Unsupported Vehicle
Tutu22
India
C?ID=161648 (NRRT)
Just done a AutoScan of a Skoda octavia Vrs 245, it says vehice not supported.
Pls Check,
Regards
TUTU.
Saturday,04,July,2020,17:15:50:04642
VCDS Version: 20.4.1.0
VIN: TMBBU9NE5L0079708   License Plate: 0333VRS
Control Module Part Number: 565 035 864
  Component and/or Version: MU-S-N-ER     H41 0478
           Software Coding: 0373510EFF00000041110001000000002F0209E601200400CF
            Work Shop Code: WSC 59828
                      VCID: 5AB1D3DE5D0D5B5625-800E
Advanced Identification/FAZIT
     Serial number: SKZAZ2W1073499
     Identification: YD7-002
     Date: 19.10.19
     Manufacturer number: 0310
     Test stand number: 0388
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 65535/0/4/4/4/4/4/65535/4/4/4/65535/0/4/0/4/65535/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
     Successful Attempts(data): 65535/0/4/4/4/4/4/65535/4/4/4/65535/0/4/0/4/65535/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
     Flash Date: 00.01.01
     Flash Tool Code(data): 2097151 1023 131071
Misc.
     Hardware number: 565 035 864
     Workshop System Name: J794
     Equipment/PR Code: FFFFFFFFFFFFFFFFFFFFFFFE
     Dataset Number: V03935314JG
     Dataset Version: 0001
     ASAM Dataset: EV_MUStd4CTSAT
     ASAM Dataset Revision: 001022
Car Info
     Chassis Number: TMBBU9NE5L0079708
VCDS Info:
       Labels: None
       ROD: ERROR - EV_MUStd4CTSAT 001022 ()
Saturday,04,July,2020,17:23:08:04642
Chassis Type  NE (3Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 2B 32 36 42 44 4B 52 5F 6C A9
          BB BC
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DKTB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 S    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0003
   Revision: --H13---
   Coding: 0C2540324424050B1000
   Shop #: WSC 31000 790 00284
   ASAM Dataset: EV_ECM20TFS0205G0906259S 001004
   ROD: N/A
   VCID: 3E797F4EA165977639-806A
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM20TFS0205G0906259S" ()
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2402
   Revision: 00H06V09
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: N/A
   VCID: 2649B72E59F52FB651-8072
No ASAM data for: "EV_TCMDQ381061" ()
   Part No SW: 5Q0 614 517 ET    HW: 5Q0 614 517 BQ
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62879000000985
   Coding: 2407939150272175407E060060CB6824C90A8402600616762041F071D0094B0B0000000012121212B835351919323200
   Shop #: WSC 31000 790 00256
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: N/A
   VCID: 0717DAAABE3F16BE4A-8052
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0530591166
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: N/A
   VCID: 458B10A2C4B3C4AE78-8010
No ASAM data for: "EV_KessyHellaMQBAB" ()
12786210 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 52
                    Mileage: 173 km
                    Date: 2020.06.21
                    Time: 09:05:51
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 5E0 907 044 BB    HW: 5E0 907 044 BB
   Component: Climatronic   H04 2201
   Revision: 00001K00
   Coding: 01110004000110011005000C0010102A
   Shop #: WSC 31000 790 00202
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: N/A
   VCID: 66C9F72E9975EFB691-8032
No ASAM data for: "EV_ACClimaBHBVW37X" ()
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 01001926100107
   ASAM Dataset: EV_BCMMQB 020001
   ROD: N/A
   VCID: 0103C4B2901B288E04-8054
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 190801  051  0916
   Serial number: 887253F0401921300127
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S7Y19M10D15H22M15S18
   Coding: 00885D
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.405  H04  0005
   Serial number: 0000FST002EJ9RZ00000
   Coding: 981803
   Subsystem 4 - Part No SW: 5Q1 953 521 DE    HW: 5Q1 953 569 C
   Component: Lenks.Modul  H33  0170
   Serial number: 0100300920190C205626
No ASAM data for: "EV_BCMMQB" ()
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319268
   Coding: 0371161051
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: N/A
   VCID: 55ABC0E23413742E08-8000
No ASAM data for: "EV_EPHVA2CAU3700000" ()
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CN    HW: 3Q0 959 655 CN
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z3PH9GHJF
   Coding: 98FCC000000000005C5400CC008800000065
   ROD: N/A
   VCID: 0C1DE586A75975E667-8058
   Subsystem 1 - Part No SW: -----------    HW: 454 002 109 19
   Serial number: 35700000000FDCA0114S
   Subsystem 2 - Part No SW: -----------    HW: 454 001 809 19
   Serial number: 3580000000019C19FF3
   Subsystem 3 - Part No SW: -----------    HW: 454 800 710 19
   Serial number: 351009393D119000000E
   Subsystem 4 - Part No SW: -----------    HW: 454 800 710 19
   Serial number: 352009416CE19000000N
   Subsystem 5 - Part No SW: -----------    HW: 454 802 409 19
   Serial number: 35500B612D819000000L
No ASAM data for: "EV_AirbaVW21TS6VW48X" ()
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 5E0 920 790 A    HW: 5E0 920 790 A
   Component: KOMBI         509 1711
   Coding: 25A5111829800008010A63001001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001031
   ROD: N/A
No ASAM data for: "EV_DashBoardVDDMQBA0" ()
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000239067
   Coding: 030100047F085900AB1002EB180F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: N/A
   VCID: 70E59176ABB13106FB-8024
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 3V0 919 719 H    HW: 3V0 919 719 H
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000E2082091019
   Component: J367-BDMConti  H03 1051
   Serial number: 7588600300191015017D
No ASAM data for: "EV_GatewNF" ()
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000288304009
   Coding: 0800000000000000
   ROD: N/A
   VCID: 31635472603B780EB4-8064
No ASAM data for: "EV_ELVMarqMQBA0" ()
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00024.09.19
   Coding: 0201
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: N/A
   VCID: 52A13BFE05FD6316ED-8006
No ASAM data for: "EV_LockElectHA1VW37X" ()
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SIC22603
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: N/A
   VCID: 3F87024AA66F9E7E32-806A
No ASAM data for: "EV_SeatMemorDriveSide" ()
Address 42: Door Elect, Driver (J386)       Labels: Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000393070087
   Coding: 001D0120DE01020000001100
   ROD: N/A
   VCID: 4D9B28821CC33CEEB0-8018
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000034725854
   Coding: 1D0200
No ASAM data for: "EV_DCU2DriveSideMAXHCONT" ()
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 83170000
   ROD: N/A
   VCID: 3C7D7546B779856617-8068
No ASAM data for: "EV_SteerAssisMQB" ()
Address 4B: Multifunc. Module
Interface not compatible.
Address 52: Door Elect, Pass. (J387)       Labels: Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000392793161
   ROD: N/A
   VCID: 4C9D2586E7D935E6A7-8018
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000034755112
   Coding: 050200
No ASAM data for: "EV_DCU2PasseSideMAXHCONT" ()
   Part No SW: 565 035 864     HW: 565 035 864
   Component: MU-S-N-ER     H41 0478
   Shop #: WSC 59828 002 1048576
   ROD: N/A
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: SKZ6ZHW2964219
No ASAM data for: "EV_MUStd4CTSAT" ()
Address 6C: Back-up Cam. (J772)       Labels:. 5Q0-980-556.clb
   Component: RVC Compact   H18 0231
   Coding: 047301012600201F000040
   ROD: N/A
   VCID: 39736C52B84BB04E0C-806C
No ASAM data for: "EV_CamSysRVRVCPANAMQBAB" ()
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0002
   Serial number: 190712200020
   ROD: N/A
   VCID: 69D3FC12886BC0CEBC-803C
No ASAM data for: "EV_SoundActuaGen2AU64X" ()
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End-------------------------(Elapsed Time: 04:33)--------------------------
Mari
C?ID=150535
... you probably need a newer Ross-Tech interface... Hex-V2 or Hex-Net!
PetrolDave
Westbury, UK
C?ID=1423
From the VIN that is a 2020 model year Octavia - which means you need either a HEX-V2 or a HEX-NET to be able to fully access all the modules or to access the #4B module at all.
VAG have made changes to the data formats since 2019 Model Year which mean that the HEX-CAN and older interfaces are not fully compatible, and those changes are too great for any software/firmware fix to be possible.
"Unsupported Vehicle" doesn't belong in Car Repair. Moving to Product Support. :)
FWIW, it looks like someone (probably me) fat-fingered the OP's membership here. He has never registered his interface for support, so technically shouldn't be a Verified user. Since he's using a legitimate interface, I'll leave it be for now, but will revert him to New User status at some point unless he fills out this form to register his system.
