So I figured out the issue and yes it makes me feel like an idiot, but the results do confirm a specific suspicion ihad regarding the pressure readings I was seeing from the sensor. I will post the before and after readings. But I thought it was odd that I was seeing negative pressure readings coming from the sensor.
So here is what I did wrong. When I installed the sensor I installed the hoses to the wrong ports on the sensor, so it was obviously seeing very incorrect information, which would explain why i was getting the erratic/intermittent reading on the sensor and a sensor fault. I had a feeling that the negative pressure I was seeing was some sort of sign that the sensor was receiving incorrect data. That is why I double checked the hose routing. On this sensor the hose diameter is the same, so it is possible to mix them up, but I also noticed that where the metal line and the rubber line connect, there is an indent where the metal line should rest. This line had a mark on it where it rested before and I noticed the mark on the metal line was not exactly in the same spot as before, maybe 2 or 3mm back. So this again made me think.
Anyway long story short. I switched the hoses and after a 25 minute drive, no MIL, no codes. So I think the issue has been resolved.
Below are the original readings I had of the pressures, which showed a negative reading. And then the new readings that show positive hPa numbers, which makes more sense to me. So I guess it is a good idea to look at those numbers to see if something looks off.
Thanks to everyone who passed their knowledge on and despite me figuring the issue out, i learned more about ways to diagnose some issues.
Paul
Before -
Address 01: Engine (04L 906 026 JC)
17:53:50
IDE00434 Particle filter: soot mass calculated 11.94 g
IDE00435 Particle filter: soot mass measured 0.11 g
IDE11896 Particle filter: differential press. sens.1 bank 1: raw value 1 -16 hPa
IDE11897 Particle filter: differential press. sens.1 bank 1: raw value 2 20 hPa
____________________________________________________________________________________
After-
VIN: WVGZZZ5NZHW807260 License Plate:
Mileage: 114431km-71104mi Repair Order:
08:31:07
IDE00434 Particle filter: soot mass calculated 6.41 g
IDE00435 Particle filter: soot mass measured -0.65 g
IDE11896 Particle filter: differential press. sens.1 bank 1: raw value 1 44 hPa
IDE11897 Particle filter: differential press. sens.1 bank 1: raw value 2 10 hPa
