Results 1 to 10 of 12
Thread: Airbag coding for 2011 1K Golf
    Australia
    Hi guys
    I have a 1K Golf 12/2011 and I'm programming a new module, I was able to read the old module so I was able to get the coding from it. I put the coding into the new module and it rejects it. I have also used the "the long code helper" which gave me another code when I pressed "do it" it said it was to long or wrong format.
    I have also tried the coding number I got off Autocomsoft which was 00004341 & didn't work either. The original number off the old module was 00004343.
    I have browsed the forum and couldnt locate a code either. My thoughts are that it may need to be flashed with a dealer tool to code the new module?
    It has an immo code saying block from starting but the customer has told me that the immo has been bypassed and I can confirm that because the car still starts, could this be a problem?
    The full scan bellow is with the new module.
    Thanks in advance
    Ron
    Monday,06,July,2020,11:31:40:39910
    VCDS Version: 20.4.1.0 (x64)
    VIN: WVWZZZ1KZCK007216   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 26 2E 37 42 44 46 52 56 62
              72 77
    VIN: WVWZZZ1KZCK007216   Mileage: 61020km-37916miles
    15-Airbags -- Status: Malfunction 1010
    25-Immobilizer -- Status: Malfunction 1010
    Address 01: Engine (J623-CAVD)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 027 BD    HW: 03C 907 309 J
       Component: 1.4l R4/4V TS H04 1209
       Revision: LGH04---    Serial number: 00000000000000
       Coding: 00250012002400000000
       Shop #: WSC 00040 040 00019
       ASAM Dataset: EV_ECM14TSI01103C906027BD 001004
       ROD: EV_ECM14TSI01103C906027BD.rod
       VCID: 64CD46BC6FC059A68F-8030
    4710 - No Communications with Airbag Control Module
              U0151 00 [044] - -
                        Mileage: 61025 km
                        Date: 2020.06.30
                        Time: 03:12:55
                        Engine speed: 702.00 /min
                        Vehicle speed: 82 km/h
                        Coolant temperature: 14 C
                        Intake air temperature: 61 C
                        Ambient air pressure: 560 mbar
                        Voltage terminal 30: 21.105 V
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [237] - -
                        Mileage: 61025 km
                        Date: 2020.06.30
                        Time: 03:12:54
                        Engine speed: 697.00 /min
                        Voltage terminal 30: 33.137 V
    Readiness: 1110 0101
       Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 3652
       Revision: 00043014    Serial number: CU501107205583
       Shop #: WSC 10160 959 100575
       VCID: 3E79D4D469EC537639-806A
       Revision: 00H31001
       Coding: 163B600D21220001680D06E5841F0080310000
       Shop #: WSC 00040 040 00001
       VCID: 7BFF1DC0FA7E865E5E-802E
                        Reset counter: 133
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 03:06:35
                        Count: 3
                        Count: 14
                        Count: 24576
                        Count: 8226
                        Count: 42752
                        Count: 766
                        Count: 48
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 1000001002
       VCID: 7F07E9D0E6669A7E72-802A
              U1111 00 [008] - -
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2020.06.30
                        Time: 00:00:11
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2020.06.30
                        Time: 00:00:11
              U1111 00 [008] - -
                        Reset counter: 171
                        Time: 00:00:00
       Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 40000A3A8A25180040082080340081E44151158851208960648040200050
       VCID: 3A71D8C4B5C47F5605-806E
       Subsystem 1 - Part No SW: 5K7 955 119 A    HW: 5K7 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 16061  10  0605
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559   Labels: 5K7-955-559.CLB
       Component: RLS 180711 02  21  0011
       Coding: 0280DD
                        Reset counter: 174
                        Mileage: 61025 km
                        Date: 2014.11.27
                        Time: 02:10:14
                        Voltage: 14.20 V
                            Term 50 Off
       Part No SW: 5K7 919 475     HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0004
       Revision: --------    Serial number: 12591118614588
       Coding: 308101
       VCID: 7AF118C4F544BF5645-802E
    01312 - Powertrain Data Bus
                        Fault Status: 00101110
                        Reset counter: 173
                        Time Indication: 15
                        Temperature: 0.0C
                        Reset counter: 165
                        Time Indication: 15
                        Temperature: 0.0C
                        Reset counter: 171
                        Temperature: 0.0C
       Part No SW: 5C0 959 655 A    HW: 5C0 959 655 A
       Component: AirbagVW10    014 0907
       Serial number: 003EPM000RPU
       Coding: 00000000
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3065FAEC6BB8B506BB-8064
       Serial number: 3572MSME72706561ZZZR
       Serial number: 3582MSME4E636561ZZZ$
    13636352 - Control module not coded
              U1013 00 [137] - -
       Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440KGE000XS
       Coding: 188A140000
       Shop #: WSC 00040 040 00021
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 4281A024D51437965D-8016
       Serial number: 50000000000000447878
       Coding: E30000
       Part No SW: 5K0 920 870 F    HW: 5K0 920 870 F
       Component: KOMBI         H03 0305
       Coding: 170B00
       Shop #: WSC 00028 028 00023
    12669184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 174
                        Mileage: 61025 km
                        Date: 2020.07.06
                        Time: 02:11:05
       Revision:   H42       Serial number: 170711F1001261
       Coding: 365001
       Shop #: WSC 01383 790 00008
       VCID: 356BCBF89CDA902EE8-8060
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 00:00:10
                        Fault Status: 00110100
                        Reset counter: 174
                        Mileage: 61044 km
                        Date: 2014.04.09
                        Time: 20:36:32
                        Fault Frequency: 55
                        Reset counter: 173
                        Reset counter: 173
       Component: IMMO          H03 0305
       VCID: 6AD128848DE40FD6B5-803E
    9456128 - Engine Control Module (ECM) not authorized
              B104A 00 [009] - -
                        Mileage: 61025 km
                        Date: 2020.07.06
                        Time: 02:15:45
    9456681 - Key
              B104C 29 [009] - Implausible Signal
                        Mileage: 61025 km
                        Date: 2020.07.06
                        Time: 02:15:21
    Address 26: Auto Roof        Labels: None
       Part No: 5K7 959 255
       Component: VSG GOLF  6     H15 0360
       VCID: 7AF118C43544BF5645-802E
       Revision: A1001003    Serial number: 7660429376
       VCID: 295317884062C4CE7C-807C
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 D
       Component: RNS-MID       H55 3970
       Revision: AB001001    Serial number: VWZ6Z7L7174067
       Coding: 04000442020000800008
       VCID: 2F67F9907E86AAFEA2-807A
                        Reset counter: 171
                        Mileage: 61040 km
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 00:00:22
    00001 - Brake Control Unit
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 00:00:22
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2154
       Coding: 0017076
       VCID: 3973C7C870C2744E0C-806C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 346DF6FC57A08926DF-8060
    00750 - Warning Lamp
                        Fault Status: 00101101
                        Reset counter: 40
                        Mileage: 61043 km
                        Date: 2014.03.31
                        Time: 18:30:01
                        Voltage: 12.00 V
                            DD
                        Temperature: 24.0C
                        Reset counter: 171
                        Voltage: 12.38 V
                            DD
                        Temperature: 19.0C
                        Reset counter: 173
                        Voltage: 12.13 V
                            DU
                        Temperature: 15.0C
                        RPM: 1498 /min
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
                        Count: 3
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 14.0 V
                            PD
                        Temperature: 16.0C
                        Count: 2
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0017332
       VCID: 3A71D8C475C47F5605-806E
                        Reset counter: 171
                        Mileage: 61040 km
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 00:00:22
                        Reset counter: 173
                        Mileage: 61025 km
                        Date: 2014.11.21
                        Time: 00:00:22
       Part No SW: 8P7 959 811 B    HW: 8P7 959 811 B
       Component: Tuer-SG         H01 2103
       Coding: 0000144
       Shop #: WSC 00040 040 1012545
       VCID: 4281A0241D1437965D-8016
       Part No SW: 8P7 959 812 B    HW: 8P7 959 812 B
       Coding: 0000144
       VCID: 438FA520020E3E9E56-8016
       Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660462575
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
       VCID: 346DF6FC9FA08926DF-8060
              U0155 00 [008] - -
                        Reset counter: 171
    End-------------------------(Elapsed Ti
    Is the new airbag module COMPLETELY identical to the original (including color code)? Just matching the main part number isn't enough, the color code (characters on the label after the part number) must match too.
  3. Likes Uwe, Ron liked this post
    Yup. There is one and only one coding acceptable to these modules and it's determined by the module's "index" or "color code", which in turn is determined by the parameter set in the module, which much precisely match the car's restraint and sensor configuration.
    What's the source of the "new" module? If it was purchased at the dealer, the index / color code should be on the invoice. If it was ordered by VIN, it should be the correct one for the car, but the fact that this module doesn't accept the coding that was in the old one implies it's not the same index / color code. That doesn't necessarily mean it's wrong for the car; sometimes several different ones will "fit", but I'm not confident that it's correct either.
    If you just ordered a "5C0 959 655 A" somewhere without specifying an index / color code, chances are this module isn't correct for the car.
  5. Likes PetrolDave, Ron liked this post
  6. #4
    Australia
    Hi, The module was purchased through the VW dealer and the VIN was used to ensure that the correct part was supplied. I will contact the customer and get a copy of the invoice and a photo of the new and old module to double check the part.
    I used the 3 characters off the new module after the part No as the index Part No 5C0959655A/0CJ am I correct in saying that the "0CJ" is the index number? Also what do you mean by "Colour Code"?
    Thanks I appreciate the help
  7. Likes Uwe liked this post
  8. #5
    Have you tried VCDS Coding with the new Airbag ?
    Use "CJ" as Index.
    Coding should be 0000434A
  9. Likes Ron, Uwe liked this post
  10. #6
    Australia
    Use "CJ" as Index.
    I didn't try VCDS coding but when I put the coding in VCDS said it was the wrong format or wrong length. I tried "0CJ" but I didn't try just "CJ"
    I used the coding out of the old module which was 00004343 I didn't try 0000434A but I will try that when I go back.
    Cheers
    Ron
  11. #7
    Australia
    I just got a copy of the invoice and they definitely used the VIN because its on the invoice and the part number is exactly the same as the old one including the prefix.
    Comparing the old and new physical module one is made in Germany and the new one is made in Mexico, also there is a number in a rectangular box after the part No the old one is 07 H011 S0906 & the new one is 10 H014 S0907 can this be an issue?
    Cheers
    Ron
  12. #8
    Quote Originally Posted by Ron View Post
    OK, good.
    Yes, OCJ would be the index or color code. These terms are used somewhat interchangeably. If you were ordering, for example, an interior trim price, then that suffix to the part number would specify its color. With an airbag module, it specifies the index (how the module is parameterized).
    I concur with Niels. Coding for index 0CJ should be 0000434A.
  13. Likes Ron liked this post
  14. #9
    Australia
    OK, good.
    Ok thanks for your help and I will let you know what happens, it will be a day or so before I get back to the job.
    Cheers
    Ron
  15. #10
    Australia
    OK, good.
    The car accepted the code and all codes cleared.
    Thanks you legends I appreciate the help so much.
    I am curious as to how you came to the coding? Is there some resource that I can access to more educate myself for the future?
    Thanks again
    Ron
  16. Likes NZDubNurd, Uwe, iichel liked this post
