Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Do I need to adapt a DPF pressure sensor for a 2016 Tiguan?
    Jun 2020
    Austria
    I am new to the forum. I have a 2016 VW Tiguan.
    Recently I had a couple fault codes related to the DPF pressure sensor. I checked voltage and blockage. All seemed to be normal so I figured it was the sensor. I bought a new sensor from VW and installed it. I cleared the codes and drove it for a bit but the check engine light comes back with the following codes.
    P2456 00 (237) - DPF sensor intermittent
    P154B 00 (040) - DPF Sensor faulty
    I am not sure if I needed to adapt the new sensor before starting the car again or not. At the time i did not have VCDS, but just a somewhat generic reader.
    Do I need to adapt the sensor on this car? And if so what would be the procedure. I only see a procedure for the G450, is that the same?
    I should add the tiguan drives completely fine and just recently i performed a regen (the regen light came up).
    Any help would be great.
    Thank you
    Paul
    Below is my complete auto scan
    Tuesday,30,June,2020,16:51:30:28823
    VIN: WVGZZZ5NZHW807260   License Plate: IM-435HM
    Mileage: 114297km-71020mi   Repair Order: N/A
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55 5F
              69 6D A5 D6 D7
    VIN: WVGZZZ5NZHW807260   Mileage: 114297km-71020miles
    29-Left Light -- Status: Malfunction 0010
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 JC    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H24 3023
       Revision: B4H24---
       Coding: 0119001204561D083000
       ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
       ROD: EV_ECM20TDI01104L906026GQ_004.rod
       VCID: 74B025844E3C26DB473-8020
    5158 - Diesel Particulate Filter; Differential Pressure Sensor
              P2456 00 [237] - Intermittent
                        Fault Frequency: 12
                        Mileage: 113917 km
                        Date: 2020.06.26
                        Time: 09:05:13
                        Engine speed: 2752.50 /min
                        Normed load value: 31.0 %
                        Vehicle speed: 69 km/h
                        Coolant temperature: 66 °C
                        Intake air temperature: 80 °C
                        Ambient air pressure: 900 mbar
                        Voltage terminal 30: 14.420 V
                        Particle filter: air pressure sensor 1 bank 1: raw value: -143 hPa
                        Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: -8 hPa
                        Par.fil: diff.pr.sens.1 bank 1: offset: -1 hPa
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -135 hPa
                        Extern.temp.sens.1 bank 1: raw value: 14.0 °C
                        Particle filter: soot mass measured: 9.95 g
                        Particle filter: soot mass calculated: 16.42 g
    31489 - Differential Pressure Sensor for DPF
              P154B 00 [040] - Faulty
                        Mileage: 113916 km
                        Date: 2020.06.26
                        Time: 09:04:49
                        Engine speed: 2559.50 /min
                        Normed load value: 83.9 %
                        Vehicle speed: 64 km/h
                        Coolant temperature: 68 °C
                        Intake air temperature: 84 °C
                        Ambient air pressure: 890 mbar
                        Voltage terminal 30: 14.340 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Readiness: 1 2 0 0 0
       Part No SW: 5Q0 614 517 CA    HW: 5Q0 614 517 AC
       Component: ESC           H25 0408
       Revision: 00000000    Serial number: 61666000001417
       Coding: 0AEE6A9A34200B734779670662C34950562CD0E2E646927D34605078C02A02
       VCID: 72BC239C342828EB55F-8026
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0406519828
       Coding: 032C2C0E0F
       ROD: EV_KessyHellaMQBAB.rod
       VCID: 3C20CDA426ECAE9B4F3-8068
       Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
       Component: GEB.F.Heckoef  H17 0903
       Serial number: 98034498
       Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
       Component: AC Automat    H35 4003
       Revision: 20K08000    Serial number: 00000B00154399
       Coding: 0002010420211001110510000010102A
       ASAM Dataset: EV_ACClimaPrehVW37X 002014
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 47CAA2486F2AFD43D21-8012
       Subsystem 1 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 231
                        Mileage: 111032 km
                        Date: 2020.05.26
                        Time: 09:12:42
                        Outside air temperature: 14.0 °C
                        Voltage terminal 30: 13.2 V
                        System run time-Engine running time: 253 s
                        System run time-Terminal 15 on: 253 s
                        Air quality status: ERROR
       Serial number: 02001616702657
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA407AC70707C8B217-802A
       Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 160523  033 0372
       Serial number: 00000001605180308513
       Component: RLHS  037 0059
       Serial number: S2Y16M06D20H11M17S27
       Coding: 00A8DD
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 166
                        Mileage: 97151 km
                        Date: 2019.10.11
                        Time: 15:47:35
    204546 - Remote key 2
              B147A 18 [008] - Current Too Low
                        Fault Frequency: 22
                        Reset counter: 2
                        Mileage: 103934 km
                        Date: 2020.01.12
                        Time: 11:30:04
       Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
       Component: PDC 8 Kanal   H07 0020
       Serial number: 001006167478010
       Coding: 0071451901
       ASAM Dataset: EV_EPHBO18VW3260000 007015
       ROD: EV_EPHBO18VW3260000_SK37.rod
       VCID: 372AD2881FCA8DC3A21-8062
    1113328 - Parking Sensor(s); Front
              B10FC F0 [008] - Function Limitation due to External Factors
              [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                        Reset counter: 252
                        Mileage: 113757 km
                        Date: 2020.06.25
                        Time: 10:06:05
       Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0155
       Coding: 2A0140C950FF8728749C8065104085
       ASAM Dataset: EV_ACCMRRCONTIVW376 001010
       ROD: EV_ACCMRRCONTIVW376_001.rod
       VCID: 392ED4B029DE9BB3545-806C
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR1VG2SL
       Coding: 98CCC0C00C0000005C5400CF000800000065
       VCID: 107849145AE47AFBC3B-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NB857705C0164Q00039
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NB857706C0162Q01191
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 706 16
       Serial number: 35700000000CB5843C1S
       Subsystem 4 - Part No SW: -----------    HW: 480 001 706 16
       Serial number: 35800000000A33CC2C1S
       Subsystem 5 - Part No SW: -----------    HW: 480 401 306 16
       Serial number: 3510001B720FC4824492
       Subsystem 6 - Part No SW: -----------    HW: 480 401 306 16
       Serial number: 3520001B720FC48303D3
       Subsystem 7 - Part No SW: -----------    HW: 480 401 206 16
       Serial number: 3550001AF20FC48497DR
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 22800019920E2701831Q
       Subsystem 9 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 22900019920E270317AZ
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 480 401 306 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 23000019920E2701433H
       Subsystem 11 - Part No SW: -----------    HW: 480 001 006 16
       Serial number: I0M000000007B3698B1A
       Subsystem 12 - Part No SW: -----------    HW: 480 001 006 16
       Serial number: I0N000000007DA188B1E
       Part No SW: 3Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF035035    Serial number: 20160619501310
       Coding: 0C00
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDABAA837FAB5836A1-806A
       Part No SW: 5NA 920 751 A    HW: 5NA 920 751 A
       Component: KOMBI         307 8311
       Coding: 07A400106F84000801886B031401000000000000
       VCID: 3D26C0A03DF6A79378D-8068
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 5
                        Mileage: 114086 km
                        Date: 2020.06.29
                        Time: 20:02:07
       Revision: --------    Serial number: 0004981669
       Coding: 030500341F087300FB07225E0A0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA00DA4666C6E9B0F3-8028
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 1671620362701721AT2B
       Coding: 2C0000
       Serial number: 2616530504
       Serial number: HA1-00020.05.16
       Coding: 0101
       VCID: 4ACC9B7C7C38002BCDF-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH05 0012
       VCID: 45D6A8405526EF5320D-8010
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 229
                        Mileage: 110831 km
                        Date: 2020.05.23
                        Time: 16:50:05
       Serial number: 16000120759018
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BE2C90312E13F3AC5-8024
       Serial number: 300516EEU13765
       Coding: 00311B20D000048000001000
       VCID: 43D2B6585B12D1630E9-8016
       Serial number: 00000000000010462189
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000872071
       Coding: 01000011004001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       Serial number: 220516EEL28188
       Coding: 00311120DE00048000001000
       VCID: 42DCB35C4408D86B05F-8016
       Serial number: 00000000000010443823
       Coding: 090000
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08AA00104B200201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
       VCID: 41DEBC50410EC3731C5-8014
       Part No SW: 3Q0 035 846 A    HW: 3Q0 035 846 A
       Component: MU-S-N-ER     840 0743
       Coding: 02730601FF0000005111000100080A001F0100C4012001008F
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2F3AEAE8E79A4503FA1-807A
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL02HRP
       Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
       Component: ECE1 2016/17  --- 0635
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0406299883
       Coding: 0100000202000000
       ROD: EV_TrailFunctGener2Hella_VW37.rod
       VCID: 3B22CEB823E2A9A3469-806E
       Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0260
       Revision: --------    Serial number: 30721974400000
       Coding: 0AA8
       ASAM Dataset: EV_DeckLidCONTIAU736 001013
       VCID: 3828D1B412D482BBABB-806C
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 13061611K22740
       Coding: 0003070600000401002213458050A10094000E200040
       VCID: 3A2CCBBC2CD890AB5DF-806E
    1275 - Unknown Error Code
              B182E F0 [024] - Unknown Error Elaboration
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 168
                        Mileage: 66391 km
                        Date: 2018.07.23
                        Time: 22:42:05
                        Control Module temperature: 42 °C
                        Vehicle speed: 74.94 km/h
                        System run time: 5749.6 s
                        Voltage terminal 15: 13.2 V
                        mid: 01 62
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
       VCID: 16743F0C780094CB997-8042
    End----------(Elapsed Time: 02:02, VBatt start/end: 12.2V/12.2V)-----------
                    Address 01: Engine       Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 906 026 JC    HW: 04L 907 309 P
      Component and/or Version: R4 2.0l TDI   H24 3023
               Software Coding: 0119001204561D083000
                Work Shop Code: WSC 01357 011 00200
                  ASAM Dataset: EV_ECM20TDI01104L906026JC 004002 (VW37)
                        Fault Frequency: 12
                        Mileage: 113917 km
                        Date: 2020.06.26
                        Time: 09:05:13
                        Mileage: 113916 km
                        Date: 2020.06.26
                        Time: 09:04:49
                        Fault Frequency: 12
                        Mileage: 113917 km
                        Date: 2020.06.26
                        Time: 09:05:13
                        Mileage: 113916 km
                        Date: 2020.06.26
                        Time: 09:04:49
                        Fault Frequency: 12
                        Mileage: 113917 km
                        Date: 2020.06.26
                        Time: 09:05:13
                        Mileage: 113916 km
                        Date: 2020.06.26
                        Time: 09:04:49
                        Fault Frequency: 12
                        Mileage: 113917 km
                        Date: 2020.06.26
                        Time: 09:05:13
                        Mileage: 113916 km
                        Date: 2020.06.26
                        Time: 09:04:49
    Address 01: DTCs cleared
    May 2017
    I swapped my DPF sensor as well last october and although the instructions say that you need to adapt the new sensor, I didn't. I did run a forced regen though but no adaptation was done.
    I've had zero issues.
  3. Likes elqwan, Jack@European_Parts liked this post
    Jun 2020
    Austria
    Thanks for your feedback.
    Since I have installed this sensor the above fault came back after I cleared the DTC's and drove it for a bit. The other day I did a force regen (the check engine light was on). Now that I have vcds, i have cleared the codes. I have only driven the tiguan for about 15 minutes and no faults have come back. Maybe now that the MIL is off, i should do another force regen.
    Regardless, do you know how i should perform an adaptation for the newer sensor. I can't seem to find an option for it on VCDS.
    Paul
    May 2017
    I didn't find it either, maybe that's why I did not do it
    I used ODIS for regen cycle and if I remember correctly I tried to do dpf sensor adaptation from the basic settings there and it stated based on measured values that it is not needed so I didn't do it.
    Jun 2020
    Austria
    So I just went for a 35 minute drive and the mil came back on with the same codes.
    I guess I should clear the codes and set a Regen.
    How do I set a force Regen on vcds?
    I’m just wondering why I have a code that says I have a faulty pressure sensor when it’s brand new. Obviously things can be bad right out of the box. But I was wondering if I messed it up by not doing an adaptation.
    Or simply doing a force Regen will calibrate the Sensor and it will read correctly.
    Is the DPF clean though?
    Jun 2020
    Austria
    I’m not sure. Two weeks ago was the first time the car asked to do a Regen. We bought the car new in 2016. I do not feel any loss In power like I would have a blocked exhaust.
  9. #8
    Did you consider if PSI lines are at top of DPF and the sensors were vicariously damaged as a result of filled ash or particulate matter, would it be plausible that the DPF is most likely full?
    Did you measure back pressure comparisons with mechanical gauges or are you going to continue to use speculation by the use of your ass in seat method, you know via mind melt with car?
    What's this stuff do?
  10. #9
    Jun 2020
    Austria
    I appreciate your sarcasm. Well my procedure was this. I checked to see if the lines are blocked. Appears to be good. I checked voltage going to the sensor. All with in spec. So I figured the last thing it could be was the sensor. Before I put the new sensor in I did not get a sensor failed code but a sensor erratic code.
    No I have not checked the sensor with a mechanical gauge yet to verify if the sensor is reading accurately.
    This is my first time diagnosing ecu issues and first time using vcds. So I am just trying to find direction from some experts like you.
  11. #10
    Jun 2020
    Austria
    Did you consider if PSI lines are at top of DPF and the sensors were vicariously damaged as a result of filled ash or particulate matter, would it be plausible that the dpf is full?”
    Would a full dpf set off a code which reads Sensor faulty?
    And wouldn’t a blocked dpf be caused from a faulty sensor? The sensor not seeing the filter is getting full? Or why would a dpf filter clog up and the sensor not pick this up?
