
Date: 2020.07.05
Time: 09:17:16
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 22091710521192
Coding: 03010004340860005B00803EB80B00000001010000000000000000000000
ROD: EV_GatewNF_AU37.rod
VCID: 3333E1336BB9FE039E9-8066
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170918223754 22432
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2442675304
131595 - Tire Pressure Monitoring Module
[Timeout Knoten 0x0B / 65 - Steuergerät für Reifendrucküberwachung]
Reset counter: 87
Mileage: 15620 km
Date: 2020.07.05
Time: 09:17:15
Terminal 15: On
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00025.07.17
Coding: 0601
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 4DC797CBED5D88F3E8D-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0017
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 42DDB4F72403478B05F-8016
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000270927006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E22F6EB7F93B873-8060
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
Component: MRR1Rear H21 0610
Revision: --------
Coding: 04C002
Component: TSG FS 020 0041
Serial number: 100917EI710056
Coding: 005D1B205C00048000000003
VCID: 43D3B1F33B194E830E9-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9106
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCC174CD30F4B5DF-806E
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAH5F00T8C%
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 2411126FDE5769BB173-8070
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 16091710802546
Coding: 000000050100143206112300040000000000000000000000000000000000
VCID: 72BD24375423B70B55F-8026
Component: TSG BFS 020 0041
Serial number: 060817EH429476
Coding: 005D13205E00048000000003
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 880 B HW: 8V1 035 880
Component: MU-P-LNS-US 054 1110
Serial number: A702I0HB001699
Coding: 017361020000000011220002041A00102F0028E5017001047E
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y05MPK
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL102081700050206
Component: Gracenote2 --- 3012
B11CF 53 [009] - Deactivated
Reset counter: 47
Mileage: 15620 km
Date: 2020.07.05
Time: 09:53:43
Voltage terminal 30: 11.9 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
6919 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 87
Mileage: 15620 km
Date: 2020.07.05
Time: 15:23:21
Voltage terminal 30: 11.7 V
7175 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 87
Mileage: 15620 km
Date: 2020.07.05
Time: 09:17:18
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0010
Serial number: 40000000004747
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736.rod
VCID: 2F3BED438791DAE3FA1-807A
12656640 - Databus
U1200 00 [008] - Defective
[CAN_BusOff]
Time: 00:00:00
Voltage terminal 30: 11.50 V
12652550 - invalid data record
B2005 00 [008] - -
[invalid_dataset]
Time: 00:00:00
System information-System status: active
System information-Radio interference: not active
System information-Coding information: 00 00
System information-Terminal 15 on: No
System information-Unit: bar
System information-Vehicle speed is not zero: No
System information-Type of calibration: Menu
System information-Transport mode: not activated
8400910 - TPMS Warning
C102D F0 [008] - Pressure Loss
Reset counter: 88
Mileage: 15621 km
Date: 2020.07.05
Time: 15:31:05
Expanded ambient data 6-Vehicle speed: 14.95 km/h
Expanded ambient data 6-Outside air temperature: 28.50 °C
Tire pressure sensor 01-Manufacturer code: 0
Tire pressure sensor 01-Sensor identification number (sensor ID): 563552624
Tire pressure sensor 01-Wheel position: Unknown
Tire pressure sensor 01-CURRENT pressure: 0.00 bar
Tire pressure sensor 01-CURRENT temperature: -40 °C
Tire pressure sensor 01-SPECIFIED pressure: 0.00 bar
Tire pressure sensor 01-Warning pressure: 0.00 bar
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 19091712K12474
Coding: 040307010000020101222346814E490080000E200120
ROD: EV_MFKBoschMQBB_VW46.rod
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 270817EHR00152
Coding: 000C13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 270817EHR00386
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 F HW: 3Q0 907 590
Revision: --------
Coding: 04C002
VCID: 3829D61F72DF1D5BABB-806C
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
ROD: EV_LEDModLeftMELCOAU736_AU37.rod
VCID: 176B35A31F013223821-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 02:02, VBatt start/end: 12.4V/12.3V)-----------
