Results 1 to 6 of 6
Thread: Sound Actuator SQ5 - Engine Noise Simulators
    New User
    May 2019
    Sydney, Australia
    Hi guys, I’ve just ran a scan on my wife’s SQ5 and this came up:
    Sound Actuator
    Or click here. I’m trying to post a picture from Dropbox. Not sure this website accepts it.
    https://www.dropbox.com/s/00tglfwcy7...21.57.jpg?dl=0
    Does this mean it doesn’t work??
    Quote Originally Posted by barbalatte View Post
    A full unedited VCDS Auto-Scan would be more helpful (see my sig for a link to a How-To).
    That DTC probably means the sound actuator can be reached by diagnostics but has another electrical issue, to say any more we'll need to see that Auto-Scan.
    New User
    May 2019
    Sydney, Australia
    Thanks again.
     Monday,06,July,2020,15:23:05:63594
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUZZZ8R9DA071750   License Plate:
    Mileage: 85790km-53307mi   Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 0F 15 16 17 19 36 42 44 46 47 52 53 56 5F
              62 6C 6D 72 A9 C0
    VIN: WAUZZZ8R9DA071750   Mileage: 85790km-53307miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    C0-Act. for Ext. Noise -- Status: Malfunction 0010
    Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589     HW: 4G0 907 589
       Component: 3.0BTD EDC17  H24 0001
       Revision: 57H24---
       Coding: 2A2A4032252603020000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30BTD0118K5907589 001004
       ROD: EV_ECM30BTD0118K5907589.rod
       VCID: 7EA5022DD078F357B89-802A
       Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1002
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMAL551211 002020
       VCID: 00597CD5AA8C85A7CA5-8054
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AB    HW: 8R0 907 379 AB
       Component: ESP8 quattro  H09 0050
       Coding: 245D0C01
       Shop #: WSC 06335 000 00000
       VCID: 00597CD5AA0C85A7CA5-8054
       Part No SW: 8K0 907 064 GR    HW: 8K0 907 064 FR
       Component: BCM2 2.0      H12 0633
       Coding: 05B54040000000000000
       VCID: 06556ACD8828AB97F09-8052
       Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
       Revision: D1000000    Serial number: 01180220130830
       Coding: 3625628080
       VCID: 3A2DCE3D8C501F77C41-806E
       Revision: 08016001    Serial number: 00000555658602
       Coding: 260080118134AFF0018140C300001D0D4F9DC70827090201000008004401030100000034000000
       Shop #: WSC 06335 123 12345
       VCID: 78A91435F2DCCD67F25-802C
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130124  H11 0050
       Serial number: 90243015130121190815
       Coding: 01DD13
       Serial number: 21003873
       Coding: 03005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001302131026
       Serial number: 30380296000000000001
    03110 - Active Steering Control Module (J792)
                        Reset counter: 13
                        Mileage: 85360 km
                        Date: 2020.06.20
                        Time: 18:16:36
    Address 0F: Digital Radio
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Serial number: 003JPD92UVBE
       Coding: 304A3431313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48C9A4F5C23C7DE7425-801C
       Serial number: 6334MSME74160A68F
       Serial number: 6344MSME777301537
       Serial number: 6352QSME5328476EQ
       Serial number: 6362QSME6628377EV
       Serial number: 63732SME712B4D688
       Serial number: 63832SME582B3D7CI
       Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90372MBD000L6
       Coding: 000037
       VCID: 43D3B3D9FB9A5EBF977-8016
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 931 K    HW: 8R0 920 931 K
       Component: KOMBIINSTR.   H35 0556
       Revision: 00100000    Serial number: UWY24KC2E
       Coding: A3AF220003010008010700
       VCID: 3D27C5219D7E284FE13-8068
       Component: GW-BEM 4CAN-M H11 0055
       Revision: 1Y060027    Serial number: 2741Y132138073
       Coding: 80CD07FF00
       VCID: 4ACD9EFDDCB08FF7541-801E
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000001461041901
       Serial number: 13038002403011200410
    02230 - Digital Radio (DAB) (R147)
                        Reset counter: 13
                        Mileage: 85360 km
                        Date: 2020.06.20
                        Time: 18:17:35
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
                        Bin. Bits:    10000
                        Reset counter: 53
                        Mileage: 85360 km
                        Date: 2020.06.20
                        Time: 18:42:21
                        Bin. Bits:    10111
                        Voltage: 11.70 V
                        Count: 6
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000051749369
       Coding: 01781B00000000000000
       VCID: 42DDB6DDE48057B79C1-8016
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000051960460
       Coding: 011D12205E01440004
       VCID: 4FFB8FE927D2AADF03F-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Revision: 00001000    Serial number: 0013268912
       Coding: 100000010001
       Shop #: WSC 06334 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B23CB3983EA267FDF7-806E
       Revision: 00002001    Serial number: 0301338329
       Coding: 01040E2220B93095872005368004000F
       Shop #: WSC 44406 123 104857
       Component: J245EE20SKB13  H05 0220
       Component: J394EE20SKB13  H05 0220
       Revision: 00005001    Serial number: 94813011164102
       VCID: 2D07F5614D1EB8CF513-8078
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000052677644
       VCID: 4EC592ED20D8A3D7089-801A
    02117 - Motor for Mirror Folding
                006 - Short to Plus
                        Fault Status: 01100110
                        Fault Frequency: 7
                        Reset counter: 29
                        Mileage: 85422 km
                        Date: 2020.06.23
                        Time: 09:52:45
                        Reset counter: 64
                        Mileage: 85553 km
                        Date: 2020.06.29
                        Time: 09:35:15
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 29
                        Mileage: 85749 km
                        Date: 2020.07.05
                        Time: 11:33:23
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000001259528
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D435B2DC0D67325-806C
       Part No SW: 4G1 035 053 G    HW: 4G1 035 053
       Component: Radio U Basic H41 0121
       Revision: AB001007    Serial number: 227B30D7696709
       Coding: 040003010000000001
       VCID: 231313591BDA7EBFF77-8076
       Part No SW: 8R2 035 754 B    HW: 8R2 035 754 C
       Component: H-BN-RW       H45 0639
       Revision: --------    Serial number: 210BP0D7509640
       Coding: 1A0A01060205E1FF4780CB4E00000403FC0000020000000000
       VCID: 3635DA0DB848FB17209-8062
       Subsystem 1 - Part No: 8R0 060 884 AS
       Component: ROW 2013  0506
       Component: DU7 High  H42 0104
       Serial number: A130BL0D2659121
       Serial number: 00000001419569
       Component: CD-Database  4949
       Revision:             Serial number: 0000052596016
       Coding: 010C12204001240004
       VCID: 46D5AACDC8A86B97B09-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H07---    Serial number: 525PA8-J2ZA1XA
       Coding: 1020010
       VCID: 3431E005A234E9071ED-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B23CB39836A267FDF7-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Revision:             Serial number: 0000052278425
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 130201200540
       VCID: 79AF1131C956D46F8DB-802C
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0002
       Serial number: 130206200331
       VCID: 71BF291191269C2F35B-8024
    0006 - Actuator 1 for Engine Noise Simulation
              C113C 13 [008] - Open Circuit
                        Reset counter: 70
                        Mileage: 85360 km
                        Date: 2020.06.21
                        Time: 09:37:10
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.0V)-----------
    You've got several intermittent faults there, some likely caused by a low state of charge in the battery (03041 - Energy Management Active) - probably worth clearing all the fault codes and seeing which (if any) return.
    BTW you really should update your VCDS (VCDS Version: 19.6.0.6) - the current version is 20.4.1
  5. Likes Uwe liked this post
    New User
    May 2019
    Sydney, Australia
    Thanks will do. I cleared the Faluts you saw there about 2 weeks before to see what popped up and those are it! About 2 weeks worth.
    So what could be the problem with Sound Actuator??
    Open Circuit = wiring problem or blown fuse, so you need to get the WD for your car and do some old fashioned fault finding using a DVOM.
  8. Likes Uwe liked this post
