Results 1 to 6 of 6
Thread: T5.1 Cruise control retro not working
    Dec 2015
    A mate has a T5.1 and got a cruise kit with instructions to fit
    Unfortunately the instructions didn't show how to update with VCDS, it looks like dealer software so we googled how to set the cruise on
    First problem:- The guides say to LOGIN to the engine ECU but the LOGIN button is greyed out, any idea why?
    Checked using the long coding and found it possible to set cruise fitted so did that.
    This is a scan from before fitting
    Friday,30,June,2020,13:38:18:27548
    VCDS Version: 20.4.1.0 (x64)
    VIN: WV1ZZZ7HZBH053533   License Plate:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
    VIN: WV1ZZZ7HZBH053533   Mileage: 213710km-132793miles
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H37 9970
       Revision: 26H37---    Serial number: 00000000000000
       Coding: 01194012230400080000
       Shop #: WSC 11488 001 104857
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
       ROD: EV_ECM20TDI01103L906019AM_002.rod
       VCID: EDDBEDB93CFAE2EE50-80B8
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0105
       Revision: 00H43001
       Coding: 208724AD09A9049824A79074AA6110
       Shop #: WSC 02736 790 49152
       VCID: B66902D5012C613661-80E2
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 AL    HW: 7E5 907 047 AL
       Component: Climatic-T5   H11 0203
       Revision: 00005001
       Coding: 0000000002
       Shop #: WSC 02737 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: F9F3C9E978B24E4ECC-80AC
       Part No SW: 7H0 937 087 D    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0221
       Revision: BO047001    Serial number: 0347 278100249
       Coding: B9A0303A0E212033002000107C2B8C540000430F60860000300000000000
       Shop #: WSC 02734 790 00000
       VCID: B56B05D91C2A6A2E68-80E0
       Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3311
       Coding: 050000
       Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3311
       Coding: 040000
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 B    HW: 7E0 919 475
       Component: PARKHILFE 4K  H11 0010
       Revision: --------    Serial number: 47331028000146
       Coding: 100001
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_VW75XParkAssis4K A01005
       ROD: EV_VW75XParkAssis4K_A01_VN75.rod
       VCID: B16331C9E042460E34-80E4
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H06 0013
       Revision: --------    Serial number: 003HL001X2TK
       Shop #: WSC 02734 790 50316
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: B56B05D9142A6A2E68-80E0
       Part No SW: 7E0 920 960 C    HW: 7E0 920 960 C
       Component: KOMBI         H04 0204
       Coding: 460A00
       VCID: A953D9A9C8923ECEFC-80FC
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 0221
       Coding: 042300
       VCID: F0E5F4CD23C80F067B-80A4
    01304 - Radio
                        Reset counter: 11
                        Mileage: 213663 km
                        Date: 2014.11.21
                        Time: 13:49:10
       Component: IMMO          H04 0204
       VCID: EAD1E6A50D14F5D635-80BE
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Then with the cruise set to fitted we got this
    Tuesday,03,July,2020,15:15:54:27548
    VCDS Version: Release 19.6.2 Running on Windows 10 x64
                    Address 01: Engine       Labels: 03L-906-022-CAA.clb
    Control Module Part Number: 03L 906 022 CH    HW: 03L 907 309 K
      Component and/or Version: R4 2,0L EDC   H37 9970
               Software Coding: 01194012232400080000
                Work Shop Code: WSC 11488 001 104857
                  ASAM Dataset: EV_ECM20TDI01103L906022CH 002013 (VN75)
                           ROD: EV_ECM20TDI01103L906022CH_002.rod
                          VCID: EDDBEDB93CFAE227FE-80B8
    4481 - Cruise Control Switch (E45)
              P0568 00 [039] - Implausible Signal
                        Mileage: 213663 km
                        Date: 2020.06.30
                        Time: 15:14:29
                        Engine speed: 848.00 /min
                        Normed load value: 52.5 %
                        Coolant temperature: 20 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 14.200 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 192
                        Cruise Control System (CCS): status-Bits 0-7: 200
                        Cruise control switch-off: irreversible-Bits 0-7: 0
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
    4482 - Function Restriction due to Implausible Message(s)
              U1112 00 [039] - -
                        Mileage: 213663 km
                        Time: 00:00:00
                        Voltage terminal 30: 12.160 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 8
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    Readiness: N/A
    Looking for ideas for what might be wrong, I don't have access to the van right now to double check the wiring so pointers or ideas
    Should we be able to use the LOGIN button?
    The old Login function simply doesn't exist on modules that use the UDS protocol, which your ECU does.
    You should probably tell the BCM that there's a CCS installed too (Byte 17).
    Then check CCS switches in MVB 004 of the BCM.
    Dec 2015
    Thank Uwe, that would explain why its greyed out
    Aug 2016
    Eindhoven, NB, NL
    Yeah code byte 17 bit 7 and the engine ECU for cruise control and you're good to go.
    Dec 2015
    next question, what should we do here when trying to update the BCM to have the CCS
    Following message appears:
    VCDS: Re-Code Invalid
    This appears to be an unintialised control module;
    valid WSC/Importer/Equipment data may be required.
    Click [yes] for VCDS to use default value of 12345/123/12345.
    Click [no] for VCDS to try the values currently in the module.
    Click [cancel] to go back and manually edit the values.
    What will happen if we say yes?
    Dec 2015
    fixed now, the choice found by google was no, and it all works now
  7. Likes Uwe liked this post
