ECU potential bad
dzubot
Canada
C?ID=374589
Lately we've had a lot of rain, I went to drive and the car quickly went into limp mode. I have about 20 different codes now, main code of P0651. I found water sitting on top of the ecu housing. Think this could be the cause? I don't know why the date for the fault codes are from random years and not the current date.
Sunday,05,July,2020,13:52:07:04508
VIN: 3VWPL8AJ4BM649339   License Plate:
Mileage: 254110km-157896mi   Repair Order:
                Address 01: Engine       Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 030 B    HW: 03L 906 019 DA
  Component and/or Version: R4 2.0l TDI G000AG  9983
           Software Coding: 0050078
            Work Shop Code: WSC 55306 001 1048576
                      VCID: 2D0709F0511027A3C8D-8078
17 Faults Found:
001617 - Sensor Reference Voltage B
               P0651 - 000 - Open Circuit - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 42
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:26
                    RPM: 920 /min
                    Voltage: 13.83 V
                    Temperature: 40.5∞C
                    (no units): 0.0
                    Torque: 57.0 Nm
               P0300 - 000 -
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:34
                    RPM: 897 /min
                    Voltage: 13.76 V
                    Voltage: 13.76 V
                    Voltage: 13.76 V
                    Voltage: 13.76 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:34
                    RPM: 897 /min
                    Bin. Bits: 00100000
                    Torque: -9.0 Nm
                    Bin. Bits: 00100000
                    Ign. Timing: 18.4 ∞ATDC
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:34
                    RPM: 897 /min
                    Bin. Bits: 00100000
                    Torque: -3.0 Nm
                    Bin. Bits: 00100000
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:34
                    RPM: 897 /min
                    Bin. Bits: 00100000
                    Torque: -6.0 Nm
                    Bin. Bits: 00100000
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected
                    Mileage: 254111 km
                    Date: 2015.01.11
                    Time: 22:24:34
                    RPM: 897 /min
                    Bin. Bits: 00100000
                    Torque: -9.0 Nm
                    Bin. Bits: 00100000
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - Intermittent
                    Fault Status: 00100001
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:30:48
                    RPM: 920 /min
                    Inj. Quantity: 8.5 mg/str
                    Mass Air / Rev.: 435.0 mg/str
                    (no units): 3.29
                    Temperature: 15.3∞C
                    Temperature: 41.4∞C
000403 - Fuel Pressure Sensor (G247)
               P0193 - 000 - Short to Plus - Intermittent
                    Mileage: 254110 km
                    Voltage: 12.31 V
                    Inj. Quantity: 0.0 mg/str
                    Temperature: 26.1∞C
                    Temperature: 49.5∞C
                    Temperature: 36.9∞C
009298 - Diesel Particle Filter; Differential Pressure Sensor
               P2452 - 000 - Elect. Malfunction - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:05:29
                    Mileage: 360 km
                    Pressure: 326 mbar
                    Pressure: 0 mbar
                    (no units): 0.0
                    Temperature: 30.6∞C
008215 - Intake Manifold Flap Position Sensor (Bank 1)
               P2017 - 000 - Short to Plus - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:06:13
                    Voltage: 12.08 V
                    Lambda: 3.2 %
                    Lambda: 10.3 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
008200 - Intake Manifold Flap; Bank 1
               P2008 - 000 - Electrical Malfunction - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:06:14
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 47.7∞C
000069 - Boost Pressure Control Valve/Solenoid (Bank 1)
               P0045 - 000 - Open Circuit - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:07:32
                    Load: 9.8 %
                    Lambda: 14.2 %
                    Pressure: 919.6 mbar
                    Temperature: 30.6∞C
009572 - Turbocharger Boost Control Position Sensor Circuit
               P2564 - 000 - Signal too Low - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:19:54
                    Voltage: 12.01 V
                    Temperature: 36.0∞C
                    Lambda: 1.6 %
                    Bin. Bits: 00000000
                    Voltage: 0.000 V
001136 - Exhaust Pressure Sensor 1
               P0470 - 000 - Malfunction - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:21:02
                    Temperature: 15.3∞C
                    Temperature: 43.2∞C
                    Temperature: 30.0∞C
                    Pressure: 326 mbar
                    Pressure: 3 mbar
000257 - Mass Air Flow Sensor (G70)
               P0101 - 003 - Implausible Signal - Intermittent
                    Fault Status: 00100011
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:22:56
                    Voltage: 12.01 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 1100.0 mg/str
000802 - Engine Speed Sensor (G28)
               P0322 - 000 - No Signal - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 00:29:48
                    RPM: 2484 /min
                    Voltage: 13.68 V
                    Temperature: 48.6∞C
                    Idle Stabilization: 0.0∞KW
                    RPM: 1254 /min
                    (no units): 60.0
008487 - Accelerator Position Sensor 2 (G185)
               P2127 - 000 - Signal too Low - Intermittent
                    Mileage: 254110 km
                    Date: 2014.11.26
                    Time: 02:18:38
                    Voltage: 10.87 V
                    Voltage: 0.684 V
                    Voltage: 0.380 V
                    Bin. Bits:  0 00  0
Readiness: 1 1 0 1 1
I guess the first thing I would do is to pull the connector(s) from ECU and check the condition of the pins. There should be no water in there, and no corrosion.
Not just connector but through vent and on board too in ECU case!
Get one of these if it doesn't have one on ECU already and that goes for any MED series ECU, without this you are just asking for ingress bad time trouble?
4L0-907-577
