2012 Jetta Sportswagen TDI
Chief05
C?ID=395290
Plugged in the HEX-V2 into my 2012 TDI and it registered my VIN, but the VCDS states it is not compatible and does not read the OBDII gateway codes. Am I doing something wrong or is the TDI not supported? If not supported, then why did it register the VIN?
Chief
It would help if you try to run an Auto-Scan and post the result here - see my sig for a How-To link.
Chief05
C?ID=395290
PetrolDave,
No Auto-scan. Just stated the Gateway is not supported.
Chief05
The car is definitely supported. Something is wrong there. Let's start with the most basic items:
Is your ignition on?
If so, what is the exact result when you click [Options] -> [Test]?
