Hoping for a little guidance if possible. A chap asked me to scan his car to double check a garages suggestion before paying for more parts.
Short story if I understood it correctly:
- car working perfectly fine
- took it to a garage to replace rear springs (one had snapped) and front drop links (worn)
- on collection, the ABS/ESC lights were lit on the dashboard
- garage blamed the front left speed sensor and ordered a replacement
- took it back to the garage for a new front left speed sensor
- on collection, it had both the previous ABS/ESC lights and now also the steering light
- told to take it for a drive to see if the faults would clear
- faults remain so they now suggest a new ABS module
Autoscan:
We did a short test drive and front left showed 0 km/h where as the other three sensors looked plausible. To me, that suggests a wiring issue between the ABS module and front left speed sensor. Possibly caused by the garage disturbing the wiring during the drop link replacement.
I've suggested he have the garage load test the wiring, check the reluctor ring is clean and check the clearance before considering a replacement ABS module.
As for the steering light, I checked the adv measuring blocks in 44 Steering assist while moving the wheel:
- Steering Torque (G269) was changing
- Steering Angle Speed was changing
- Steering Angle Sensor (G85) was static at 0°
- Calibration Status (G85) was 'OK'
Not 100% what the cause is but I fear that could be be a disturbed connector? It only appeared after the garage removed the battery box and disconnected various wires when trying to figure out the ABS/ESC light issue. I've suggested that the disturbed connectors are all double checked but I'm not totally convinced.
Anything obvious that I've missed or other advice/suggestions I should be giving the owner before going back to the garage?
Autoscan:
Wednesday,01,July,2020,14:26:39:30291
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4513.4
VIN: TMBEH21Z282120034 License Plate:
Mileage: 380950km-236711mi Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBEH21Z282120034 Mileage: 380950km-236711miles
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EL HW: 03G 906 018 EL
Component: R4 2.0l PPD1.2 9953
Revision: --H52--- Serial number: SKZ7Z0G4653339
Coding: 0000072
Shop #: WSC 00191 264 15243
VCID: 73B3210C47B24DA35E9-8026
Readiness: N/A
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0006786
Shop #: WSC 73430 790 00000
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
VCID: 76B5181854C0588B797-8022
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Revision: 00H54000 Serial number: 00000005481089
Coding: B1880F011004140043110D000000000000197F074100000C000000000000
Shop #: WSC 73430 790 12345
VCID: 71BF2B043DAE7FB3AC5-8024
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 180108 022 0601
Coding: 00057271
Shop #: WSC 73430
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1RC6JS
Coding: 0020788
VCID: 3D27C7343176CBD378D-8068
Subsystem 1 - Serial number: 6332MSME2245332D5
Subsystem 2 - Serial number: 6342MSME33037432/
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000012
VCID: 7F5BFD3C7BFA19C32A1-802A
Part No SW: 1Z0 920 912 E HW: 1Z0 920 912 E
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4653339
Coding: 0000401
Shop #: WSC 23032 210 175203
VCID: 372BD51C134AE183A21-8062
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K0811108C5
Coding: E9807F064002021303
Shop #: WSC 23042 576 94337
VCID: 3431E210023C0A9B873-8060
Component: IMMO VD1 1610
Address 37: Navigation Labels: 1T0-919-887.lbl
Part No: 1Z0 919 887 B
Component: Navigation 0412
Shop #: WSC 26029 576 92321
VCID: 47CBA5DC63AA9103D21-8012
02731 - CD Reading Error
001 - Upper Limit Exceeded
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000756
VCID: 3829D6201E54EEFBABB-806C
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 73430 000 90108
VCID: 3635D8181440188BB97-8062
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F048D0D4008DF96907CA0
VCID: 035371CC17127D234E9-8056
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Subsystem 6 - Part No: 1K0 951 605 D
Subsystem 7 - Component: NGS n.mounted
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 392FD324255EF7F3545-806C
Address 56: Radio Labels: 1T0-035-095.lbl
Part No: 1T0 035 095
Component: Radio 0412
Coding: 0001445
VCID: 6B83396C1F829563969-803E
00879 - Connection to Speaker Front Right
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 73430 790 1012544
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End----------(Elapsed Time: 01:13, VBatt start/end: 12.2V/12.2V)-----------
