Results 1 to 8 of 8
Thread: 2007 VW Passat ABS Module/Park Break Module
    Jun 2020
    Guyton, GA, USA
    I have a 2007 VW Passat that was setting. I just rebuilt the Engine and I have having difficulty with the ABS Module. Can the module just lose its information by just setting. I have another module I pulled off another car and it has the same part number. Can I use this ABS module and get the car to accept it. I just dont have the long coding for the module. The speedometer is also not working. Also is there a place to get the wiring diagrams for this car as well. Not sure I inserted the auto scan correctly. Thank You.
    Thursday,02,July,2020,16:08:29:24649
    VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWEK73C77P002442   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
              65 72
    VIN: WVWEK73C77P002442   Mileage: 249930km-155299miles
    03-ABS Brakes -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
       Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
       Revision: --H14---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 25428 444 57477
       VCID: 303915096625571BE3B-8064
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:03
                        RPM: 837 /min
                        Load: 28.2 %
                        Temperature: 93.0C
                        Temperature: 62.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.335 V
    049448 - No Communications with Parking Brake Control Module
                   U0128 - 008 -
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:03
                        RPM: 837 /min
                        Load: 28.2 %
                        Temperature: 93.0C
                        Temperature: 62.0C
                        Voltage: 13.335 V
    001281 - Vehicle Speed Sensor
                   P0501 - 002 - Implausible Signal - MIL ON
                        Fault Status: 11100010
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 12:30:51
                        RPM: 1718 /min
                        Load: 11.4 %
                        Temperature: 92.0C
                        Temperature: 47.0C
                        Voltage: 13.462 V
    000010 - Camshaft Positioner (Bank 1 Intake)
                   P000A - 008 - Slow Response - Intermittent
                        Mileage: 249937 km
                        Date: 2020.06.28
                        Time: 12:06:32
                        RPM: 1976 /min
                        Load: 35.3 %
                        Temperature: 92.0C
                        Temperature: 47.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.462 V
    Readiness: 0000 0100
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
       Component: AQ 250 6F           1068
       Revision: 00H38000    Serial number:
       Coding: 0000072
       VCID: 005985C99605079B53B-8054
    Address 03: ABS Brakes
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
       Component: ClimatronicPQ46 050 0505
       Revision: 00050005    Serial number: 00000000000000
       VCID: 678BBE55936BD0A3F21-8032
    00710 - Defroster Flap Positioning Motor (V107)
                        Fault Status: 00110000
                        Fault Frequency: 22
                        Reset counter: 57
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:12
                        Fault Frequency: 23
                        Reset counter: 17
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:12
       Revision: 00H46000    Serial number: 00000005593787
       Coding: F5848F0340041A00470A00000F00000000285D435C0000
       Shop #: WSC 00028 028 00001
       VCID: 372B2E15834B8023A21-8062
       Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer VW461 001   0101
       Coding: 00063445
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 00028
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7F1024501
       VCID: 2A0D076140F92DCB2DF-807E
                        Reset counter: 17
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 16:04:34
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0N AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3P7WP26R
       Coding: 0012366
       VCID: 2E050B717C1141EBF17-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 000000000309W0
       Subsystem 3 - Serial number: 0001.01.00000060000000000063
       Subsystem 4 - Serial number: 0000006332MSME0F0A7529J63
       Subsystem 5 - Serial number: A7529J6342MSME0E580023463
       Subsystem 6 - Serial number: 8002346351HTS6OLLAPOK2R63
       Subsystem 7 - Serial number: APOK2R6361HTS6OLLMS4C3G63
       Subsystem 8 - Serial number: MS4C3G63727TS6TLLQEJA3G63
       Subsystem 9 - Serial number: QEJA3G63827TS6OLLIKRT2-
       Subsystem 10 - Serial number: IKRT2-
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00005000    Serial number: 3C5953507P
       Coding: 0002111
       Component: E0221           006 0080
       Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: X0006000    Serial number: 00000000000000
       Coding: 0007205
       Shop #: WSC 25428 444 85788
       VCID: 2313EA4527D3FC836E9-8076
                        Fault Frequency: 13
                        Reset counter: 16
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:25
                        Fault Frequency: 13
                        Reset counter: 16
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:25
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0651108E2
       Coding: 3FFD0F04D31002
       VCID: 211FE04D3DCFEE937C5-8074
                        Reset counter: 10
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 11:42:37
                        Reset counter: 10
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 11:42:37
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0002
       Revision: 00005000    Serial number: 1166279TQJK505
       VCID: 6D87CC7DB197FAF388D-8038
                        Fault Frequency: 24
                        Reset counter: 17
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:34
       Part No SW: 3C0 959 433 AA    HW: 3C0 959 433 AA
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 25428 444 101307
       VCID: 698FB86D857FE6D3E45-803C
    02823 - Requirements for Locking the Steering Column Lock not met
                        Reset counter: 15
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 11:16:05
    02827 - Wake-Up request via ESP
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 10
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:45
                        Reset counter: 10
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 11:16:05
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
       Component: Sitzverstellung     1001
       Revision: 00004000    Serial number: 00000000000000
       VCID: 2D070C7D71173AF3C8D-8078
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1123
       Revision: 11006001    Serial number: 00000021368520
       Coding: 0001463
       VCID: 3C213139BA6DA37B4F3-8068
    01034 - Electric Window Thermal Protection Active; Driver
                        Fault Frequency: 117
                        Reset counter: 52
                        Mileage: 249937 km
                        Date: 2020.06.28
                        Time: 19:12:31
       Part No: 1K1 909 144 K
       VCID: 33331A0597336C039E9-8066
    00625 - Vehicle Speed Signal
                        Mileage: 9920 km
                        Temperature: 68.0C
                        Voltage: 13.30 V
                        Voltage: 13.10 V
       Component:    KSG PQ46 RDK 051 0218
       Coding: 13910F8001862E521004141FF08A8F0E085800
       Shop #: WSC 25018 444 58921
                        Reset counter: 17
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 16:04:34
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1123
       Revision: 11007001    Serial number: 00000033368923
       Coding: 0001462
       VCID: 3D273C3DA177AA7378D-8068
    01035 - Electric Window Thermal Protection Active; Passenger
                        Fault Frequency: 118
                        Reset counter: 52
                        Mileage: 249937 km
                        Date: 2020.06.28
                        Time: 19:12:31
    Address 53: Parking Brake
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       165 0035
       Revision: 00165000    Serial number: VWZ5Z7F2075876
       Coding: 0040401
       VCID: 2411E95922DDFBBB173-8070
                        Fault Status: 01111011
                        Reset counter: 16
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 11:15:55
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1109
       Revision: 12005001    Serial number: 00000000067904
       Coding: 0001168
       VCID: 3E253B31AC71B16B617-806A
    01036 - Electric Window Thermal Protection Active; Rear Left
                        Fault Frequency: 178
                        Reset counter: 52
                        Mileage: 249937 km
                        Date: 2020.06.28
                        Time: 19:16:23
       Component:    RDK              0420
       Coding: 0100101
                        Fault Status: 01111000
                        Reset counter: 10
                        Mileage: 249937 km
                        Date: 2020.06.26
                        Time: 10:52:59
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1109
       Revision: 12005001    Serial number: 00000000018436
       Coding: 0001168
       VCID: 3FDB4635AB7BB8636A1-806A
    01037 - Electric Window Thermal Protection Active; Rear Right
                        Fault Frequency: 179
                        Reset counter: 52
                        Mileage: 249937 km
                        Date: 2020.06.28
                        Time: 19:17:20
    End----------(Elapsed Time: 02:14, VBatt start/end: 13.7V/13.7V)-----------
    ABS is completely off-line. You'll need to figure out why. Check fuses first.
    The instrument cluster likely gets vehicle speed data from the ABS module in this car, rather than from a dedicated vehicle speed sensor.
    Also please see: Where do I get a Wiring Diagram.
  3. Likes Jetta ,97 liked this post
    Jun 2020
    Guyton, GA, USA
    I have already checked the power, grounds and ABS sensors and other wiring. I just plugged in a ABS module that I picked up used and when i plugged it in on my scan tool it was providing information that the other ABS module would not. Would I be able to reprogram a used module to the car. I just dont have the long coding to try and reprogram. Thanks for the info.
    HQ
    Provided this other ABS module is a correct part number for the vehicle, then yes, we can provide the info you need to code it and the Basic Settings. Post a fresh Auto-Scan with the talking ABS and we'll go from there.
    Jef
  6. Likes Uwe liked this post
    Jun 2020
    Guyton, GA, USA
    Friday,03,July,2020,17:35:27:24649
              65 72
    53-Parking Brake -- Status: Malfunction 1010
                   U0121 - 008 -  - Intermittent
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:46:03
                        RPM: 844 /min
                        Load: 24.3 %
                        Temperature: 67.0C
                        Temperature: 35.0C
                        Voltage: 13.589 V
                   U0128 - 008 -  - Intermittent
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:46:03
                        RPM: 844 /min
                        Load: 24.3 %
                        Temperature: 67.0C
                        Temperature: 35.0C
                        Voltage: 13.589 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - MIL ON
                        Fault Status: 11100100
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:46:09
                        RPM: 839 /min
                        Load: 24.3 %
                        Temperature: 67.0C
                        Temperature: 36.0C
                        Voltage: 13.716 V
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -
                        Fault Frequency: 16
                        Temperature: 33.0C
                        Temperature: 34.0C
                        Voltage: 7.620 V
    Readiness: 0110 0101
       Coding: 0000072
                013 - Check DTC Memory
                        Fault Frequency: 19
                        Reset counter: 0
                        Mileage: 52028 km
                        Date: 2008.08.15
                        Time: 14:26:14
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
       Component: ESP 440 C2     H015 0004
       Revision:  H015       Serial number: 0100006470
       Coding: 0010000
       Shop #: WSC 05100 444 59153
       VCID: 323D1F016829650B95F-8066
    7 Faults Found:
                        Fault Frequency: 43
                        Mileage: 249937 km
                        Date: 2020.06.23
                        Time: 16:59:58
    00532 - Supply Voltage B+
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
    01542 - Yaw Rate Sensor (G202)
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
    00810 - Sensor 1/2 for Brake Pressure
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:29
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:58
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:58
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:11:58
       Coding: 00063445
       Shop #: WSC 00028
       Coding: 00208933
       Shop #: WSC 00028
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:21:00
                        Voltage: 8.15 V
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 14:23:00
                        Voltage: 8.50 V
    02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 14:24:00
                        Voltage: 8.45 V
                        Reset counter: 18
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:25:26
       Coding: 0012366
       Subsystem 3 - Serial number: 0001.01.000000600000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME0F0A7529J†63
       Subsystem 5 - Serial number: A7529J†6342MSME0E5800234†63
       Subsystem 6 - Serial number: 800234†6351HTS6OLLAPOK2R†63
       Subsystem 7 - Serial number: APOK2R†6361HTS6OLLMS4C3G†63
       Subsystem 8 - Serial number: MS4C3G†63727TS6TLLQEJA3G†63
       Subsystem 9 - Serial number: QEJA3G†63827TS6OLLIKRT2-
    03032 - Supply Voltage for Seat Occupied Recognition Control Module
       Coding: 0002111
       Coding: 0007205
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:39
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:39
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 14:23:39
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:14
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:46:01
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:46:01
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:29
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:47:57
                        Fault Status: 00100111
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:45:40
                        Fault Status: 00111000
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 20:47:58
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 58
       Coding: 0001463
                        Reset counter: 58
                        Mileage: 9920 km
                        Temperature: 34.0C
                        Voltage: 13.70 V
                        Voltage: 13.50 V
    00003 - Control Module
                        Temperature: 34.0C
                        Voltage: 4.70 V
                        Voltage: 5.60 V
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:17:17
       Coding: 0001462
                        Reset counter: 58
       Revision:   013
       Coding: 0010000
                        Fault Status: 11101101
                        Fault Frequency: 173
                        Reset counter: 18
                        Mileage: 249936 km
                        Date: 2020.07.02
                        Time: 17:33:03
                        Voltage: 13.04 V
                        Count: 236
                        Reset counter: 58
                        Mileage: 249936 km
                        Date: 2020.07.02
                        Time: 15:20:20
                        Voltage: 6.52 V
                        Count: 200
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 18
                        Voltage: 6.42 V
                        Count: 171
                000 - - - MIL ON
                        Reset counter: 18
                        Voltage: 6.42 V
                        Count: 170
       Coding: 0040401
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 14:23:47
                        Reset counter: 18
                        Mileage: 249937 km
                        Date: 2020.07.01
                        Time: 21:09:32
                        Reset counter: 18
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:16:14
                        Reset counter: 18
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:16:14
       Coding: 0001168
       Component:    RDK              0420
       Coding: 0100101
    00667 - Ambient Temperature Signal
                        Reset counter: 58
                        Mileage: 249937 km
                        Date: 2020.07.02
                        Time: 15:20:12
                        Fault Frequency: 255
                        Reset counter: 58
       Coding: 0001168
    00935 - Electric Window Motor; Rear Right (V27)
                        Fault Status: 01100101
                        Reset counter: 18
    End----------(Elapsed Time: 01:41, VBatt start/end: 13.0V/12.5V)-----------
    HQ
    For ABS coding, try 0013755. Then do the Basic Settings for the ABS module:
    http://wiki.ross-tech.com/wiki/index...ke_Electronics
    For EPB coding, try 0000013. After you code the EPB module, you will need to do the "Function Test":
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    Do make sure you follow the rules of the game when playing with the EPB. If your electrical system (battery) is subpar, then you be:
    Jef
    Jun 2020
    Guyton, GA, USA
    Just wanted to give a update. I was able to code the used ABS module and now I have my speedometer working and parking brakes working. I need to actually mount the ABS module on the car. Just had Hernia surgery so it will be a minute before that happens. Thanks for helping.
  10. Likes Jef, Jetta ,97 liked this post
  11. #8
    HQ
    Good to hear. Once you have everything buttoned up, please post a follow up Auto-Scan.
    Jef
  12. Likes Uwe liked this post
