AC Blows Hot Air with Fan Error-2008 Rabbit
betterimp
C?ID=370791
I'm trying to diagnose ac not working.
I have verified there is refrigerant.
With ac turned on pressure on low side is 88psi. High side is 65psi.
Low side pressure is close to ambient temperature.
There are errors in the auto scan referring to the fans, but I have verfied both fans are on and working with engine idling.
I suspect the RCV solonoid is the problem, but I would like to be sure.
I tried to operate the fans by using vcds but was unsuccessful.
Can anyone help with this.
BTW-I turned on AC this morning while driving and had cold air for a short period of time.
Thursday,02,July,2020,15:41:32:33951
VIN: WVWAA71K38W240338   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K38W240338   Mileage: 281100km-174667miles
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BK    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1568
   Revision: 1NH01---    Serial number: VWX7Z0H03NL95V
   Shop #: WSC 01279 785 00200
   VCID: 73B3DE1627BD61635E9-8026
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 131
                    Mileage: 251659 km
                    Time: 06:30:15
                    RPM: 1588 /min
                    Load: 61.2 %
                    Speed: 37.0 km/h
                    Temperature: 86.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.097 V
006480 - Radiator Fan (V7)
               P1950 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 16
                    Mileage: 252633 km
                    Time: 02:01:00
                    RPM: 681 /min
                    Load: 18.4 %
                    Temperature: 91.0°C
                    Temperature: 54.0°C
                    Voltage: 13.589 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Fault Frequency: 27
                    Mileage: 270782 km
                    Time: 11:18:37
                    RPM: 679 /min
                    Load: 19.2 %
                    Temperature: 92.0°C
                    Temperature: 52.0°C
                    Voltage: 13.716 V
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3FDB42265B75F5036A1-806A
   Part No SW: 1K0 820 047 HJ    HW: 1K0 820 047 HJ
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   Revision: 00H54000    Serial number: 00000007947775
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 09460 444 53328
   VCID: 71BFD41E5DA15373AC5-8024
   Component: Wischer 180108 021  0501
   Coding: 00038805
   Shop #: WSC 09460
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0ADA2P
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6C81C56A7A83BE9B9F3-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3802486BD
   Subsystem 3 - Serial number: 6342MSME327361330
   Subsystem 4 - Serial number: 6352QSME4C77273DW
   Subsystem 5 - Serial number: 6362QSME45334E01C
   Subsystem 6 - Serial number: 63727SME12764F465
   Subsystem 7 - Serial number: 63827SME12765619+
   Part No SW: 1K0 953 549 BN    HW: 1K0 953 549 BN
   Component: J0527           051 0100
   Coding: 0000042
   VCID: 7F5B02261BF535032A1-802A
   Part No SW: 1K0 920 974 J    HW: 1K0 920 974 J
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0H03NL95V
   Coding: 0007203
   Shop #: WSC 00000 067 57207
   VCID: 3537200E69493F53B0D-8060
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K081230695
   Coding: E9801F070002020000
   VCID: 3039111A962B1A7BE3B-8064
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 3829293A7E5BC23BABB-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 00028 028 00001
   Coding: 139006885103281B0904058FB0080A04889C00
   Shop #: WSC 00000 785 00200
   VCID: 04518DCA721356DB773-8050
   Coding: 0001076
   VCID: 392F2C3E4551DB33545-806C
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       015 0019
   Revision: 00015000    Serial number: VWZ4Z7G6309362
   Coding: 0040402
   VCID: 1F1BE2A6FBB595034A1-804A
   Coding: 0100101
End----------(Elapsed Time: 00:56, VBatt start/end: 12.3V/12.3V)-----------
NZDubNurd
New Zealand
C?ID=230482
The fans fail often - the brushes get clogged up and stick in their holders. That usually results in the "Movement Restricted / Jammed" fault
I dismantled mine, cleaned out the crud and freed them up and they're been fine for years. The brushes were only about 1/3 worn.
After that... it probably is the compressor control valve. They also stick and often become intermittent - occasionally giving actual AC, often though, making the AC output feel hot.
TFSI
Maryland, USA
C?ID=66650
Looks like inadequate pressure is the issue, please make sure the basics are right: recover and recharge freon to the required capacity according to elsa/erwin or even there is a data sticker in the hood area that shows recommended freon in grams. Now ensure that the compressor received supply to the N280 valve. If you have voltage present but compressor output is low or no activation, check the compressor pulley, I think this car uses the externally regulated compressor type and mostly the pulley drive sheer off and it spins freely with no engagement due to defect.
betterimp
C?ID=370791
AC Hot-Measuging block data for compressor?
I did the same, and the fans are working. The dealer wanted a lot to replace the fans.
This was years ago. I'm wondering why I am getting an error code when the fans are working.
I'm leaning towards the valve. But I'm wondering if I can get data from VCDS that would help me diagnose.
For example, I get expected voltage for the compressor, but actual voltage is blank-when looking at the measuring blocks. This might indicate a lack of signal to the compressor, but I'm not sure?
betterimp
C?ID=370791
Since I'm getting pressure equal to ambient temperature, doesn't that indicate there is enough refrigerant for the compressor to run?
When the ac switch is turned on, the pressure does seem to change some...low side goes up a little, and high side goes down a little, so they are not equal, but it seems like the compressor isn't doing much of anything.
I don't really understand how the RCV Solonoid works. It is more obvious with "old style" clutch.
Did you know the key to the compressor not failing or valve, is running slightly less than factory specs of refrigerant and adding forward fans in front of condenser to reduce and remove heat more effectively while not over taxing the already inefficiently chosen "size" AC compressor by VAG?
Compressor might of already sheared on hub, so it maybe best to inspect it?
Did you try simulating ground completed by duty cycle to compressor valve while observation of pressure changes?
betterimp
C?ID=370791
I thank you for the videos.
I will check to see if it has sheared.
Not sure what you are saying about the ground. Can you explain for 1st grader to understand.
By duty cycle I mean frequency....
I could, however, that is not what this section of forum is for and I'd rather you read the RTFB and SSP for design and function + WD to familiarize circuit.
Please see how to sections too and consider searching videos to self educate on how to test electronics or basic electronic class online, okay?
https://forums.ross-tech.com/showthread.php?633-Tis%92-the-HVAC-Season
Come back with RTFB and WD displayed and let me know what you don't understand?
This class might be helpful found on web no?
https://erwin.vw.com/erwin/showArticleProperties.do?articleId=165189
https://procarmanuals.com/wp-conten...-Conditioning-and-Climate-Control-Systems.pdf
https://www.google.com/url?sa=t&sou...Vaw2JDQ4Jh5qtKd2TXoLv6k4u&cshid=1593804421270
betterimp
C?ID=370791
Thank you. This is helpful. I will study.
I would like to become competent at electrical problem solving.
Back to duty cycle. I don't see any change in pressure. I was hoping to find out through VCDS if the signal is being sent to the valve. It might not prove it is the valve, but it would be nice to know the signal voltage is getting to the valve.
Since I did get a short period of cold air the other day, which has not happened again, it leads me to believe the compressor itself is functional, and attached to the shaft.
I appreciate the information. I will study it.
RTFB-Where to find the fine book? Is the Bentley manual what I want?
betterimp
C?ID=370791
...previous statement about fans working was incorrect. I saw them running at high speed, but when I turn on the ignition and turn on the ac...neither fan is running, and since I have a fault on the fans, I'm going to remove the fault before considering ac again.
I'm going to revisit output test to see if I can learn more about the fans.
betterimp
C?ID=370791
....Ran output test on fans. Both fans start and run during test.
Not sure if this model has a slow speed, but for now, I assume not, since that was not part of the test. I cleared faults for fans. They have not returned, yet.
Downloaded VW Repair Manual for HVAC system, and wiring diagram. Yikes, wiring diagram was a large file, but I have it now.
....not sure what to do, but I think I will try output test HVAC and see what happens.
Don't speculate verify the mechanical's yet?
betterimp
C?ID=370791
Thanks for the videos.
Pretty sure I observed pulley and shaft spinning together. So, I think that part is mechanically sound.
I will try to test for power to the RCValve.
So you did this by taking off hub and verifying or you used x-ray super hero vision?
If you think you are doing this by looking at pulley on belt and center clutch like a traditional compressor you are way wrong!
betterimp
C?ID=370791
Yikes! Quite a lot of sarcasm, but I get your meaning. I understand there is not an external clutch, but I thought I could see pulley and shaft turning together, but apparently that might not be the case. I will have to look at that again!
Good idea........... :p
Did you know it only takes a couple minutes to take hub off to inspect it?
You would appreciate that video and spare part if you dont have to change valve or open system.
