Results 1 to 5 of 5
Thread: 2011 Audi S4 sport diff problem
    Jul 2020
    Canada
    I recently purchased a B8 Audi S4 with a sport diff fault on the dash. Original owner said Audi dealer said it needs a new oil pressure sensor, I contacted audi and they confirmed that's what it needs so I ordered a new sensor and installed it today but i'm getting these codes.
    Thursday,02,July,2020,15:29:27:14058
    VIN: WAUDGCFL7BA005769   License Plate:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 22 2E 36 42 46 47 52 53 55 56 62
              72 77
    VIN: WAUDGCFL7BA005769   Mileage: 111750km-69438miles
    Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H06 0003
       Revision: --H06---
       Coding: 0104000A180F0128
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
       ROD: EV_ECM30TFS0218K0907551D.rod
       VCID: 323D1F4A84AC0F3B95F-8066
    Readiness: 1110 1101
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0050
       Coding: 28050A
       VCID: 025D8F8A740C7FBB45F-8056
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 137
                        Mileage: 111750 km
                        Date: 2020.07.02
                        Time: 15:28:38
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0028
                        Hex Value: 0x5091
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
       Component: BCM2 2.0      H04 0430
       Coding: 0B0100
       VCID: 76B5E35A28C4531B797-8022
       Subsystem 1 - Part No SW: 8T0 959 754 AD    HW: 8T0 959 754 AD
       Component: FBSAUDIB8 IDG  H50 0070
       Serial number: 0510000031693018
       Serial number: 0210000087749002
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01290520100692
       Coding: 66002000
       VCID: 005985827A006DAB53B-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H29 0392
       Revision: 10029001    Serial number: 00000000552642
       Coding: 26001096463CAF212600080300003D0D0F1C934802010141000000
       VCID: 3C2131725668C94B4F3-8068
       Component: WWS 010610  H06 0070
       Serial number: SWF10060011012
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10926493
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002405100342
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0G3JKP
       Coding: 30453735423030303030554A304C384B3053
       VCID: 45D754962522888320D-8010
       Serial number: 6334MSME540625443
       Serial number: 6344MSME5370550DC
       Serial number: 6352QSME2863260EI
       Serial number: 6362QSME5E621A1CT
       Serial number: 63732SME3B61001AV
       Serial number: 63832SME3661262C
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Revision: --------    Serial number: 90304JES0000Y
       Coding: 000016
       VCID: 3E253B7A4074DB5B617-806A
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 931     HW: 8K0 920 931
       Component: KOMBIINSTR.   H06 0258
       Revision: 00000000    Serial number: EJE644U5A
       Coding: 8B05090082000008020000
       VCID: 6B83C22E63869EF3969-803E
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G105248124
       Coding: 00C303
       VCID: 015F8086710A64A35C5-8054
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 1001BC18200510
                        Reset counter: 176
                        Mileage: 111750 km
                        Date: 2020.07.02
                        Time: 15:27:19
                        Bin. Bits:    10111
                        Voltage: 11.80 V
                        Count: 6
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H10 0025
       Serial number: 001305100001068
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
       VCID: 2E050B3A90942BDBF17-807A
    0325 - Internal Control Module Memory Check Sum Error
              B2000 00 [137] - -
              [SG Defekt DTC_QCU_DEFEKT]
                        Mileage: 106941 km
                        Date: 2020.02.22
                        Time: 18:08:46
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020302
       VCID: 392F2866595AFC63545-806C
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001010170924
       Coding: 00581300000000000000
       VCID: 3B23326E5366CE73469-806E
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1401
       Coding: 011C03204E00410001
       VCID: 53F37ACEDBF62633BE9-8006
       Revision: 00002001    Serial number: 0130600748
       Coding: 0106023A00FA044480B0013200000000
       Shop #: WSC 06342 000 00000
       Subsystem 2 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS039  H06 0041
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74B1D9523EB8410B473-8020
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1401
       VCID: 52FD7FCAE4EC2F3BB5F-8006
       Revision: 00000003    Serial number: 00000000654125
       VCID: 343119527E38010B873-8060
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77ABEE5E23CE2A13621-8022
       Part No SW: 8T1 035 195 AD    HW: 8T1 035 195 AD
       Component: Symph3 Sirius H06 0351
       Revision: 00000009    Serial number: AUZ5Z4J1212942
       Coding: 240200020101870003D9070804
       VCID: 79AFE86619DA3C63145-802C
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1401
       Coding: 010C03204000210001
       VCID: 56F583DAC804331B597-8002
       Component: TSG HR        H06 1401
       Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005082636
       Coding: 0010370
       VCID: 3D273C764172C04378D-8068
    End----------(Elapsed Time: 01:38, VBatt start/end: 12.2V/12.2V)-----------
    The fault in the ABS is just a "sympathy" code for the center differential.
    As for the center differential itself:
    "Internal Control Module Memory Check Sum Error -- [SG Defekt DTC_QCU_DEFEKT]"
    I'm not sure what to tell you about that.
    Do you have a scan from before you did the work?
    Jul 2020
    Canada
    Yes it was the same faults as now.
    HQ
    J492 is located at the right rear of the car, looks to be behind the carpeted panel in the cargo area. It has 2 powers and a single ground. T47b/28 look to be a Terminal 15 power (ignition on) to wake up the module. And T47b/46 is the main power with a rather beefy 4.0mm² ws/rt wire and then T47b/47 is ground with another beefy 4.0mm² br wire.
    It seems the J492 uses a 35A fuse that goes to T47b/46. I would unplug the J492 and use a 180 LOADPro to verify those beefy power/ground wires are not suffering a voltage drop issue. If that checks out good, then odds are you do in fact have a bad J492.
    As I recall, you had cleared the code out and it came right back... If this is the case and it is in fact a bad module, you'll be able to verify that when you plug up another working module... the code won't come back. But odds are the Audi dealer will have to marry a replacement unit to the car.
    Jef
  5. Likes Uwe liked this post
    Jul 2020
    Canada
    Thanks for the reply. I’ll try that in the morning and see what happens. I may have a friend with a spare module.
