Good day fine gents!
I wanted to do what I thought would be a simple job to replace the oem wimpy horn on my 2013 VW Golf with a dual Fiam horns but following the setup I found out that the original horn was only for the remote door locks sound and there was another horn (also pathetic!) somewhere else installed by the previous owner when he added an alarm on the car.
First question: can it be that the alarm horn was added with the vag-com coding since I removed the original connector to the original horn and the alarm horn still works and gets power from somewhere else? Or maybe a separate circuit was added?
Second: I ended up with two dashboard warning lights that I can't clear with the vag-com:yellow Solid: ESP/ASR and Yellow solid: power steering reduced.
I'm forever grateful for your help in sorting this out. Thanks.
Here is the scanning:
Tuesday,30,June,2020,13:45:58:64309
VIN: WVWDA7AJ1DW101307 License Plate: GOLF 4
Mileage: 77110km-47913mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: Mileage: 77110km-47913miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 DH HW: 07K 907 309 B
Component: 2,5l R5/4V G01 3848
Revision: T4H06--- Serial number:
Coding: 0000075
VCID: 77A8E2B9B3C2F7E3621-8022
Readiness: 1110 0101
Part No SW: 09G 927 750 LM HW: 09G 927 750 LM
Component: AQ 250 6F 2252
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 07489279C3228763121-8052
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B400C492200FB880E02E492200041310000
VCID: 7DA4F0919DFEDDB338D-8028
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004002
VCID: 7BA0FE89836AD383069-802E
Part No SW: 1K0 937 084 J HW: 1K0 937 084 J
Component: BCM PQ35 B 111 0709
Revision: AC111709
Coding: 6F180A1A94232EC4008000C1500004444A010386524D8D60648020200040
VCID: 353428B1E54EC5F3B0D-8060
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 19091 26 0512
Coding: 009795
Reset counter: 188
Mileage: 77117 km
Date: 2014.11.21
Time: 18:49:28
Voltage: 11.55 V
Term 50 Off
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R00U2RS
Coding: 00004734
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C223D95C6E414BB4F3-8068
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME2F062372ZZZU
Serial number: 3582MSME54586072ZZZV
Serial number: 3512QSME543E2071ZZZR
Serial number: 3522QSME762D192BZZZ0
Component: F.Sens.Fahr --- ----
Serial number: 35527SME24694A2EZZZR
Component: F.Sens.Beif --- ----
Serial number: 35627SME5D264C2EZZZZ
Part No SW: 5K0 953 507 AE HW: 5K0 953 549
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LIM000WI
Coding: 5880140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 73B0D6A9AB3A9BC35E9-8026
Part No SW: 5K0 920 863 HW: 5K0 920 863
Component: KOMBI H05 0705
Coding: 370F00
VCID: 6C82CDD5F604443B9F3-8038
Part No SW: 7N0 907 530 AB HW: 7N0 907 530 AB
Component: J533 Gateway H47 1633
Revision: H47 Serial number: 150912F1000407
Coding: 350002
VCID: 70BAD9A5DAACA0DBA3B-8024
Reset counter: 188
Mileage: 77117 km
Date: 2014.11.21
Time: 18:49:29
Component: IMMO H05 0705
VCID: 6A8ECBCDFCF05A0BEDF-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 313C1CA11D26E9D3EC5-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
VCID: 372822B9F34237E3A21-8062
000 - - - MIL ON
Fault Status: 11100000
Mileage: 77117 km
Date: 2014.11.21
Time: 18:50:59
Battery Volts: 11.6 V
DD
Temperature: 30.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 323E13AD1820D2CB95F-8066
Address 56: Radio
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 353428B1E94EC5F3B0D-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 36362FBDF448CEEBB97-8062
End----(Elapsed Time: 00:53, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
